root/radiance/ray/src/common/view.h
Wed Jan 12 21:07:39 2022 UTC (2 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 2.21
refactor: created cropview() function to manage view sections
Fri Dec 3 18:10:48 2021 UTC (2 years, 4 months ago) by greg
Diff to previous 2.20
refactor: moved depth-of-field sampling to separate module
Fri Apr 27 05:00:29 2018 UTC (6 years ago) by greg
CVS Tags: rad5R2, rad5R3
Changes since 2.19: +7 -1 lines
Diff to previous 2.19
Improved viewloc() return values to include aft clipping test
Wed Jan 24 03:34:15 2018 UTC (6 years, 3 months ago) by greg
Diff to previous 2.18
Added off-view checking to viewloc()
Tue Mar 11 02:21:46 2008 UTC (16 years, 1 month ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1
Diff to previous 2.17
Tue Jan 18 00:33:16 2005 UTC (19 years, 3 months ago) by greg
Changes since 2.16: +3 -2 lines
Diff to previous 2.16
Tue Jun 8 19:48:29 2004 UTC (19 years, 10 months ago) by greg
Changes since 2.15: +2 -5 lines
Diff to previous 2.15
Diff to previous 2.14
Fri Oct 24 05:29:42 2003 UTC (20 years, 6 months ago) by greg
Diff to previous 2.13
Mon Jul 14 22:23:59 2003 UTC (20 years, 9 months ago) by schorsch
Diff to previous 2.12
Mon Jun 30 19:04:29 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.10: +1 -3 lines
Fri Jun 6 16:38:47 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.8: +11 -17 lines
*** empty log message ***
Changes since 2.6: +94 -11 lines
Tue Jan 9 12:21:13 1996 UTC (28 years, 3 months ago) by greg
added viewopt() routine to get minimal view specification
Fri Aug 18 10:20:11 1995 UTC (28 years, 8 months ago) by greg
added cylindrical view type
Tue Dec 20 20:15:06 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.3: +7 -2 lines
added -vo and -va (fore and aft clipping plane) parameters
Fri Mar 5 15:14:06 1993 UTC (31 years, 2 months ago) by greg
portability improvements
Fri Oct 2 15:56:31 1992 UTC (31 years, 7 months ago) by greg
Tue Nov 12 16:55:36 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.7
Fri Apr 12 14:20:40 1991 UTC (33 years ago) by greg
Changes since 1.6: +1 -0 lines
Diff to previous 1.6
added VIEWSTRL
Sat Oct 13 20:56:04 1990 UTC (33 years, 6 months ago) by greg
Diff to previous 1.5
added fisheye view types
Thu Jan 18 23:58:55 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.4: +0 -2 lines
Diff to previous 1.4
Mon Jan 8 14:45:51 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.3: +13 -7 lines
Diff to previous 1.3
got rid of resolution and added shift and lift options
Fri Dec 22 08:21:55 1989 UTC (34 years, 4 months ago) by greg
Diff to previous 1.2
changed vhs2 and vvs2 to vhn2 and vvn2
Sun Dec 10 13:41:08 1989 UTC (34 years, 4 months ago) by greg
Diff to previous 1.1
added pixelview() and sskip() routines
Thu Feb 2 10:34:24 1989 UTC (35 years, 3 months ago) by greg
