root/Development/ray/src/common/view.h
Revision: 2.22
Committed: Wed Jan 12 21:07:39 2022 UTC (3 years, 11 months ago) by greg
refactor: created cropview() function to manage view sections
# User Rev Content
1 greg 2.22 /* RCSid $Id: view.h,v 2.21 2021/12/03 18:10:48 greg Exp $ */
2 greg 1.1 /*
3     * view.h - header file for image generation.
4     *
5 greg 2.16 * Include after stdio.h and rtmath.h
6 greg 2.7 * Includes resolu.h
7     */
8 schorsch 2.9 #ifndef _RAD_VIEW_H_
9     #define _RAD_VIEW_H_
10 schorsch 2.13
11     #include "resolu.h"
12
13 schorsch 2.9 #ifdef __cplusplus
14     extern "C" {
15     #endif
16 greg 2.7
17 greg 1.1 /* view types */
18     #define VT_PER 'v' /* perspective */
19     #define VT_PAR 'l' /* parallel */
20 greg 1.6 #define VT_ANG 'a' /* angular fisheye */
21     #define VT_HEM 'h' /* hemispherical fisheye */
22 greg 2.18 #define VT_PLS 's' /* planispheric fisheye */
23 greg 2.5 #define VT_CYL 'c' /* cylindrical panorama */
24 greg 1.1
25     typedef struct {
26     int type; /* view type */
27     FVECT vp; /* view origin */
28     FVECT vdir; /* view direction */
29     FVECT vup; /* view up */
30 greg 2.17 double vdist; /* view distance */
31 greg 1.1 double horiz; /* horizontal view size */
32     double vert; /* vertical view size */
33 greg 1.4 double hoff; /* horizontal image offset */
34     double voff; /* vertical image offset */
35 greg 2.4 double vfore; /* fore clipping plane */
36     double vaft; /* aft clipping plane (<=0 for inf) */
37 greg 1.4 FVECT hvec; /* computed horizontal image vector */
38     FVECT vvec; /* computed vertical image vector */
39     double hn2; /* DOT(hvec,hvec) */
40     double vn2; /* DOT(vvec,vvec) */
41 greg 1.1 } VIEW; /* view parameters */
42
43     extern VIEW stdview;
44
45 greg 1.4 #define viewaspect(v) sqrt((v)->vn2/(v)->hn2)
46
47 greg 2.3 #define STDVIEW {VT_PER,{0.,0.,0.},{0.,1.,0.},{0.,0.,1.}, \
48 greg 2.17 1.,45.,45.,0.,0.,0.,0., \
49 greg 2.4 {0.,0.,0.},{0.,0.,0.},0.,0.}
50 greg 1.1
51     #define VIEWSTR "VIEW="
52 greg 1.7 #define VIEWSTRL 5
53 greg 2.7
54 greg 2.20 /* return values/flags for viewloc() */
55     #define VL_BAD 0 /* illegal position (i.e. origin) */
56     #define VL_GOOD 0x1 /* result is valid */
57     #define VL_BEHIND 0x2 /* world point is behind fore plane */
58     #define VL_OUTSIDE 0x4 /* world point is outside frustum */
59     #define VL_BEYOND 0x8 /* point is beyond aft clipping plane */
60 greg 2.7
61     extern char *setview(VIEW *v);
62 greg 2.22 extern char *cropview(VIEW *v, double x0, double y0, double x1, double y1);
63 greg 2.7 extern void normaspect(double va, double *ap, int *xp, int *yp);
64     extern double viewray(FVECT orig, FVECT direc, VIEW *v, double x, double y);
65 greg 2.21 extern int jitteraperture(FVECT orig, FVECT direc, VIEW *v, double dia);
66 greg 2.19 extern int viewloc(FVECT ip, VIEW *v, FVECT p);
67 schorsch 2.10 extern void pix2loc(RREAL loc[2], RESOLU *rp, int px, int py);
68 greg 2.7 extern void loc2pix(int pp[2], RESOLU *rp, double lx, double ly);
69     extern int getviewopt(VIEW *v, int ac, char *av[]);
70     extern int sscanview(VIEW *vp, char *s);
71     extern void fprintview(VIEW *vp, FILE *fp);
72     extern char *viewopt(VIEW *vp);
73     extern int isview(char *s);
74     extern int viewfile(char *fname, VIEW *vp, RESOLU *rp);
75
76 schorsch 2.9
77     #ifdef __cplusplus
78     }
79 greg 2.7 #endif
80 schorsch 2.9 #endif /* _RAD_VIEW_H_ */
81
