feat(iso2klems): New script to generate Klems BSDF from simplified measurements
feat(checkBSDF): created new checkBSDF tool to check XML data reciprocity
chore(robjutil): added to installer targets is it wasn't being copied
chore(bsdf2rad): added missing target to CMakeLists.txt
chore: fixed missing ')'
chore: added custom Windows compilation of Perl scripts
Update to CMake build system from Rob G. and Alex S., adding test cases
Minor fixes for 5.1 release
Added value flushing to bsdfquery and put in standard build
Added pabopto2xyz utility to interpolate CIE-XYZ color values from measurements
Fixes in cmake build for last changes (thanks to Rob G.)
Removed objview Ruby script, which is no longer needed for Windows
Added module for pabopto2bsdf in cmake
Minor fix from RobG
Removed pabopto2bsdf and pabopto2rad from Windows build list
Updates for new program installations
Added qt interface for rvu and cmake files from Bill Hoffman
