root/Development/ray/src/cv/CMakeLists.txt
Mon Jan 8 16:51:32 2018 UTC (7 years, 10 months ago) by greg
Changes since 1.13: +43 -21 lines
Diff to previous 1.13 , to selected 1.11
Update to CMake build system from Rob G. and Alex S., adding test cases
Sat Aug 19 14:16:15 2017 UTC (8 years, 3 months ago) by greg
Changes since 1.12: +7 -4 lines
Diff to previous 1.12 , to selected 1.11
Minor fixes for 5.1 release
Thu Apr 13 00:14:36 2017 UTC (8 years, 7 months ago) by greg
Changes since 1.11: +2 -4 lines
Diff to previous 1.11
Added value flushing to bsdfquery and put in standard build
Revision 1.11 - (view) (download) (annotate) - [selected]
Sun Apr 9 21:39:26 2017 UTC (8 years, 7 months ago) by greg
Diff to previous 1.10
Wed Jul 27 18:05:53 2016 UTC (9 years, 3 months ago) by greg
Changes since 1.9: +3 -0 lines
Diff to previous 1.9 , to selected 1.11
Added pabopto2xyz utility to interpolate CIE-XYZ color values from measurements
Wed Feb 3 22:54:01 2016 UTC (9 years, 9 months ago) by greg
Changes since 1.8: +4 -2 lines
Diff to previous 1.8 , to selected 1.11
Fixes in cmake build for last changes (thanks to Rob G.)
Wed Apr 16 20:48:07 2014 UTC (11 years, 7 months ago) by greg
Changes since 1.7: +2 -1 lines
Diff to previous 1.7 , to selected 1.11
Removed objview Ruby script, which is no longer needed for Windows
Mon Apr 7 21:34:09 2014 UTC (11 years, 7 months ago) by greg
Diff to previous 1.6 , to selected 1.11
Added module for pabopto2bsdf in cmake
Fri Feb 7 19:17:40 2014 UTC (11 years, 9 months ago) by greg
Diff to previous 1.5 , to selected 1.11
Minor fix from RobG
Tue Nov 26 22:35:51 2013 UTC (11 years, 11 months ago) by greg
Changes since 1.4: +10 -5 lines
Diff to previous 1.4 , to selected 1.11
Removed pabopto2bsdf and pabopto2rad from Windows build list
Mon Nov 25 23:05:33 2013 UTC (11 years, 11 months ago) by greg
Changes since 1.3: +38 -19 lines
Diff to previous 1.3 , to selected 1.11
Updates for new program installations
Wed Sep 25 16:52:28 2013 UTC (12 years, 1 month ago) by greg
Diff to previous 1.2 , to selected 1.11
Wed Apr 25 22:21:06 2012 UTC (13 years, 6 months ago) by greg
Changes since 1.1: +9 -2 lines
Diff to previous 1.1 , to selected 1.11
Sat Oct 22 22:38:10 2011 UTC (14 years, 1 month ago) by greg
Diff to selected 1.11
Added qt interface for rvu and cmake files from Bill Hoffman
