--- ray/src/common/xf.c 1989/10/05 07:54:31 1.4 +++ ray/src/common/xf.c 2003/02/22 02:07:23 2.4 @@ -1,38 +1,90 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: xf.c,v 2.4 2003/02/22 02:07:23 greg Exp $"; #endif - /* * xf.c - routines to convert transform arguments into 4X4 matrix. * - * 1/28/86 + * External symbols declared in standard.h */ +/* ==================================================================== + * The Radiance Software License, Version 1.0 + * + * Copyright (c) 1990 - 2002 The Regents of the University of California, + * through Lawrence Berkeley National Laboratory. All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * + * 3. The end-user documentation included with the redistribution, + * if any, must include the following acknowledgment: + * "This product includes Radiance software + * (http://radsite.lbl.gov/) + * developed by the Lawrence Berkeley National Laboratory + * (http://www.lbl.gov/)." + * Alternately, this acknowledgment may appear in the software itself, + * if and wherever such third-party acknowledgments normally appear. + * + * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" + * and "The Regents of the University of California" must + * not be used to endorse or promote products derived from this + * software without prior written permission. For written + * permission, please contact radiance@radsite.lbl.gov. + * + * 5. Products derived from this software may not be called "Radiance", + * nor may "Radiance" appear in their name, without prior written + * permission of Lawrence Berkeley National Laboratory. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR + * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * ==================================================================== + * + * This software consists of voluntary contributions made by many + * individuals on behalf of Lawrence Berkeley National Laboratory. For more + * information on Lawrence Berkeley National Laboratory, please see + * . + */ -#define PI 3.14159265358979323846 +#include "standard.h" -#define checkarg(a,n) if (strcmp(av[i],a) || i+n >= ac) goto done +#define d2r(a) ((PI/180.)*(a)) +#define checkarg(a,l) if (av[i][a] || badarg(ac-i-1,av+i+1,l)) goto done + int -xf(retmat, retsca, ac, av) /* get transform specification */ -double retmat[4][4]; -double *retsca; +xf(ret, ac, av) /* get transform specification */ +register XF *ret; int ac; char *av[]; { - double atof(), sin(), cos(); - double xfmat[4][4], m4[4][4]; - double xfsca, theta; - int i, j; - int rept; + MAT4 xfmat, m4; + double xfsca, dtmp; + int i, icnt; - setident4(retmat); - *retsca = 1.0; + setident4(ret->xfm); + ret->sca = 1.0; - rept = 1; + icnt = 1; setident4(xfmat); xfsca = 1.0; @@ -43,7 +95,7 @@ char *av[]; switch (av[i][1]) { case 't': /* translate */ - checkarg("-t",3); + checkarg(2,"fff"); m4[3][0] = atof(av[++i]); m4[3][1] = atof(av[++i]); m4[3][2] = atof(av[++i]); @@ -52,102 +104,101 @@ char *av[]; case 'r': /* rotate */ switch (av[i][2]) { case 'x': - checkarg("-rx",1); - theta = PI/180.0 * atof(av[++i]); - m4[1][1] = m4[2][2] = cos(theta); - m4[2][1] = -(m4[1][2] = sin(theta)); + checkarg(3,"f"); + dtmp = d2r(atof(av[++i])); + m4[1][1] = m4[2][2] = cos(dtmp); + m4[2][1] = -(m4[1][2] = sin(dtmp)); break; case 'y': - checkarg("-ry",1); - theta = PI/180.0 * atof(av[++i]); - m4[0][0] = m4[2][2] = cos(theta); - m4[0][2] = -(m4[2][0] = sin(theta)); + checkarg(3,"f"); + dtmp = d2r(atof(av[++i])); + m4[0][0] = m4[2][2] = cos(dtmp); + m4[0][2] = -(m4[2][0] = sin(dtmp)); break; case 'z': - checkarg("-rz",1); - theta = PI/180.0 * atof(av[++i]); - m4[0][0] = m4[1][1] = cos(theta); - m4[1][0] = -(m4[0][1] = sin(theta)); + checkarg(3,"f"); + dtmp = d2r(atof(av[++i])); + m4[0][0] = m4[1][1] = cos(dtmp); + m4[1][0] = -(m4[0][1] = sin(dtmp)); break; default: - return(i); + goto done; } break; case 's': /* scale */ - checkarg("-s",1); + checkarg(2,"f"); + dtmp = atof(av[i+1]); + if (dtmp == 0.0) goto done; + i++; xfsca *= m4[0][0] = m4[1][1] = - m4[2][2] = atof(av[++i]); + m4[2][2] = dtmp; break; case 'm': /* mirror */ switch (av[i][2]) { case 'x': - checkarg("-mx",0); + checkarg(3,""); xfsca *= m4[0][0] = -1.0; break; case 'y': - checkarg("-my",0); + checkarg(3,""); xfsca *= m4[1][1] = -1.0; break; case 'z': - checkarg("-mz",0); + checkarg(3,""); xfsca *= m4[2][2] = -1.0; break; default: - return(i); + goto done; } break; case 'i': /* iterate */ - checkarg("-i",1); - for (j = 0; j < rept; j++) { - multmat4(retmat, retmat, xfmat); - *retsca *= xfsca; + checkarg(2,"i"); + while (icnt-- > 0) { + multmat4(ret->xfm, ret->xfm, xfmat); + ret->sca *= xfsca; } - rept = atoi(av[++i]); + icnt = atoi(av[++i]); setident4(xfmat); xfsca = 1.0; - break; + continue; default: - return(i); + goto done; } multmat4(xfmat, xfmat, m4); } done: - for (j = 0; j < rept; j++) { - multmat4(retmat, retmat, xfmat); - *retsca *= xfsca; + while (icnt-- > 0) { + multmat4(ret->xfm, ret->xfm, xfmat); + ret->sca *= xfsca; } return(i); } -#ifdef INVXF int -invxf(retmat, retsca, ac, av) /* invert transform specification */ -double retmat[4][4]; -double *retsca; +invxf(ret, ac, av) /* invert transform specification */ +register XF *ret; int ac; char *av[]; { - double atof(), sin(), cos(); - double xfmat[4][4], m4[4][4]; - double xfsca, theta; - int i, j; - int rept; + MAT4 xfmat, m4; + double xfsca, dtmp; + int i, icnt; - setident4(retmat); - *retsca = 1.0; + setident4(ret->xfm); + ret->sca = 1.0; - rept = 1; + icnt = 1; setident4(xfmat); xfsca = 1.0; @@ -158,7 +209,7 @@ char *av[]; switch (av[i][1]) { case 't': /* translate */ - checkarg("-t",3); + checkarg(2,"fff"); m4[3][0] = -atof(av[++i]); m4[3][1] = -atof(av[++i]); m4[3][2] = -atof(av[++i]); @@ -167,80 +218,93 @@ char *av[]; case 'r': /* rotate */ switch (av[i][2]) { case 'x': - checkarg("-rx",1); - theta = -PI/180.0 * atof(av[++i]); - m4[1][1] = m4[2][2] = cos(theta); - m4[2][1] = -(m4[1][2] = sin(theta)); + checkarg(3,"f"); + dtmp = -d2r(atof(av[++i])); + m4[1][1] = m4[2][2] = cos(dtmp); + m4[2][1] = -(m4[1][2] = sin(dtmp)); break; case 'y': - checkarg("-ry",1); - theta = -PI/180.0 * atof(av[++i]); - m4[0][0] = m4[2][2] = cos(theta); - m4[0][2] = -(m4[2][0] = sin(theta)); + checkarg(3,"f"); + dtmp = -d2r(atof(av[++i])); + m4[0][0] = m4[2][2] = cos(dtmp); + m4[0][2] = -(m4[2][0] = sin(dtmp)); break; case 'z': - checkarg("-rz",1); - theta = -PI/180.0 * atof(av[++i]); - m4[0][0] = m4[1][1] = cos(theta); - m4[1][0] = -(m4[0][1] = sin(theta)); + checkarg(3,"f"); + dtmp = -d2r(atof(av[++i])); + m4[0][0] = m4[1][1] = cos(dtmp); + m4[1][0] = -(m4[0][1] = sin(dtmp)); break; default: - return(i); + goto done; } break; case 's': /* scale */ - checkarg("-s",1); - *xfsca *= + checkarg(2,"f"); + dtmp = atof(av[i+1]); + if (dtmp == 0.0) goto done; + i++; + xfsca *= m4[0][0] = m4[1][1] = - m4[2][2] = 1.0 / atof(av[++i]); + m4[2][2] = 1.0 / dtmp; break; case 'm': /* mirror */ switch (av[i][2]) { case 'x': - checkarg("-mx",0); - *xfsca *= + checkarg(3,""); + xfsca *= m4[0][0] = -1.0; break; case 'y': - checkarg("-my",0); - *xfsca *= + checkarg(3,""); + xfsca *= m4[1][1] = -1.0; break; case 'z': - checkarg("-mz",0); - *xfsca *= + checkarg(3,""); + xfsca *= m4[2][2] = -1.0; break; default: - return(i); + goto done; } break; case 'i': /* iterate */ - checkarg("-i",1); - for (j = 0; j < rept; j++) { - multmat4(retmat, xfmat, retmat); - *retsca *= xfsca; + checkarg(2,"i"); + while (icnt-- > 0) { + multmat4(ret->xfm, xfmat, ret->xfm); + ret->sca *= xfsca; } - rept = atoi(av[++i]); + icnt = atoi(av[++i]); setident4(xfmat); xfsca = 1.0; break; default: - return(i); + goto done; } multmat4(xfmat, m4, xfmat); /* left multiply */ } done: - for (j = 0; j < rept; j++) { - multmat4(retmat, xfmat, retmat); - *retsca *= xfsca; + while (icnt-- > 0) { + multmat4(ret->xfm, xfmat, ret->xfm); + ret->sca *= xfsca; } return(i); } -#endif + + +int +fullxf(fx, ac, av) /* compute both forward and inverse */ +FULLXF *fx; +int ac; +char *av[]; +{ + xf(&fx->f, ac, av); + return(invxf(&fx->b, ac, av)); +}
