root/radiance/ray/src/common/xf.c
Revision: 2.3
Committed: Tue Dec 24 17:42:48 1991 UTC (33 years, 4 months ago) by greg
Changes since 2.2: +7 -7 lines
changed the error returns
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * xf.c - routines to convert transform arguments into 4X4 matrix.
9 *
10 * 1/28/86
11 */
12
13 #include "standard.h"
14
15 #define d2r(a) ((PI/180.)*(a))
16
17 #define checkarg(a,l) if (av[i][a] || badarg(ac-i-1,av+i+1,l)) goto done
18
19
20 int
21 xf(ret, ac, av) /* get transform specification */
22 register XF *ret;
23 int ac;
24 char *av[];
25 {
26 MAT4 xfmat, m4;
27 double xfsca, dtmp;
28 int i, icnt;
29
30 setident4(ret->xfm);
31 ret->sca = 1.0;
32
33 icnt = 1;
34 setident4(xfmat);
35 xfsca = 1.0;
36
37 for (i = 0; i < ac && av[i][0] == '-'; i++) {
38
39 setident4(m4);
40
41 switch (av[i][1]) {
42
43 case 't': /* translate */
44 checkarg(2,"fff");
45 m4[3][0] = atof(av[++i]);
46 m4[3][1] = atof(av[++i]);
47 m4[3][2] = atof(av[++i]);
48 break;
49
50 case 'r': /* rotate */
51 switch (av[i][2]) {
52 case 'x':
53 checkarg(3,"f");
54 dtmp = d2r(atof(av[++i]));
55 m4[1][1] = m4[2][2] = cos(dtmp);
56 m4[2][1] = -(m4[1][2] = sin(dtmp));
57 break;
58 case 'y':
59 checkarg(3,"f");
60 dtmp = d2r(atof(av[++i]));
61 m4[0][0] = m4[2][2] = cos(dtmp);
62 m4[0][2] = -(m4[2][0] = sin(dtmp));
63 break;
64 case 'z':
65 checkarg(3,"f");
66 dtmp = d2r(atof(av[++i]));
67 m4[0][0] = m4[1][1] = cos(dtmp);
68 m4[1][0] = -(m4[0][1] = sin(dtmp));
69 break;
70 default:
71 goto done;
72 }
73 break;
74
75 case 's': /* scale */
76 checkarg(2,"f");
77 dtmp = atof(av[i+1]);
78 if (dtmp == 0.0) goto done;
79 i++;
80 xfsca *=
81 m4[0][0] =
82 m4[1][1] =
83 m4[2][2] = dtmp;
84 break;
85
86 case 'm': /* mirror */
87 switch (av[i][2]) {
88 case 'x':
89 checkarg(3,"");
90 xfsca *=
91 m4[0][0] = -1.0;
92 break;
93 case 'y':
94 checkarg(3,"");
95 xfsca *=
96 m4[1][1] = -1.0;
97 break;
98 case 'z':
99 checkarg(3,"");
100 xfsca *=
101 m4[2][2] = -1.0;
102 break;
103 default:
104 goto done;
105 }
106 break;
107
108 case 'i': /* iterate */
109 checkarg(2,"i");
110 while (icnt-- > 0) {
111 multmat4(ret->xfm, ret->xfm, xfmat);
112 ret->sca *= xfsca;
113 }
114 icnt = atoi(av[++i]);
115 setident4(xfmat);
116 xfsca = 1.0;
117 continue;
118
119 default:
120 goto done;
121
122 }
123 multmat4(xfmat, xfmat, m4);
124 }
125 done:
126 while (icnt-- > 0) {
127 multmat4(ret->xfm, ret->xfm, xfmat);
128 ret->sca *= xfsca;
129 }
130 return(i);
131 }
132
133
134 int
135 invxf(ret, ac, av) /* invert transform specification */
136 register XF *ret;
137 int ac;
138 char *av[];
139 {
140 MAT4 xfmat, m4;
141 double xfsca, dtmp;
142 int i, icnt;
143
144 setident4(ret->xfm);
145 ret->sca = 1.0;
146
147 icnt = 1;
148 setident4(xfmat);
149 xfsca = 1.0;
150
151 for (i = 0; i < ac && av[i][0] == '-'; i++) {
152
153 setident4(m4);
154
155 switch (av[i][1]) {
156
157 case 't': /* translate */
158 checkarg(2,"fff");
159 m4[3][0] = -atof(av[++i]);
160 m4[3][1] = -atof(av[++i]);
161 m4[3][2] = -atof(av[++i]);
162 break;
163
164 case 'r': /* rotate */
165 switch (av[i][2]) {
166 case 'x':
167 checkarg(3,"f");
168 dtmp = -d2r(atof(av[++i]));
169 m4[1][1] = m4[2][2] = cos(dtmp);
170 m4[2][1] = -(m4[1][2] = sin(dtmp));
171 break;
172 case 'y':
173 checkarg(3,"f");
174 dtmp = -d2r(atof(av[++i]));
175 m4[0][0] = m4[2][2] = cos(dtmp);
176 m4[0][2] = -(m4[2][0] = sin(dtmp));
177 break;
178 case 'z':
179 checkarg(3,"f");
180 dtmp = -d2r(atof(av[++i]));
181 m4[0][0] = m4[1][1] = cos(dtmp);
182 m4[1][0] = -(m4[0][1] = sin(dtmp));
183 break;
184 default:
185 goto done;
186 }
187 break;
188
189 case 's': /* scale */
190 checkarg(2,"f");
191 dtmp = atof(av[i+1]);
192 if (dtmp == 0.0) goto done;
193 i++;
194 xfsca *=
195 m4[0][0] =
196 m4[1][1] =
197 m4[2][2] = 1.0 / dtmp;
198 break;
199
200 case 'm': /* mirror */
201 switch (av[i][2]) {
202 case 'x':
203 checkarg(3,"");
204 xfsca *=
205 m4[0][0] = -1.0;
206 break;
207 case 'y':
208 checkarg(3,"");
209 xfsca *=
210 m4[1][1] = -1.0;
211 break;
212 case 'z':
213 checkarg(3,"");
214 xfsca *=
215 m4[2][2] = -1.0;
216 break;
217 default:
218 goto done;
219 }
220 break;
221
222 case 'i': /* iterate */
223 checkarg(2,"i");
224 while (icnt-- > 0) {
225 multmat4(ret->xfm, xfmat, ret->xfm);
226 ret->sca *= xfsca;
227 }
228 icnt = atoi(av[++i]);
229 setident4(xfmat);
230 xfsca = 1.0;
231 break;
232
233 default:
234 goto done;
235
236 }
237 multmat4(xfmat, m4, xfmat); /* left multiply */
238 }
239 done:
240 while (icnt-- > 0) {
241 multmat4(ret->xfm, xfmat, ret->xfm);
242 ret->sca *= xfsca;
243 }
244 return(i);
245 }
246
247
248 int
249 fullxf(fx, ac, av) /* compute both forward and inverse */
250 FULLXF *fx;
251 int ac;
252 char *av[];
253 {
254 xf(&fx->f, ac, av);
255 return(invxf(&fx->b, ac, av));
256 }
