root/radiance/ray/src/common/words.c
Revision: 2.4
Committed: Fri Jan 29 11:18:23 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 2.3: +28 -1 lines
added nextword() function for reading quoted strings
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for recognizing and moving about words in strings.
9 */
10
11 #include <ctype.h>
12
13 #ifdef BSD
14 #define strchr index
15 #endif
16
17 #define NULL 0
18
19 extern char *strchr();
20
21
22 char *
23 atos(rs, nb, s) /* get word from string, returning rs */
24 char *rs;
25 register int nb;
26 register char *s;
27 {
28 register char *cp = rs;
29
30 while (isspace(*s))
31 s++;
32 while (--nb > 0 && *s && !isspace(*s))
33 *cp++ = *s++;
34 *cp = '\0';
35 return(rs);
36 }
37
38
39 char *
40 nextword(cp, nb, s) /* get (quoted) word, returning new s */
41 register char *cp;
42 register int nb;
43 register char *s;
44 {
45 int quote = 0;
46
47 if (s == NULL) return(NULL);
48 while (isspace(*s))
49 s++;
50 switch (*s) {
51 case '\0':
52 return(NULL);
53 case '"':
54 case '\'':
55 quote = *s++;
56 }
57 while (--nb > 0 && *s && (quote ? *s!=quote : !isspace(*s)))
58 *cp++ = *s++;
59 *cp = '\0';
60 if (quote && *s==quote)
61 s++;
62 return(s);
63 }
64
65
66 char *
67 sskip(s) /* skip word in string, leaving on space */
68 register char *s;
69 {
70 while (isspace(*s))
71 s++;
72 while (*s && !isspace(*s))
73 s++;
74 return(s);
75 }
76
77
78 char *
79 sskip2(s, n) /* skip word(s) in string, leaving on word */
80 register char *s;
81 register int n;
82 {
83 while (isspace(*s))
84 s++;
85 while (n-- > 0) {
86 while (*s && !isspace(*s))
87 s++;
88 while (isspace(*s))
89 s++;
90 }
91 return(s);
92 }
93
94
95 char *
96 iskip(s) /* skip integer in string */
97 register char *s;
98 {
99 while (isspace(*s))
100 s++;
101 if (*s == '-' || *s == '+')
102 s++;
103 if (!isdigit(*s))
104 return(NULL);
105 do
106 s++;
107 while (isdigit(*s));
108 return(s);
109 }
110
111
112 char *
113 fskip(s) /* skip float in string */
114 register char *s;
115 {
116 register char *cp;
117
118 while (isspace(*s))
119 s++;
120 if (*s == '-' || *s == '+')
121 s++;
122 cp = s;
123 while (isdigit(*cp))
124 cp++;
125 if (*cp == '.') {
126 cp++; s++;
127 while (isdigit(*cp))
128 cp++;
129 }
130 if (cp == s)
131 return(NULL);
132 if (*cp == 'e' || *cp == 'E')
133 return(iskip(cp+1));
134 return(cp);
135 }
136
137
138 isint(s) /* check integer format */
139 char *s;
140 {
141 register char *cp;
142
143 cp = iskip(s);
144 return(cp != NULL && *cp == '\0');
145 }
146
147
148 isintd(s, ds) /* check integer format with delimiter set */
149 char *s, *ds;
150 {
151 register char *cp;
152
153 cp = iskip(s);
154 return(cp != NULL && strchr(ds, *cp) != NULL);
155 }
156
157
158 isflt(s) /* check float format */
159 char *s;
160 {
161 register char *cp;
162
163 cp = fskip(s);
164 return(cp != NULL && *cp == '\0');
165 }
166
167
168 isfltd(s, ds) /* check integer format with delimiter set */
169 char *s, *ds;
170 {
171 register char *cp;
172
173 cp = fskip(s);
174 return(cp != NULL && strchr(ds, *cp) != NULL);
175 }
