root/radiance/ray/src/common/wordfile.c
Fri Jun 10 16:42:11 2005 UTC (19 years, 11 months ago) by greg
CVS Tags: rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0
Diff to previous 2.14
Added rtcontrib -M option to read modifier list from a file
Fri Nov 5 17:36:55 2004 UTC (20 years, 6 months ago) by greg
Diff to previous 2.13
Sun Mar 28 20:33:12 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.12: +1 -3 lines
Diff to previous 2.12
Wed Oct 22 02:06:34 2003 UTC (21 years, 6 months ago) by greg
Sun Jun 8 12:03:09 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.10: +2 -5 lines
Sat Jun 7 12:50:21 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.9: +12 -2 lines
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
Sat Feb 22 02:07:23 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.7: +60 -4 lines
Fri Jun 18 09:00:22 1993 UTC (31 years, 10 months ago) by greg
fixed potential bug when wordfile is passed NULL as file name
Fri Apr 2 09:11:35 1993 UTC (32 years, 1 month ago) by greg
insignificant optimization in wordstring()
Tue Nov 10 18:21:26 1992 UTC (32 years, 6 months ago) by greg
bug fix
Tue Nov 3 19:34:00 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.3: +9 -8 lines
bug fix in wordstring()
Sat Oct 17 08:08:02 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.2: +34 -29 lines
added wordstring() function to wordfile.c
created expandargs.c
Fri Oct 16 13:02:46 1992 UTC (32 years, 6 months ago) by greg
Changes since 2.1: +9 -8 lines
increased file size limit
Wed Mar 4 09:59:19 1992 UTC (33 years, 2 months ago) by greg
