root/radiance/ray/src/common/xf.c
Revision: 1.10
Committed: Mon Jul 15 11:28:41 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.9: +0 -2 lines
removed conditional compiles
1 /* Copyright (c) 1990 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * xf.c - routines to convert transform arguments into 4X4 matrix.
9 *
10 * 1/28/86
11 */
12
13 #include "standard.h"
14
15 #define d2r(a) ((PI/180.)*(a))
16
17 #define checkarg(a,n) if (av[i][a] || i+n >= ac) goto done
18
19
20 int
21 xf(ret, ac, av) /* get transform specification */
22 register XF *ret;
23 int ac;
24 char *av[];
25 {
26 double atof(), sin(), cos();
27 double xfmat[4][4], m4[4][4];
28 double xfsca, dtmp;
29 int i, icnt;
30
31 setident4(ret->xfm);
32 ret->sca = 1.0;
33
34 icnt = 1;
35 setident4(xfmat);
36 xfsca = 1.0;
37
38 for (i = 0; i < ac && av[i][0] == '-'; i++) {
39
40 setident4(m4);
41
42 switch (av[i][1]) {
43
44 case 't': /* translate */
45 checkarg(2,3);
46 m4[3][0] = atof(av[++i]);
47 m4[3][1] = atof(av[++i]);
48 m4[3][2] = atof(av[++i]);
49 break;
50
51 case 'r': /* rotate */
52 switch (av[i][2]) {
53 case 'x':
54 checkarg(3,1);
55 dtmp = d2r(atof(av[++i]));
56 m4[1][1] = m4[2][2] = cos(dtmp);
57 m4[2][1] = -(m4[1][2] = sin(dtmp));
58 break;
59 case 'y':
60 checkarg(3,1);
61 dtmp = d2r(atof(av[++i]));
62 m4[0][0] = m4[2][2] = cos(dtmp);
63 m4[0][2] = -(m4[2][0] = sin(dtmp));
64 break;
65 case 'z':
66 checkarg(3,1);
67 dtmp = d2r(atof(av[++i]));
68 m4[0][0] = m4[1][1] = cos(dtmp);
69 m4[1][0] = -(m4[0][1] = sin(dtmp));
70 break;
71 default:
72 return(i);
73 }
74 break;
75
76 case 's': /* scale */
77 checkarg(2,1);
78 dtmp = atof(av[i+1]);
79 if (dtmp == 0.0) goto done;
80 i++;
81 xfsca *=
82 m4[0][0] =
83 m4[1][1] =
84 m4[2][2] = dtmp;
85 break;
86
87 case 'm': /* mirror */
88 switch (av[i][2]) {
89 case 'x':
90 checkarg(3,0);
91 xfsca *=
92 m4[0][0] = -1.0;
93 break;
94 case 'y':
95 checkarg(3,0);
96 xfsca *=
97 m4[1][1] = -1.0;
98 break;
99 case 'z':
100 checkarg(3,0);
101 xfsca *=
102 m4[2][2] = -1.0;
103 break;
104 default:
105 return(i);
106 }
107 break;
108
109 case 'i': /* iterate */
110 checkarg(2,1);
111 while (icnt-- > 0) {
112 multmat4(ret->xfm, ret->xfm, xfmat);
113 ret->sca *= xfsca;
114 }
115 icnt = atoi(av[++i]);
116 setident4(xfmat);
117 xfsca = 1.0;
118 continue;
119
120 default:
121 return(i);
122
123 }
124 multmat4(xfmat, xfmat, m4);
125 }
126 done:
127 while (icnt-- > 0) {
128 multmat4(ret->xfm, ret->xfm, xfmat);
129 ret->sca *= xfsca;
130 }
131 return(i);
132 }
133
134
135 int
136 invxf(ret, ac, av) /* invert transform specification */
137 register XF *ret;
138 int ac;
139 char *av[];
140 {
141 double atof(), sin(), cos();
142 double xfmat[4][4], m4[4][4];
143 double xfsca, dtmp;
144 int i, icnt;
145
146 setident4(ret->xfm);
147 ret->sca = 1.0;
148
149 icnt = 1;
150 setident4(xfmat);
151 xfsca = 1.0;
152
153 for (i = 0; i < ac && av[i][0] == '-'; i++) {
154
155 setident4(m4);
156
157 switch (av[i][1]) {
158
159 case 't': /* translate */
160 checkarg(2,3);
161 m4[3][0] = -atof(av[++i]);
162 m4[3][1] = -atof(av[++i]);
163 m4[3][2] = -atof(av[++i]);
164 break;
165
166 case 'r': /* rotate */
167 switch (av[i][2]) {
168 case 'x':
169 checkarg(3,1);
170 dtmp = -d2r(atof(av[++i]));
171 m4[1][1] = m4[2][2] = cos(dtmp);
172 m4[2][1] = -(m4[1][2] = sin(dtmp));
173 break;
174 case 'y':
175 checkarg(3,1);
176 dtmp = -d2r(atof(av[++i]));
177 m4[0][0] = m4[2][2] = cos(dtmp);
178 m4[0][2] = -(m4[2][0] = sin(dtmp));
179 break;
180 case 'z':
181 checkarg(3,1);
182 dtmp = -d2r(atof(av[++i]));
183 m4[0][0] = m4[1][1] = cos(dtmp);
184 m4[1][0] = -(m4[0][1] = sin(dtmp));
185 break;
186 default:
187 return(i);
188 }
189 break;
190
191 case 's': /* scale */
192 checkarg(2,1);
193 dtmp = atof(av[i+1]);
194 if (dtmp == 0.0) goto done;
195 i++;
196 xfsca *=
197 m4[0][0] =
198 m4[1][1] =
199 m4[2][2] = 1.0 / dtmp;
200 break;
201
202 case 'm': /* mirror */
203 switch (av[i][2]) {
204 case 'x':
205 checkarg(3,0);
206 xfsca *=
207 m4[0][0] = -1.0;
208 break;
209 case 'y':
210 checkarg(3,0);
211 xfsca *=
212 m4[1][1] = -1.0;
213 break;
214 case 'z':
215 checkarg(3,0);
216 xfsca *=
217 m4[2][2] = -1.0;
218 break;
219 default:
220 return(i);
221 }
222 break;
223
224 case 'i': /* iterate */
225 checkarg(2,1);
226 while (icnt-- > 0) {
227 multmat4(ret->xfm, xfmat, ret->xfm);
228 ret->sca *= xfsca;
229 }
230 icnt = atoi(av[++i]);
231 setident4(xfmat);
232 xfsca = 1.0;
233 break;
234
235 default:
236 return(i);
237
238 }
239 multmat4(xfmat, m4, xfmat); /* left multiply */
240 }
241 done:
242 while (icnt-- > 0) {
243 multmat4(ret->xfm, xfmat, ret->xfm);
244 ret->sca *= xfsca;
245 }
246 return(i);
247 }
248
249
250 int
251 fullxf(fx, ac, av) /* compute both forward and inverse */
252 FULLXF *fx;
253 int ac;
254 char *av[];
255 {
256 xf(&fx->f, ac, av);
257 return(invxf(&fx->b, ac, av));
258 }
