--- ray/src/common/xf.c 1989/02/02 10:34:41 1.1 +++ ray/src/common/xf.c 1990/02/20 18:02:30 1.8 @@ -12,20 +12,30 @@ static char SCCSid[] = "$SunId$ LBL"; #define PI 3.14159265358979323846 +#define d2r(a) ((PI/180.)*(a)) +#define checkarg(a,n) if (av[i][a] || i+n >= ac) goto done + int -xf(xfmat, xfsca, ac, av) /* get transform specification */ -double xfmat[4][4]; -double *xfsca; +xf(retmat, retsca, ac, av) /* get transform specification */ +double retmat[4][4]; +double *retsca; int ac; char *av[]; { double atof(), sin(), cos(); - double m4[4][4]; - double theta; - int i; + double xfmat[4][4], m4[4][4]; + double xfsca, dtmp; + int i, icnt; + setident4(retmat); + *retsca = 1.0; + + icnt = 1; + setident4(xfmat); + xfsca = 1.0; + for (i = 0; i < ac && av[i][0] == '-'; i++) { setident4(m4); @@ -33,6 +43,7 @@ char *av[]; switch (av[i][1]) { case 't': /* translate */ + checkarg(2,3); m4[3][0] = atof(av[++i]); m4[3][1] = atof(av[++i]); m4[3][2] = atof(av[++i]); @@ -41,19 +52,22 @@ char *av[]; case 'r': /* rotate */ switch (av[i][2]) { case 'x': - theta = PI/180.0 * atof(av[++i]); - m4[1][1] = m4[2][2] = cos(theta); - m4[2][1] = -(m4[1][2] = sin(theta)); + checkarg(3,1); + dtmp = d2r(atof(av[++i])); + m4[1][1] = m4[2][2] = cos(dtmp); + m4[2][1] = -(m4[1][2] = sin(dtmp)); break; case 'y': - theta = PI/180 * atof(av[++i]); - m4[0][0] = m4[2][2] = cos(theta); - m4[0][2] = -(m4[2][0] = sin(theta)); + checkarg(3,1); + dtmp = d2r(atof(av[++i])); + m4[0][0] = m4[2][2] = cos(dtmp); + m4[0][2] = -(m4[2][0] = sin(dtmp)); break; case 'z': - theta = PI/180 * atof(av[++i]); - m4[0][0] = m4[1][1] = cos(theta); - m4[1][0] = -(m4[0][1] = sin(theta)); + checkarg(3,1); + dtmp = d2r(atof(av[++i])); + m4[0][0] = m4[1][1] = cos(dtmp); + m4[1][0] = -(m4[0][1] = sin(dtmp)); break; default: return(i); @@ -61,24 +75,31 @@ char *av[]; break; case 's': /* scale */ - *xfsca *= + checkarg(2,1); + dtmp = atof(av[i+1]); + if (dtmp == 0.0) goto done; + i++; + xfsca *= m4[0][0] = m4[1][1] = - m4[2][2] = atof(av[++i]); + m4[2][2] = dtmp; break; case 'm': /* mirror */ switch (av[i][2]) { case 'x': - *xfsca *= + checkarg(3,0); + xfsca *= m4[0][0] = -1.0; break; case 'y': - *xfsca *= + checkarg(3,0); + xfsca *= m4[1][1] = -1.0; break; case 'z': - *xfsca *= + checkarg(3,0); + xfsca *= m4[2][2] = -1.0; break; default: @@ -86,29 +107,52 @@ char *av[]; } break; + case 'i': /* iterate */ + checkarg(2,1); + while (icnt-- > 0) { + multmat4(retmat, retmat, xfmat); + *retsca *= xfsca; + } + icnt = atoi(av[++i]); + setident4(xfmat); + xfsca = 1.0; + continue; + default: return(i); } multmat4(xfmat, xfmat, m4); } +done: + while (icnt-- > 0) { + multmat4(retmat, retmat, xfmat); + *retsca *= xfsca; + } return(i); } #ifdef INVXF int -invxf(xfmat, xfsca, ac, av) /* invert transform specification */ -double xfmat[4][4]; -double *xfsca; +invxf(retmat, retsca, ac, av) /* invert transform specification */ +double retmat[4][4]; +double *retsca; int ac; char *av[]; { double atof(), sin(), cos(); - double m4[4][4]; - double theta; - int i; + double xfmat[4][4], m4[4][4]; + double xfsca, dtmp; + int i, icnt; + setident4(retmat); + *retsca = 1.0; + + icnt = 1; + setident4(xfmat); + xfsca = 1.0; + for (i = 0; i < ac && av[i][0] == '-'; i++) { setident4(m4); @@ -116,6 +160,7 @@ char *av[]; switch (av[i][1]) { case 't': /* translate */ + checkarg(2,3); m4[3][0] = -atof(av[++i]); m4[3][1] = -atof(av[++i]); m4[3][2] = -atof(av[++i]); @@ -124,19 +169,22 @@ char *av[]; case 'r': /* rotate */ switch (av[i][2]) { case 'x': - theta = -PI/180.0 * atof(av[++i]); - m4[1][1] = m4[2][2] = cos(theta); - m4[2][1] = -(m4[1][2] = sin(theta)); + checkarg(3,1); + dtmp = -d2r(atof(av[++i])); + m4[1][1] = m4[2][2] = cos(dtmp); + m4[2][1] = -(m4[1][2] = sin(dtmp)); break; case 'y': - theta = -PI/180.0 * atof(av[++i]); - m4[0][0] = m4[2][2] = cos(theta); - m4[0][2] = -(m4[2][0] = sin(theta)); + checkarg(3,1); + dtmp = -d2r(atof(av[++i])); + m4[0][0] = m4[2][2] = cos(dtmp); + m4[0][2] = -(m4[2][0] = sin(dtmp)); break; case 'z': - theta = -PI/180.0 * atof(av[++i]); - m4[0][0] = m4[1][1] = cos(theta); - m4[1][0] = -(m4[0][1] = sin(theta)); + checkarg(3,1); + dtmp = -d2r(atof(av[++i])); + m4[0][0] = m4[1][1] = cos(dtmp); + m4[1][0] = -(m4[0][1] = sin(dtmp)); break; default: return(i); @@ -144,24 +192,31 @@ char *av[]; break; case 's': /* scale */ - *xfsca *= + checkarg(2,1); + dtmp = atof(av[i+1]); + if (dtmp == 0.0) goto done; + i++; + xfsca *= m4[0][0] = m4[1][1] = - m4[2][2] = 1.0 / atof(av[++i]); + m4[2][2] = 1.0 / dtmp; break; case 'm': /* mirror */ switch (av[i][2]) { case 'x': - *xfsca *= + checkarg(3,0); + xfsca *= m4[0][0] = -1.0; break; case 'y': - *xfsca *= + checkarg(3,0); + xfsca *= m4[1][1] = -1.0; break; case 'z': - *xfsca *= + checkarg(3,0); + xfsca *= m4[2][2] = -1.0; break; default: @@ -169,11 +224,27 @@ char *av[]; } break; + case 'i': /* iterate */ + checkarg(2,1); + while (icnt-- > 0) { + multmat4(retmat, xfmat, retmat); + *retsca *= xfsca; + } + icnt = atoi(av[++i]); + setident4(xfmat); + xfsca = 1.0; + break; + default: return(i); } multmat4(xfmat, m4, xfmat); /* left multiply */ + } +done: + while (icnt-- > 0) { + multmat4(retmat, xfmat, retmat); + *retsca *= xfsca; } return(i); }
