root/radiance/ray/src/common/win_process.c
Revision: 3.13
Committed: Mon Mar 28 16:59:38 2016 UTC (8 years, 2 months ago) by schorsch
CVS Tags: rad5R2, rad5R1
Changes since 3.12: +2 -16 lines
Remove code for obsolete systems.
# User Rev Content
1 schorsch 3.1 #ifndef lint
2 schorsch 3.13 static char RCSid[]="$Id: win_process.c,v 3.12 2016/03/06 01:13:17 schorsch Exp $";
3 schorsch 3.1 #endif
4     /*
5     * Routines to communicate with separate process via dual pipes.
6     * Windows version.
7     *
8     * External symbols declared in standard.h
9     */
10
11     #include "copyright.h"
12
13     #include <stdio.h>
14     #define STRICT
15     #include <windows.h> /* typedefs */
16     #include <io.h> /* _open_osfhandle */
17     #include <fcntl.h> /* _O_XXX */
18
19 schorsch 3.3 #include "rterror.h"
20     #include "rtio.h"
21 schorsch 3.1 #include "rtprocess.h"
22
23
24 schorsch 3.4 int
25     win_nice(int inc) /* simple nice(2) replacement for Windows */
26     {
27     /* We don't have much granularity available: IDLE_PRIORITY_CLASS
28     will run whenever no other higher priority process is running */
29     if (inc > 0) {
30     return (int)!SetPriorityClass(GetCurrentProcess(), IDLE_PRIORITY_CLASS);
31     }
32     return 0;
33     }
34 schorsch 3.1
35
36     /*
37     Safely terminate a process by creating a remote thread
38     in the process that calls ExitProcess.
39     As presented by Andrew Tucker in Windows Developer Magazine.
40     */
41     BOOL SafeTerminateProcess(HANDLE hProcess, UINT uExitCode)
42     {
43     DWORD dwTID, dwCode, dwErr = 0;
44     HANDLE hProcessDup = INVALID_HANDLE_VALUE;
45     HANDLE hRT = NULL;
46     HINSTANCE hKernel = GetModuleHandle("Kernel32");
47     BOOL bSuccess = FALSE;
48
49     BOOL bDup = DuplicateHandle(GetCurrentProcess(),
50     hProcess,
51     GetCurrentProcess(),
52     &hProcessDup,
53     PROCESS_ALL_ACCESS,
54     FALSE,
55     0);
56     /* Detect the special case where the process is already dead... */
57     if ( GetExitCodeProcess((bDup) ? hProcessDup : hProcess, &dwCode) &&
58     (dwCode == STILL_ACTIVE) ) {
59     FARPROC pfnExitProc;
60     pfnExitProc = GetProcAddress(hKernel, "ExitProcess");
61     hRT = CreateRemoteThread((bDup) ? hProcessDup : hProcess,
62     NULL,
63     0,
64     (LPTHREAD_START_ROUTINE)pfnExitProc,
65     (PVOID)uExitCode, 0, &dwTID);
66     if ( hRT == NULL ) dwErr = GetLastError();
67     } else {
68     dwErr = ERROR_PROCESS_ABORTED;
69     }
70     if ( hRT ) {
71     /* Must wait process to terminate to guarantee that it has exited... */
72     WaitForSingleObject((bDup) ? hProcessDup : hProcess, INFINITE);
73     CloseHandle(hRT);
74     bSuccess = TRUE;
75     }
76     if ( bDup ) CloseHandle(hProcessDup);
77     if ( !bSuccess ) SetLastError(dwErr);
78     return bSuccess;
79     }
80
81
82     static int
83     start_process(SUBPROC *proc, char *cmdstr)
84     {
85     BOOL res;
86     int Pflags = 0;
87     SECURITY_ATTRIBUTES SAttrs;
88     STARTUPINFO SInfo;
89     PROCESS_INFORMATION PInfo;
90     /* welcome to the world of resource handles */
91     HANDLE hToChildRead = NULL;
92     HANDLE hToChildWrite = NULL;
93     HANDLE hFromChildRead = NULL;
94     HANDLE hFromChildWrite = NULL;
95     HANDLE hRead = NULL, hWrite = NULL;
96     HANDLE hStdIn, hStdOut, hStdErr;
97     HANDLE hCurProc;
98
99     /* get process and standard stream handles */
100     hCurProc = GetCurrentProcess();
101     hStdIn = GetStdHandle(STD_INPUT_HANDLE);
102     hStdOut = GetStdHandle(STD_OUTPUT_HANDLE);
103     hStdErr = GetStdHandle(STD_ERROR_HANDLE);
104
105     /* the remote pipe handles must be inheritable */
106     SAttrs.bInheritHandle = 1;
107     SAttrs.lpSecurityDescriptor = NULL;
108     SAttrs.nLength = sizeof(SECURITY_ATTRIBUTES);
109
110     /* make pipe, assign to stdout */
111     /* we'll check for errors after CreateProcess()...*/
112     res = CreatePipe(&hFromChildRead, &hFromChildWrite, &SAttrs, 0);
113     res = SetStdHandle(STD_OUTPUT_HANDLE, hFromChildWrite);
114     /* create non-inheritable dup of local end */
115     res = DuplicateHandle(hCurProc, hFromChildRead, hCurProc, &hRead,
116     0, FALSE, DUPLICATE_SAME_ACCESS);
117     CloseHandle(hFromChildRead); hFromChildRead = NULL;
118
119     res = CreatePipe(&hToChildRead, &hToChildWrite, &SAttrs, 0);
120     res = SetStdHandle(STD_INPUT_HANDLE, hToChildRead);
121     res = DuplicateHandle(hCurProc, hToChildWrite, hCurProc, &hWrite,
122     0, FALSE, DUPLICATE_SAME_ACCESS);
123     CloseHandle(hToChildWrite); hToChildWrite = NULL;
124
125     CloseHandle(hCurProc); hCurProc = NULL;
126
127     /* do some bookkeeping for Windows... */
128     SInfo.cb = sizeof(STARTUPINFO);
129     SInfo.lpReserved = NULL;
130     SInfo.lpDesktop = NULL;
131     SInfo.lpTitle = NULL;
132     SInfo.cbReserved2 = 0;
133     SInfo.lpReserved2 = NULL;
134     /* don't open a console automatically, pass handles */
135     SInfo.dwFlags = STARTF_USESHOWWINDOW | STARTF_USESTDHANDLES;
136     SInfo.wShowWindow = SW_HIDE;
137     SInfo.hStdInput = hToChildRead;
138     SInfo.hStdOutput = hFromChildWrite;
139     SInfo.hStdError = hStdErr; /* reuse original stderr */
140
141     res = CreateProcess(NULL, /* command name */
142     cmdstr, /* full command line */
143     NULL, /* default process attributes */
144     NULL, /* default security attributes */
145     1, /* inherit handles (pass doesn't work reliably) */
146     Pflags, /* process flags */
147     NULL, /* no new environment */
148     NULL, /* stay in current directory */
149     &SInfo,
150     &PInfo
151     );
152     /* reset stdin/stdout in any case */
153     SetStdHandle(STD_OUTPUT_HANDLE, hStdOut);
154     SetStdHandle(STD_INPUT_HANDLE, hStdIn);
155     /* Oops... */
156     if(res == 0) {
157     char es[128];
158     _snprintf(es, sizeof(es),
159     "Error creating process (%d)\n", GetLastError());
160     eputs(es);
161     goto error;
162     }
163     /* close stuff we don't need */
164     CloseHandle(PInfo.hThread);
165     CloseHandle(hFromChildWrite); hFromChildWrite = NULL;
166     CloseHandle(hToChildRead); hToChildRead = NULL;
167     /* get the file descriptors */
168 greg 3.9 proc->r = _open_osfhandle((long)hRead, _O_RDONLY|_O_BINARY);
169     proc->w = _open_osfhandle((long)hWrite, _O_APPEND|_O_BINARY);
170 schorsch 3.1 proc->pid = PInfo.dwProcessId;
171     proc->running = 1;
172     CloseHandle(hCurProc);
173     /* Windows doesn't tell us the actual buffer size */
174     return PIPE_BUF;
175
176     error: /* cleanup */
177     if(PInfo.hThread) CloseHandle(PInfo.hThread);
178     if(hToChildRead) CloseHandle(hToChildRead);
179     if(hToChildWrite) CloseHandle(hToChildWrite);
180     if(hFromChildRead) CloseHandle(hFromChildRead);
181     if(hFromChildWrite) CloseHandle(hFromChildWrite);
182     if(hRead) CloseHandle(hRead);
183     if(hWrite) CloseHandle(hWrite);
184     if(hCurProc) CloseHandle(hCurProc);
185     proc->running = 0;
186 greg 3.7 return -1;
187 schorsch 3.1 /* There... Are we happy now? */
188     }
189
190
191 schorsch 3.12 static size_t /* copied size or -1 on error */
192 schorsch 3.1 wordncopy( /* copy (quoted) src to dest. */
193
194     char * dest,
195     char * src,
196 schorsch 3.12 size_t dlen,
197 schorsch 3.1 int insert_space, /* prepend a space */
198     int force_dq /* turn 'src' into "dest" (for Win command line) */
199     )
200     {
201 schorsch 3.12 size_t slen;
202     size_t pos = 0;
203 schorsch 3.1
204     slen = strlen(src);
205     if (insert_space) {
206     if (1 >= dlen) return -1;
207     dest[pos++] = ' ';
208     }
209     if (strpbrk(src, " \f\n\r\t\v")) {
210     if (force_dq && src[0] == '\'' && src[slen-1] == '\'') {
211     if (slen + pos + 1 > dlen) return -1;
212     dest[pos++] = '"';
213     strncpy(dest + pos, src + 1, slen -2);
214     pos += slen - 2;
215     dest[pos++] = '"';
216     } else if (src[0] == '"' && src[slen-1] == '"') {
217     if (slen + pos + 1 > dlen) return -1;
218     strncpy(dest + pos, src, slen);
219     pos += slen;
220     } else {
221     if (slen + pos + 3 > dlen) return -1;
222     dest[pos++] = '"';
223     strncpy(dest + pos, src, slen);
224     pos += slen;
225     dest[pos++] = '"';
226     }
227     } else {
228     if (slen + pos + 1 > dlen) return -1;
229     strncpy(dest + pos, src, slen);
230     pos += slen;
231     }
232     dest[pos] = '\0';
233     return pos;
234     }
235
236
237
238     static char *
239     quoted_cmdline( /* compose command line for StartProcess() as static string */
240
241     char *cmdpath, /* full path to executable */
242     char *sl[] /* list of arguments */
243     )
244     {
245     static char *cmdstr;
246 schorsch 3.12 static size_t clen;
247 schorsch 3.1 char *newcs;
248 schorsch 3.12 size_t newlen, pos, i, res;
249 schorsch 3.1
250     newlen = strlen(cmdpath) + 3; /* allow two quotes plus the final \0 */
251     for (i = 0; sl[i] != NULL; i++) {
252     newlen += strlen(sl[i]) + 3; /* allow two quotes and a space */
253     }
254     if (cmdstr == NULL) {
255     cmdstr = (char *) malloc(newlen);
256     if (cmdstr == NULL) return NULL;
257     } else if (newlen > clen) {
258     newcs = (char *) realloc(cmdstr, newlen);
259     if (newcs == NULL) return NULL;
260     cmdstr = newcs;
261     }
262     clen = newlen;
263     pos = wordncopy(cmdstr, cmdpath, clen, 0, 1);
264     if (pos < 0) return NULL;
265     for (i = 0; sl[i] != NULL; i++) {
266     res = wordncopy(cmdstr + pos, sl[i], clen - pos, 1, 1);
267     if (res < 0) return NULL;
268     pos += res;
269     }
270     return cmdstr;
271     }
272
273
274     int
275     open_process(SUBPROC *proc, char *av[])
276     {
277     char *cmdpath;
278     char *cmdstr;
279
280 greg 3.8 if (av == NULL || av[0] == NULL) {
281     fputs("Illegal call to open_process()!\n", stderr);
282     return -1;
283     }
284 greg 3.10 proc->pid = 0;
285 schorsch 3.1 proc->running = 0;
286 greg 3.7 if (av == NULL) { return -1; }
287 schorsch 3.1 cmdpath = getpath(av[0], getenv("PATH"), X_OK);
288 schorsch 3.6 cmdstr = quoted_cmdline(cmdpath, av+1);
289 schorsch 3.1 if (cmdstr == NULL) { return 0; }
290     return start_process(proc, cmdstr);
291     }
292
293
294 schorsch 3.5 int win_kill(RT_PID pid, int sig) /* we ignore sig... */
295     {
296     HANDLE hProc;
297
298     hProc = OpenProcess(SYNCHRONIZE|PROCESS_TERMINATE, FALSE, pid);
299     /* it looks like we want to ignore errors here */
300     if(hProc != NULL) {
301     SafeTerminateProcess(hProc, 0);
302     CloseHandle(hProc);
303     }
304     return 0; /* XXX we need to figure out more here... */
305     }
306
307
308 schorsch 3.1 int
309 greg 3.10 close_processes(SUBPROC pd[], int nproc) {
310     int i, icres, ocres;
311 schorsch 3.1 DWORD pid;
312
313 greg 3.10 for (i = 0; i < nproc; i++) {
314 schorsch 3.12 if (pd[i].running) {
315 greg 3.10 ocres = close(pd[i].w);
316     icres = close(pd[i].r);
317     pd[i].running = 0;
318 greg 3.11 if(ocres != 0 || icres != 0) {
319     /* something went wrong: enforce infanticide */
320 schorsch 3.13 /* other than that, it looks like we want to ignore errors */
321 greg 3.11 win_kill(pd[i].pid, 0);
322     }
323 greg 3.10 }
324     pd[i].pid = 0;
325 schorsch 3.1 }
326     return 0; /* XXX we need to figure out more here... */
327     }
328
329
330     #ifdef TEST_MODULE
331     int
332     main( int argc, char **argv )
333     {
334     SUBPROC proc;
335     FILE *inf, *outf;
336     int res;
337     char ret[1024];
338     char *command[]= {"word", "gappy word", "\"quoted words\"", "'squoted words'", NULL};
339
340     res = open_process(&proc, command)
341     if (res == 0) {
342     printf("open_process() failed with return value 0\n");
343     return -1;
344     }
345     printf("process opened with return value: %d, pid: %d, r: %d, w: %d\n",
346     res, proc.pid, proc.r, proc.w);
347     inf = fdopen(proc.r, "rb");
348     outf = fdopen(proc.w, "wb");
349     fprintf(outf,"0 0 0 0 1 0\n");
350     fflush(outf);
351     fgets(ret, sizeof(ret), inf);
352     printf("%s\n",ret);
353     close_process(&proc);
354     }
355     #endif
356
