--- ray/src/common/win_process.c 2013/11/08 18:08:07 3.8 +++ ray/src/common/win_process.c 2016/03/06 01:13:17 3.12 @@ -1,5 +1,5 @@ #ifndef lint -static char RCSid[]="$Id: win_process.c,v 3.8 2013/11/08 18:08:07 greg Exp $"; +static char RCSid[]="$Id: win_process.c,v 3.12 2016/03/06 01:13:17 schorsch Exp $"; #endif /* * Routines to communicate with separate process via dual pipes. @@ -167,8 +167,8 @@ start_process(SUBPROC *proc, char *cmdstr) CloseHandle(hFromChildWrite); hFromChildWrite = NULL; CloseHandle(hToChildRead); hToChildRead = NULL; /* get the file descriptors */ - proc->r = _open_osfhandle((long)hRead, _O_RDONLY); - proc->w = _open_osfhandle((long)hWrite, _O_APPEND); + proc->r = _open_osfhandle((long)hRead, _O_RDONLY|_O_BINARY); + proc->w = _open_osfhandle((long)hWrite, _O_APPEND|_O_BINARY); proc->pid = PInfo.dwProcessId; proc->running = 1; CloseHandle(hCurProc); @@ -190,18 +190,18 @@ error: /* cleanup */ } -static int /* copied size or -1 on error */ +static size_t /* copied size or -1 on error */ wordncopy( /* copy (quoted) src to dest. */ char * dest, char * src, -int dlen, +size_t dlen, int insert_space, /* prepend a space */ int force_dq /* turn 'src' into "dest" (for Win command line) */ ) { - int slen; - int pos = 0; + size_t slen; + size_t pos = 0; slen = strlen(src); if (insert_space) { @@ -245,9 +245,9 @@ char *sl[] /* list of arguments */ ) { static char *cmdstr; - static int clen; + static size_t clen; char *newcs; - int newlen, pos, res, i; + size_t newlen, pos, i, res; newlen = strlen(cmdpath) + 3; /* allow two quotes plus the final \0 */ for (i = 0; sl[i] != NULL; i++) { @@ -283,6 +283,7 @@ open_process(SUBPROC *proc, char *av[]) fputs("Illegal call to open_process()!\n", stderr); return -1; } + proc->pid = 0; proc->running = 0; if (av == NULL) { return -1; } cmdpath = getpath(av[0], getenv("PATH"), X_OK); @@ -319,21 +320,23 @@ int win_kill(RT_PID pid, int sig) /* we ignore sig... int -close_process(SUBPROC *proc) { - int icres, ocres; +close_processes(SUBPROC pd[], int nproc) { + int i, icres, ocres; DWORD pid; - ocres = close(proc->w); - icres = close(proc->r); - pid = proc->pid; - if(ocres != 0 || icres != 0) { - /* something went wrong: enforce infanticide */ - /* other than that, it looks like we want to ignore errors here */ - if (proc->running) { - win_kill(pid, 0); + for (i = 0; i < nproc; i++) { + if (pd[i].running) { + ocres = close(pd[i].w); + icres = close(pd[i].r); + pd[i].running = 0; + if(ocres != 0 || icres != 0) { + /* something went wrong: enforce infanticide */ + /* other than that, it looks like we want to ignore errors here */ + win_kill(pd[i].pid, 0); + } } + pd[i].pid = 0; } - proc->running = 0; return 0; /* XXX we need to figure out more here... */ }
