root/radiance/ray/src/common/words.c
Revision: 2.8
Committed: Thu Jul 17 09:21:29 2003 UTC (21 years, 10 months ago) by schorsch
2 static const char RCSid[] = "$Id";
5 * Routines for recognizing and moving about words in strings.
6 *
7 * External symbols declared in standard.h
8 */
9
10 #include "copyright.h"
11
12 #include <ctype.h>
13 #include <string.h>
14
15 #include "rtio.h"
16
17 char *
18 atos(rs, nb, s) /* get word from string, returning rs */
19 char *rs;
20 register int nb;
21 register char *s;
22 {
23 register char *cp = rs;
24
25 while (isspace(*s))
26 s++;
27 while (--nb > 0 && *s && !isspace(*s))
28 *cp++ = *s++;
29 *cp = '\0';
30 return(rs);
31 }
32
33
34 char *
35 nextword(cp, nb, s) /* get (quoted) word, returning new s */
36 register char *cp;
37 register int nb;
38 register char *s;
39 {
40 int quote = 0;
41
42 if (s == NULL) return(NULL);
43 while (isspace(*s))
44 s++;
45 switch (*s) {
46 case '\0':
47 return(NULL);
48 case '"':
49 case '\'':
50 quote = *s++;
51 }
52 while (--nb > 0 && *s && (quote ? *s!=quote : !isspace(*s)))
53 *cp++ = *s++;
54 *cp = '\0';
55 if (quote && *s==quote)
56 s++;
57 return(s);
58 }
59
60
61 char *
62 sskip(s) /* skip word in string, leaving on space */
63 register char *s;
64 {
65 while (isspace(*s))
66 s++;
67 while (*s && !isspace(*s))
68 s++;
69 return(s);
70 }
71
72
73 char *
74 sskip2(s, n) /* skip word(s) in string, leaving on word */
75 register char *s;
76 register int n;
77 {
78 while (isspace(*s))
79 s++;
80 while (n-- > 0) {
81 while (*s && !isspace(*s))
82 s++;
83 while (isspace(*s))
84 s++;
85 }
86 return(s);
87 }
88
89
90 char *
91 iskip(s) /* skip integer in string */
92 register char *s;
93 {
94 while (isspace(*s))
95 s++;
96 if (*s == '-' || *s == '+')
97 s++;
98 if (!isdigit(*s))
99 return(NULL);
100 do
101 s++;
102 while (isdigit(*s));
103 return(s);
104 }
105
106
107 char *
108 fskip(s) /* skip float in string */
109 register char *s;
110 {
111 register char *cp;
112
113 while (isspace(*s))
114 s++;
115 if (*s == '-' || *s == '+')
116 s++;
117 cp = s;
118 while (isdigit(*cp))
119 cp++;
120 if (*cp == '.') {
121 cp++; s++;
122 while (isdigit(*cp))
123 cp++;
124 }
125 if (cp == s)
126 return(NULL);
127 if (*cp == 'e' || *cp == 'E')
128 return(iskip(cp+1));
129 return(cp);
130 }
131
132
133 int
134 isint(s) /* check integer format */
135 char *s;
136 {
137 register char *cp;
138
139 cp = iskip(s);
140 return(cp != NULL && *cp == '\0');
141 }
142
143
144 int
145 isintd(s, ds) /* check integer format with delimiter set */
146 char *s, *ds;
147 {
148 register char *cp;
149
150 cp = iskip(s);
151 return(cp != NULL && strchr(ds, *cp) != NULL);
152 }
153
154
155 int
156 isflt(s) /* check float format */
157 char *s;
158 {
159 register char *cp;
160
161 cp = fskip(s);
162 return(cp != NULL && *cp == '\0');
163 }
164
165
166 int
167 isfltd(s, ds) /* check integer format with delimiter set */
168 char *s, *ds;
169 {
170 register char *cp;
171
172 cp = fskip(s);
173 return(cp != NULL && strchr(ds, *cp) != NULL);
174 }
