root/radiance/ray/src/common/words.c
Thu Apr 28 17:46:25 2011 UTC (13 years ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 2.10: +11 -11 lines
Diff to previous 2.10 , to selected 1.4
Minor fixes
Changes since 2.9: +24 -26 lines
Diff to previous 2.9 , to selected 1.4
Tue Sep 28 17:54:18 2004 UTC (19 years, 7 months ago) by greg
Diff to previous 2.8 , to selected 1.4
Diff to previous 2.7 , to selected 1.4
Mon Mar 10 17:26:26 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.6: +1 -5 lines
Diff to previous 2.6 , to selected 1.4
Compile fixes for Linux
Diff to previous 2.5 , to selected 1.4
Changes since 2.4: +65 -8 lines
Diff to previous 2.4 , to selected 1.4
Fri Jan 29 11:18:23 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 2.3: +28 -1 lines
Diff to previous 2.3 , to selected 1.4
added nextword() function for reading quoted strings
Wed Jan 17 10:53:38 1996 UTC (28 years, 4 months ago) by greg
Changes since 2.2: +16 -1 lines
Diff to previous 2.2 , to selected 1.4
replaced sskip() behavior and added new sskip2() function
Wed Jan 10 21:04:21 1996 UTC (28 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 1.4
improved sskip() behavior
Tue Nov 12 16:56:04 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.4
Revision 1.4 - (view) (download) (annotate) - [selected]
Tue Jul 30 13:47:29 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.3: +6 -6 lines
Diff to previous 1.3
*** empty log message ***
Thu Jul 25 14:36:49 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.2 , to selected 1.4
bug
Tue Jul 23 11:36:42 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.1: +37 -16 lines
Diff to previous 1.1 , to selected 1.4
added atos() function and made checking more robust
Mon Jul 22 14:34:27 1991 UTC (32 years, 10 months ago) by greg
Diff to selected 1.4
