/* Copyright (c) 1987 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; #endif /* * xtwind.c - routines for X text windows. * * 10/30/87 */ #include #include #include "xtwind.h" #ifndef BSD #define bzero(d,n) (void)memset(d,0,n) extern char *memset(); #endif #define checkcurs(t) if ((t)->cursor) togglecurs(t) #define restorecurs checkcurs #define togglecurs(t) XPixFill((t)->w, (t)->c*(t)->f.width+LEFTMAR, \ (t)->r*(t)->f.height, (t)->f.width, \ (t)->f.height, 0, 0, GXinvert, 1) extern char *calloc(), *malloc(); TEXTWIND * xt_open(parent, x, y, width, height, border, fontname) Window parent; int x, y; int width, height; int border; char *fontname; { register int i; register TEXTWIND *t; if ((t = (TEXTWIND *)malloc(sizeof(TEXTWIND))) == NULL) return(NULL); t->w = XCreateWindow(parent, x, y, width, height, border, BlackPixmap, WhitePixmap); if (t->w == 0) return(NULL); XMapWindow(t->w); if ((i = XGetFont(fontname)) == 0) return(NULL); if (XQueryFont(i, &t->f) == 0) return(NULL); if (!t->f.fixedwidth) return(NULL); t->nc = (width - LEFTMAR) / t->f.width; t->nr = height / t->f.height; if (t->nc < 1 || t->nr < 1) return(NULL); if ((t->lp = (char **)calloc(t->nr+1, sizeof(char *))) == NULL) return(NULL); for (i = 0; i < t->nr; i++) if ((t->lp[i] = calloc(t->nc+1, 1)) == NULL) return(NULL); t->r = t->c = 0; t->cursor = TNOCURS; return(t); } xt_puts(s, t) /* output a string */ register char *s; TEXTWIND *t; { int oldcurs = xt_cursor(t, TNOCURS); while (*s) xt_putc(*s++, t); xt_cursor(t, oldcurs); } xt_putc(c, t) /* output a character */ char c; register TEXTWIND *t; { int oldcurs = xt_cursor(t, TNOCURS); switch (c) { case '\n': if (t->r >= t->nr - 1) xt_delete(t, 0); /* scroll up 1 line */ else t->r++; /* fall through */ case '\r': t->c = 0; break; case '\b': while (t->c < 1 && t->r > 0) t->c = strlen(t->lp[--t->r]); if (t->c > 0) t->c--; break; default: if (t->c >= t->nc) xt_putc('\n', t); XText(t->w, LEFTMAR + t->c*t->f.width, t->r*t->f.height, &c, 1, t->f.id, BlackPixel, WhitePixel); t->lp[t->r][t->c++] = c; break; } xt_cursor(t, oldcurs); } xt_delete(t, r) /* delete a line */ register TEXTWIND *t; int r; { char *cp; register int i; if (r < 0 || r >= t->nr) return; checkcurs(t); /* move lines */ XMoveArea(t->w, LEFTMAR, (r+1)*t->f.height, LEFTMAR, r*t->f.height, t->nc*t->f.width, (t->nr-1-r)*t->f.height); cp = t->lp[r]; for (i = r; i < t->nr-1; i++) t->lp[i] = t->lp[i+1]; t->lp[t->nr-1] = cp; /* clear bottom */ XPixSet(t->w, LEFTMAR, (t->nr-1)*t->f.height, t->nc*t->f.width, t->f.height, WhitePixel); bzero(cp, t->nc); restorecurs(t); /* should we reposition cursor? */ } xt_insert(t, r) /* insert a line */ register TEXTWIND *t; int r; { char *cp; register int i; if (r < 0 || r >= t->nr) return; checkcurs(t); /* move lines */ XMoveArea(t->w, LEFTMAR, r*t->f.height, LEFTMAR, (r+1)*t->f.height, t->nc*t->f.width, (t->nr-1-r)*t->f.height); cp = t->lp[t->nr-1]; for (i = t->nr-1; i > r; i--) t->lp[i] = t->lp[i-1]; t->lp[r] = cp; /* clear new line */ XPixSet(t->w, LEFTMAR, r*t->f.height, t->nc*t->f.width, t->f.height, WhitePixel); bzero(cp, t->nc); restorecurs(t); /* should we reposition cursor? */ } xt_redraw(t) /* redraw text window */ register TEXTWIND *t; { register int i; checkcurs(t); XClear(t->w); for (i = 0; i < t->nr; i++) XText(t->w, LEFTMAR, i*t->f.height, t->lp[i], strlen(t->lp[i]), t->f.id, BlackPixel, WhitePixel); restorecurs(t); } xt_clear(t) /* clear text window */ register TEXTWIND *t; { register int i; checkcurs(t); XClear(t->w); for (i = 0; i < t->nr; i++) bzero(t->lp[i], t->nc); t->r = t->c = 0; restorecurs(t); } xt_move(t, r, c) /* move to new position */ register TEXTWIND *t; int r, c; { if (r < 0 || c < 0 || r >= t->nr || c >= t->nc) return; checkcurs(t); t->r = r; t->c = c; restorecurs(t); } int xt_cursor(t, curs) /* change cursor */ register TEXTWIND *t; register int curs; { register int oldcurs; if (curs != TNOCURS && curs != TBLKCURS) return(-1); oldcurs = t->cursor; if (curs != oldcurs) togglecurs(t); t->cursor = curs; return(oldcurs); } xt_close(t) /* close text window */ register TEXTWIND *t; { register int i; XFreeFont(t->f.id); XDestroyWindow(t->w); for (i = 0; i < t->nr; i++) free(t->lp[i]); free((char *)t->lp); free((char *)t); }
