root/radiance/ray/src/common/view.h
Revision: 2.24
Committed: Sat Jun 7 05:09:45 2025 UTC (2 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.23: +1 -3 lines
1 /* RCSid $Id: view.h,v 2.23 2025/06/03 21:31:51 greg Exp $ */
2 /*
3 * view.h - header file for image generation.
4 *
5 * Include after stdio.h and rtmath.h
6 * Includes resolu.h
7 */
8 #ifndef _RAD_VIEW_H_
9 #define _RAD_VIEW_H_
10
11 #include "resolu.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16
17 /* view types */
18 #define VT_PER 'v' /* perspective */
19 #define VT_PAR 'l' /* parallel */
20 #define VT_ANG 'a' /* angular fisheye */
21 #define VT_HEM 'h' /* hemispherical fisheye */
22 #define VT_PLS 's' /* planispheric fisheye */
23 #define VT_CYL 'c' /* cylindrical panorama */
24
25 typedef struct {
26 int type; /* view type */
27 FVECT vp; /* view origin */
28 FVECT vdir; /* view direction */
29 FVECT vup; /* view up */
30 double vdist; /* view distance */
31 double horiz; /* horizontal view size */
32 double vert; /* vertical view size */
33 double hoff; /* horizontal image offset */
34 double voff; /* vertical image offset */
35 double vfore; /* fore clipping plane */
36 double vaft; /* aft clipping plane (<=0 for inf) */
37 FVECT hvec; /* computed horizontal image vector */
38 FVECT vvec; /* computed vertical image vector */
39 double hn2; /* DOT(hvec,hvec) */
40 double vn2; /* DOT(vvec,vvec) */
41 } VIEW; /* view parameters */
42
43 extern VIEW stdview;
44
45 #define viewaspect(v) sqrt((v)->vn2/(v)->hn2)
46
47 #define STDVIEW {VT_PER,{0.,0.,0.},{0.,1.,0.},{0.,0.,1.}, \
48 1.,45.,45.,0.,0.,0.,0., \
49 {0.,0.,0.},{0.,0.,0.},0.,0.}
50
51 #define VIEWSTR "VIEW="
52 #define VIEWSTRL 5
53
54 /* return values/flags for viewloc() */
55 #define VL_BAD 0 /* illegal position (i.e. origin) */
56 #define VL_GOOD 0x1 /* result is valid */
57 #define VL_BEHIND 0x2 /* world point is behind fore plane */
58 #define VL_OUTSIDE 0x4 /* world point is outside frustum */
59 #define VL_BEYOND 0x8 /* point is beyond aft clipping plane */
60
61 extern char *setview(VIEW *v);
62 extern char *cropview(VIEW *v, double x0, double y0, double x1, double y1);
63 extern void normaspect(double va, double *ap, int *xp, int *yp);
64 extern double viewray(FVECT orig, FVECT direc, VIEW *v, double x, double y);
65 extern int jitteraperture(FVECT orig, FVECT direc, VIEW *v, double dia);
66 extern int viewloc(FVECT ip, VIEW *v, FVECT p);
67 extern void pix2loc(RREAL loc[2], RESOLU *rp, int px, int py);
68 extern void loc2pix(int pp[2], RESOLU *rp, double lx, double ly);
69 extern int getviewopt(VIEW *v, int ac, char *av[]);
70 extern int sscanview(VIEW *vp, char *s);
71 extern void fprintview(VIEW *vp, FILE *fp);
72 extern char *viewopt(VIEW *vp);
73 extern int isview(char *s);
74 extern int viewfile(char *fname, VIEW *vp, RESOLU *rp);
75
76
77 #ifdef __cplusplus
78 }
79 #endif
80 #endif /* _RAD_VIEW_H_ */
81
