root/radiance/ray/src/common/words.c
Fri Jan 1 02:10:32 2021 UTC (3 years, 4 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.12: +4 -6 lines
perf: insignificant branch reduction
Sat Dec 28 18:05:14 2019 UTC (4 years, 5 months ago) by greg
Changes since 2.11: +1 -2 lines
Thu Apr 28 17:46:25 2011 UTC (13 years, 1 month ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Changes since 2.10: +11 -11 lines
Minor fixes
Changes since 2.9: +24 -26 lines
Tue Sep 28 17:54:18 2004 UTC (19 years, 8 months ago) by greg
Mon Mar 10 17:26:26 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.6: +1 -5 lines
Compile fixes for Linux
Changes since 2.4: +65 -8 lines
Fri Jan 29 11:18:23 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 2.3: +28 -1 lines
added nextword() function for reading quoted strings
Wed Jan 17 10:53:38 1996 UTC (28 years, 4 months ago) by greg
Changes since 2.2: +16 -1 lines
replaced sskip() behavior and added new sskip2() function
Wed Jan 10 21:04:21 1996 UTC (28 years, 4 months ago) by greg
improved sskip() behavior
Tue Nov 12 16:56:04 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.4 , to selected 2.4
Tue Jul 30 13:47:29 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.3: +6 -6 lines
Diff to previous 1.3 , to selected 2.4
*** empty log message ***
Thu Jul 25 14:36:49 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.2 , to selected 2.4
bug
Tue Jul 23 11:36:42 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.1: +37 -16 lines
Diff to previous 1.1 , to selected 2.4
added atos() function and made checking more robust
Mon Jul 22 14:34:27 1991 UTC (32 years, 10 months ago) by greg
Diff to selected 2.4
