root/radiance/ray/src/cv/CMakeLists.txt
Tue Mar 8 19:04:56 2022 UTC (3 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.20: +7 -4 lines
Diff to previous 1.20
feat(iso2klems): New script to generate Klems BSDF from simplified measurements
Tue Dec 14 02:33:18 2021 UTC (3 years, 4 months ago) by greg
Changes since 1.19: +4 -0 lines
Diff to previous 1.19
feat(checkBSDF): created new checkBSDF tool to check XML data reciprocity
Sat Dec 5 16:33:01 2020 UTC (4 years, 4 months ago) by greg
Changes since 1.18: +1 -0 lines
Diff to previous 1.18
chore(robjutil): added to installer targets is it wasn't being copied
Fri Nov 13 16:09:54 2020 UTC (4 years, 5 months ago) by greg
Changes since 1.17: +1 -0 lines
Diff to previous 1.17
chore(bsdf2rad): added missing target to CMakeLists.txt
Wed Aug 19 04:33:20 2020 UTC (4 years, 8 months ago) by greg
Changes since 1.16: +1 -0 lines
Diff to previous 1.16
chore: fixed missing ')'
Tue Aug 18 19:33:58 2020 UTC (4 years, 8 months ago) by greg
Changes since 1.15: +8 -2 lines
Diff to previous 1.15
chore: added custom Windows compilation of Perl scripts
Mon Mar 30 18:28:35 2020 UTC (5 years, 1 month ago) by greg
Diff to previous 1.14
Mon Jan 8 16:51:32 2018 UTC (7 years, 3 months ago) by greg
Changes since 1.13: +43 -21 lines
Diff to previous 1.13
Update to CMake build system from Rob G. and Alex S., adding test cases
Sat Aug 19 14:16:15 2017 UTC (7 years, 8 months ago) by greg
Changes since 1.12: +7 -4 lines
Diff to previous 1.12
Minor fixes for 5.1 release
Thu Apr 13 00:14:36 2017 UTC (8 years ago) by greg
Changes since 1.11: +2 -4 lines
Diff to previous 1.11
Added value flushing to bsdfquery and put in standard build
Sun Apr 9 21:39:26 2017 UTC (8 years ago) by greg
Diff to previous 1.10
Wed Jul 27 18:05:53 2016 UTC (8 years, 9 months ago) by greg
Changes since 1.9: +3 -0 lines
Diff to previous 1.9
Added pabopto2xyz utility to interpolate CIE-XYZ color values from measurements
Wed Feb 3 22:54:01 2016 UTC (9 years, 3 months ago) by greg
Changes since 1.8: +4 -2 lines
Diff to previous 1.8
Fixes in cmake build for last changes (thanks to Rob G.)
Wed Apr 16 20:48:07 2014 UTC (11 years ago) by greg
Changes since 1.7: +2 -1 lines
Diff to previous 1.7
Removed objview Ruby script, which is no longer needed for Windows
Mon Apr 7 21:34:09 2014 UTC (11 years, 1 month ago) by greg
Diff to previous 1.6
Added module for pabopto2bsdf in cmake
Fri Feb 7 19:17:40 2014 UTC (11 years, 2 months ago) by greg
Diff to previous 1.5
Minor fix from RobG
Tue Nov 26 22:35:51 2013 UTC (11 years, 5 months ago) by greg
Changes since 1.4: +10 -5 lines
Diff to previous 1.4
Removed pabopto2bsdf and pabopto2rad from Windows build list
Mon Nov 25 23:05:33 2013 UTC (11 years, 5 months ago) by greg
Changes since 1.3: +38 -19 lines
Diff to previous 1.3
Updates for new program installations
Wed Sep 25 16:52:28 2013 UTC (11 years, 7 months ago) by greg
Wed Apr 25 22:21:06 2012 UTC (13 years ago) by greg
Changes since 1.1: +9 -2 lines
Sat Oct 22 22:38:10 2011 UTC (13 years, 6 months ago) by greg
Added qt interface for rvu and cmake files from Bill Hoffman
