--- ray/src/common/xf.c 1989/02/02 10:34:41 1.1 +++ ray/src/common/xf.c 2003/06/27 06:53:22 2.6 @@ -1,31 +1,37 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: xf.c,v 2.6 2003/06/27 06:53:22 greg Exp $"; #endif - /* * xf.c - routines to convert transform arguments into 4X4 matrix. * - * 1/28/86 + * External symbols declared in rtmath.h */ +#include "rtmath.h" +#include "rtio.h" -#define PI 3.14159265358979323846 +#define d2r(a) ((PI/180.)*(a)) +#define checkarg(a,l) if (av[i][a] || badarg(ac-i-1,av+i+1,l)) goto done + int -xf(xfmat, xfsca, ac, av) /* get transform specification */ -double xfmat[4][4]; -double *xfsca; +xf(ret, ac, av) /* get transform specification */ +register XF *ret; int ac; char *av[]; { - double atof(), sin(), cos(); - double m4[4][4]; - double theta; - int i; + MAT4 xfmat, m4; + double xfsca, dtmp; + int i, icnt; + setident4(ret->xfm); + ret->sca = 1.0; + + icnt = 1; + setident4(xfmat); + xfsca = 1.0; + for (i = 0; i < ac && av[i][0] == '-'; i++) { setident4(m4); @@ -33,6 +39,7 @@ char *av[]; switch (av[i][1]) { case 't': /* translate */ + checkarg(2,"fff"); m4[3][0] = atof(av[++i]); m4[3][1] = atof(av[++i]); m4[3][2] = atof(av[++i]); @@ -41,74 +48,104 @@ char *av[]; case 'r': /* rotate */ switch (av[i][2]) { case 'x': - theta = PI/180.0 * atof(av[++i]); - m4[1][1] = m4[2][2] = cos(theta); - m4[2][1] = -(m4[1][2] = sin(theta)); + checkarg(3,"f"); + dtmp = d2r(atof(av[++i])); + m4[1][1] = m4[2][2] = cos(dtmp); + m4[2][1] = -(m4[1][2] = sin(dtmp)); break; case 'y': - theta = PI/180 * atof(av[++i]); - m4[0][0] = m4[2][2] = cos(theta); - m4[0][2] = -(m4[2][0] = sin(theta)); + checkarg(3,"f"); + dtmp = d2r(atof(av[++i])); + m4[0][0] = m4[2][2] = cos(dtmp); + m4[0][2] = -(m4[2][0] = sin(dtmp)); break; case 'z': - theta = PI/180 * atof(av[++i]); - m4[0][0] = m4[1][1] = cos(theta); - m4[1][0] = -(m4[0][1] = sin(theta)); + checkarg(3,"f"); + dtmp = d2r(atof(av[++i])); + m4[0][0] = m4[1][1] = cos(dtmp); + m4[1][0] = -(m4[0][1] = sin(dtmp)); break; default: - return(i); + goto done; } break; case 's': /* scale */ - *xfsca *= + checkarg(2,"f"); + dtmp = atof(av[i+1]); + if (dtmp == 0.0) goto done; + i++; + xfsca *= m4[0][0] = m4[1][1] = - m4[2][2] = atof(av[++i]); + m4[2][2] = dtmp; break; case 'm': /* mirror */ switch (av[i][2]) { case 'x': - *xfsca *= + checkarg(3,""); + xfsca *= m4[0][0] = -1.0; break; case 'y': - *xfsca *= + checkarg(3,""); + xfsca *= m4[1][1] = -1.0; break; case 'z': - *xfsca *= + checkarg(3,""); + xfsca *= m4[2][2] = -1.0; break; default: - return(i); + goto done; } break; + case 'i': /* iterate */ + checkarg(2,"i"); + while (icnt-- > 0) { + multmat4(ret->xfm, ret->xfm, xfmat); + ret->sca *= xfsca; + } + icnt = atoi(av[++i]); + setident4(xfmat); + xfsca = 1.0; + continue; + default: - return(i); + goto done; } multmat4(xfmat, xfmat, m4); } +done: + while (icnt-- > 0) { + multmat4(ret->xfm, ret->xfm, xfmat); + ret->sca *= xfsca; + } return(i); } -#ifdef INVXF int -invxf(xfmat, xfsca, ac, av) /* invert transform specification */ -double xfmat[4][4]; -double *xfsca; +invxf(ret, ac, av) /* invert transform specification */ +register XF *ret; int ac; char *av[]; { - double atof(), sin(), cos(); - double m4[4][4]; - double theta; - int i; + MAT4 xfmat, m4; + double xfsca, dtmp; + int i, icnt; + setident4(ret->xfm); + ret->sca = 1.0; + + icnt = 1; + setident4(xfmat); + xfsca = 1.0; + for (i = 0; i < ac && av[i][0] == '-'; i++) { setident4(m4); @@ -116,6 +153,7 @@ char *av[]; switch (av[i][1]) { case 't': /* translate */ + checkarg(2,"fff"); m4[3][0] = -atof(av[++i]); m4[3][1] = -atof(av[++i]); m4[3][2] = -atof(av[++i]); @@ -124,57 +162,93 @@ char *av[]; case 'r': /* rotate */ switch (av[i][2]) { case 'x': - theta = -PI/180.0 * atof(av[++i]); - m4[1][1] = m4[2][2] = cos(theta); - m4[2][1] = -(m4[1][2] = sin(theta)); + checkarg(3,"f"); + dtmp = -d2r(atof(av[++i])); + m4[1][1] = m4[2][2] = cos(dtmp); + m4[2][1] = -(m4[1][2] = sin(dtmp)); break; case 'y': - theta = -PI/180.0 * atof(av[++i]); - m4[0][0] = m4[2][2] = cos(theta); - m4[0][2] = -(m4[2][0] = sin(theta)); + checkarg(3,"f"); + dtmp = -d2r(atof(av[++i])); + m4[0][0] = m4[2][2] = cos(dtmp); + m4[0][2] = -(m4[2][0] = sin(dtmp)); break; case 'z': - theta = -PI/180.0 * atof(av[++i]); - m4[0][0] = m4[1][1] = cos(theta); - m4[1][0] = -(m4[0][1] = sin(theta)); + checkarg(3,"f"); + dtmp = -d2r(atof(av[++i])); + m4[0][0] = m4[1][1] = cos(dtmp); + m4[1][0] = -(m4[0][1] = sin(dtmp)); break; default: - return(i); + goto done; } break; case 's': /* scale */ - *xfsca *= + checkarg(2,"f"); + dtmp = atof(av[i+1]); + if (dtmp == 0.0) goto done; + i++; + xfsca *= m4[0][0] = m4[1][1] = - m4[2][2] = 1.0 / atof(av[++i]); + m4[2][2] = 1.0 / dtmp; break; case 'm': /* mirror */ switch (av[i][2]) { case 'x': - *xfsca *= + checkarg(3,""); + xfsca *= m4[0][0] = -1.0; break; case 'y': - *xfsca *= + checkarg(3,""); + xfsca *= m4[1][1] = -1.0; break; case 'z': - *xfsca *= + checkarg(3,""); + xfsca *= m4[2][2] = -1.0; break; default: - return(i); + goto done; } break; + case 'i': /* iterate */ + checkarg(2,"i"); + while (icnt-- > 0) { + multmat4(ret->xfm, xfmat, ret->xfm); + ret->sca *= xfsca; + } + icnt = atoi(av[++i]); + setident4(xfmat); + xfsca = 1.0; + break; + default: - return(i); + goto done; } multmat4(xfmat, m4, xfmat); /* left multiply */ } +done: + while (icnt-- > 0) { + multmat4(ret->xfm, xfmat, ret->xfm); + ret->sca *= xfsca; + } return(i); } -#endif + + +int +fullxf(fx, ac, av) /* compute both forward and inverse */ +FULLXF *fx; +int ac; +char *av[]; +{ + xf(&fx->f, ac, av); + return(invxf(&fx->b, ac, av)); +}
