--- ray/src/common/xf.c 1990/02/20 18:02:30 1.8 +++ ray/src/common/xf.c 1991/12/19 14:45:41 2.2 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1990 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -10,27 +10,25 @@ static char SCCSid[] = "$SunId$ LBL"; * 1/28/86 */ +#include "standard.h" -#define PI 3.14159265358979323846 #define d2r(a) ((PI/180.)*(a)) -#define checkarg(a,n) if (av[i][a] || i+n >= ac) goto done +#define checkarg(a,l) if (av[i][a] || badarg(ac-i-1,av+i+1,l)) goto done int -xf(retmat, retsca, ac, av) /* get transform specification */ -double retmat[4][4]; -double *retsca; +xf(ret, ac, av) /* get transform specification */ +register XF *ret; int ac; char *av[]; { - double atof(), sin(), cos(); - double xfmat[4][4], m4[4][4]; + MAT4 xfmat, m4; double xfsca, dtmp; int i, icnt; - setident4(retmat); - *retsca = 1.0; + setident4(ret->xfm); + ret->sca = 1.0; icnt = 1; setident4(xfmat); @@ -43,7 +41,7 @@ char *av[]; switch (av[i][1]) { case 't': /* translate */ - checkarg(2,3); + checkarg(2,"fff"); m4[3][0] = atof(av[++i]); m4[3][1] = atof(av[++i]); m4[3][2] = atof(av[++i]); @@ -52,19 +50,19 @@ char *av[]; case 'r': /* rotate */ switch (av[i][2]) { case 'x': - checkarg(3,1); + checkarg(3,"f"); dtmp = d2r(atof(av[++i])); m4[1][1] = m4[2][2] = cos(dtmp); m4[2][1] = -(m4[1][2] = sin(dtmp)); break; case 'y': - checkarg(3,1); + checkarg(3,"f"); dtmp = d2r(atof(av[++i])); m4[0][0] = m4[2][2] = cos(dtmp); m4[0][2] = -(m4[2][0] = sin(dtmp)); break; case 'z': - checkarg(3,1); + checkarg(3,"f"); dtmp = d2r(atof(av[++i])); m4[0][0] = m4[1][1] = cos(dtmp); m4[1][0] = -(m4[0][1] = sin(dtmp)); @@ -75,7 +73,7 @@ char *av[]; break; case 's': /* scale */ - checkarg(2,1); + checkarg(2,"f"); dtmp = atof(av[i+1]); if (dtmp == 0.0) goto done; i++; @@ -88,17 +86,17 @@ char *av[]; case 'm': /* mirror */ switch (av[i][2]) { case 'x': - checkarg(3,0); + checkarg(3,""); xfsca *= m4[0][0] = -1.0; break; case 'y': - checkarg(3,0); + checkarg(3,""); xfsca *= m4[1][1] = -1.0; break; case 'z': - checkarg(3,0); + checkarg(3,""); xfsca *= m4[2][2] = -1.0; break; @@ -108,10 +106,10 @@ char *av[]; break; case 'i': /* iterate */ - checkarg(2,1); + checkarg(2,"i"); while (icnt-- > 0) { - multmat4(retmat, retmat, xfmat); - *retsca *= xfsca; + multmat4(ret->xfm, ret->xfm, xfmat); + ret->sca *= xfsca; } icnt = atoi(av[++i]); setident4(xfmat); @@ -126,28 +124,25 @@ char *av[]; } done: while (icnt-- > 0) { - multmat4(retmat, retmat, xfmat); - *retsca *= xfsca; + multmat4(ret->xfm, ret->xfm, xfmat); + ret->sca *= xfsca; } return(i); } -#ifdef INVXF int -invxf(retmat, retsca, ac, av) /* invert transform specification */ -double retmat[4][4]; -double *retsca; +invxf(ret, ac, av) /* invert transform specification */ +register XF *ret; int ac; char *av[]; { - double atof(), sin(), cos(); - double xfmat[4][4], m4[4][4]; + MAT4 xfmat, m4; double xfsca, dtmp; int i, icnt; - setident4(retmat); - *retsca = 1.0; + setident4(ret->xfm); + ret->sca = 1.0; icnt = 1; setident4(xfmat); @@ -160,7 +155,7 @@ char *av[]; switch (av[i][1]) { case 't': /* translate */ - checkarg(2,3); + checkarg(2,"fff"); m4[3][0] = -atof(av[++i]); m4[3][1] = -atof(av[++i]); m4[3][2] = -atof(av[++i]); @@ -169,19 +164,19 @@ char *av[]; case 'r': /* rotate */ switch (av[i][2]) { case 'x': - checkarg(3,1); + checkarg(3,"f"); dtmp = -d2r(atof(av[++i])); m4[1][1] = m4[2][2] = cos(dtmp); m4[2][1] = -(m4[1][2] = sin(dtmp)); break; case 'y': - checkarg(3,1); + checkarg(3,"f"); dtmp = -d2r(atof(av[++i])); m4[0][0] = m4[2][2] = cos(dtmp); m4[0][2] = -(m4[2][0] = sin(dtmp)); break; case 'z': - checkarg(3,1); + checkarg(3,"f"); dtmp = -d2r(atof(av[++i])); m4[0][0] = m4[1][1] = cos(dtmp); m4[1][0] = -(m4[0][1] = sin(dtmp)); @@ -192,7 +187,7 @@ char *av[]; break; case 's': /* scale */ - checkarg(2,1); + checkarg(2,"f"); dtmp = atof(av[i+1]); if (dtmp == 0.0) goto done; i++; @@ -205,17 +200,17 @@ char *av[]; case 'm': /* mirror */ switch (av[i][2]) { case 'x': - checkarg(3,0); + checkarg(3,""); xfsca *= m4[0][0] = -1.0; break; case 'y': - checkarg(3,0); + checkarg(3,""); xfsca *= m4[1][1] = -1.0; break; case 'z': - checkarg(3,0); + checkarg(3,""); xfsca *= m4[2][2] = -1.0; break; @@ -225,10 +220,10 @@ char *av[]; break; case 'i': /* iterate */ - checkarg(2,1); + checkarg(2,"i"); while (icnt-- > 0) { - multmat4(retmat, xfmat, retmat); - *retsca *= xfsca; + multmat4(ret->xfm, xfmat, ret->xfm); + ret->sca *= xfsca; } icnt = atoi(av[++i]); setident4(xfmat); @@ -243,9 +238,19 @@ char *av[]; } done: while (icnt-- > 0) { - multmat4(retmat, xfmat, retmat); - *retsca *= xfsca; + multmat4(ret->xfm, xfmat, ret->xfm); + ret->sca *= xfsca; } return(i); } -#endif + + +int +fullxf(fx, ac, av) /* compute both forward and inverse */ +FULLXF *fx; +int ac; +char *av[]; +{ + xf(&fx->f, ac, av); + return(invxf(&fx->b, ac, av)); +}
