root/radiance/ray/src/common/win_process.c
Fri Feb 28 05:18:49 2020 UTC (4 years, 3 months ago) by greg
Changes since 3.13: +12 -8 lines
Diff to previous 3.13 , to selected 3.8
Mon Mar 28 16:59:38 2016 UTC (8 years, 2 months ago) by schorsch
CVS Tags: rad5R1, rad5R2
Changes since 3.12: +2 -16 lines
Diff to previous 3.12 , to selected 3.8
Remove code for obsolete systems.
Sun Mar 6 01:13:17 2016 UTC (8 years, 3 months ago) by schorsch
Changes since 3.11: +8 -8 lines
Diff to previous 3.11 , to selected 3.8
Fri Mar 4 19:13:53 2016 UTC (8 years, 3 months ago) by greg
Changes since 3.10: +6 -6 lines
Diff to previous 3.10 , to selected 3.8
Minor fix
Fri Mar 4 02:48:14 2016 UTC (8 years, 3 months ago) by greg
Changes since 3.9: +15 -12 lines
Diff to previous 3.9 , to selected 3.8
Made quitting rvu, rholo and rcontrib quicker with multiple processes on Unix
Wed Feb 12 00:15:40 2014 UTC (10 years, 4 months ago) by greg
Changes since 3.8: +3 -3 lines
Diff to previous 3.8
Added binary flag to i/o descriptors (needed in this case?)
Revision 3.8 - (view) (download) (annotate) - [selected]
Fri Nov 8 18:08:07 2013 UTC (10 years, 7 months ago) by greg
Changes since 3.7: +5 -1 lines
Diff to previous 3.7
Minor fixes that should not affect operation
Thu Jun 14 05:13:25 2012 UTC (12 years ago) by greg
Changes since 3.6: +3 -2 lines
Diff to previous 3.6 , to selected 3.8
Simplified creation of child process
Mon Sep 19 11:30:10 2005 UTC (18 years, 8 months ago) by schorsch
Changes since 3.5: +3 -3 lines
Diff to previous 3.5 , to selected 3.8
Sat Oct 23 18:55:52 2004 UTC (19 years, 7 months ago) by schorsch
Changes since 3.4: +28 -19 lines
Diff to previous 3.4 , to selected 3.8
Tue Oct 21 19:19:28 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 3.3: +11 -4 lines
Diff to previous 3.3 , to selected 3.8
Mon Jul 14 20:02:29 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 3.2: +3 -2 lines
Diff to previous 3.2 , to selected 3.8
Thu Jul 3 22:41:44 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 3.1: +1 -2 lines
Diff to previous 3.1 , to selected 3.8
Diff to selected 3.8
