root/radiance/ray/src/common/xf.c
Thu Apr 2 20:44:15 2020 UTC (5 years, 2 months ago) by greg
Changes since 2.7: +4 -13 lines
Diff to previous 2.7 , to selected 1.4
Added -x option to robjutil to transform .OBJ files
Fri Jun 27 22:27:45 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 1.4
Fri Jun 27 06:53:22 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.5: +4 -5 lines
Diff to previous 2.5 , to selected 1.4
Tue Feb 25 02:47:22 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 2.4 , to selected 1.4
Sat Feb 22 02:07:23 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.3: +59 -5 lines
Diff to previous 2.3 , to selected 1.4
Tue Dec 24 17:42:48 1991 UTC (33 years, 5 months ago) by greg
Changes since 2.2: +7 -7 lines
Diff to previous 2.2 , to selected 1.4
changed the error returns
Thu Dec 19 14:45:41 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 1.4
Tue Nov 12 16:54:14 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.12 , to selected 1.4
Fri Nov 8 13:45:54 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.11: +19 -19 lines
Diff to previous 1.11 , to selected 1.4
added tighter argument checking with calls to badarg()
Wed Oct 23 15:19:25 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.10 , to selected 1.4
added FLOAT definition
Mon Jul 15 11:28:41 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.9: +0 -2 lines
Diff to previous 1.9 , to selected 1.4
removed conditional compiles
Sat Dec 15 15:01:40 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.8: +29 -20 lines
Diff to previous 1.8 , to selected 1.4
Tue Feb 20 18:02:30 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.7: +13 -7 lines
Diff to previous 1.7 , to selected 1.4
moved array and index back before transformation
Wed Oct 18 23:15:37 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.6: +28 -22 lines
Diff to previous 1.6 , to selected 1.4
added check for zero scalefactor
Fri Oct 13 19:34:51 1989 UTC (35 years, 7 months ago) by greg
Changes since 1.5: +26 -25 lines
Diff to previous 1.5 , to selected 1.4
Made argument error checking more efficient.
Fri Oct 6 09:39:42 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.4: +14 -22 lines
Diff to previous 1.4
Iteration now given after transformation.
Revision 1.4 - (view) (download) (annotate) - [selected]
Thu Oct 5 07:54:31 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.3: +65 -17 lines
Diff to previous 1.3
Added iterate argument for arrays.
Fri Mar 24 17:10:43 1989 UTC (36 years, 2 months ago) by greg
Diff to previous 1.2 , to selected 1.4
minor aesthetic fixes
Fri Mar 24 16:59:48 1989 UTC (36 years, 2 months ago) by greg
Changes since 1.1: +18 -0 lines
Diff to previous 1.1 , to selected 1.4
added better checks for transform arguments
Thu Feb 2 10:34:41 1989 UTC (36 years, 4 months ago) by greg
Diff to selected 1.4
