root/radiance/ray/src/common/view.h
Revision: 2.18
Committed: Tue Mar 11 02:21:46 2008 UTC (17 years, 3 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R9, rad4R2P1
1 /* RCSid $Id: view.h,v 2.17 2005/01/18 00:33:16 greg Exp $ */
2 /*
3 * view.h - header file for image generation.
4 *
5 * Include after stdio.h and rtmath.h
6 * Includes resolu.h
7 */
8 #ifndef _RAD_VIEW_H_
9 #define _RAD_VIEW_H_
10
11 #include "resolu.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16
17 /* view types */
18 #define VT_PER 'v' /* perspective */
19 #define VT_PAR 'l' /* parallel */
20 #define VT_ANG 'a' /* angular fisheye */
21 #define VT_HEM 'h' /* hemispherical fisheye */
22 #define VT_PLS 's' /* planispheric fisheye */
23 #define VT_CYL 'c' /* cylindrical panorama */
24
25 typedef struct {
26 int type; /* view type */
27 FVECT vp; /* view origin */
28 FVECT vdir; /* view direction */
29 FVECT vup; /* view up */
30 double vdist; /* view distance */
31 double horiz; /* horizontal view size */
32 double vert; /* vertical view size */
33 double hoff; /* horizontal image offset */
34 double voff; /* vertical image offset */
35 double vfore; /* fore clipping plane */
36 double vaft; /* aft clipping plane (<=0 for inf) */
37 FVECT hvec; /* computed horizontal image vector */
38 FVECT vvec; /* computed vertical image vector */
39 double hn2; /* DOT(hvec,hvec) */
40 double vn2; /* DOT(vvec,vvec) */
41 } VIEW; /* view parameters */
42
43 extern VIEW stdview;
44
45 #define viewaspect(v) sqrt((v)->vn2/(v)->hn2)
46
47 #define STDVIEW {VT_PER,{0.,0.,0.},{0.,1.,0.},{0.,0.,1.}, \
48 1.,45.,45.,0.,0.,0.,0., \
49 {0.,0.,0.},{0.,0.,0.},0.,0.}
50
51 #define VIEWSTR "VIEW="
52 #define VIEWSTRL 5
53
54
55 extern char *setview(VIEW *v);
56 extern void normaspect(double va, double *ap, int *xp, int *yp);
57 extern double viewray(FVECT orig, FVECT direc, VIEW *v, double x, double y);
58 extern void viewloc(FVECT ip, VIEW *v, FVECT p);
59 extern void pix2loc(RREAL loc[2], RESOLU *rp, int px, int py);
60 extern void loc2pix(int pp[2], RESOLU *rp, double lx, double ly);
61 extern int getviewopt(VIEW *v, int ac, char *av[]);
62 extern int sscanview(VIEW *vp, char *s);
63 extern void fprintview(VIEW *vp, FILE *fp);
64 extern char *viewopt(VIEW *vp);
65 extern int isview(char *s);
66 extern int viewfile(char *fname, VIEW *vp, RESOLU *rp);
67
68
69 #ifdef __cplusplus
70 }
71 #endif
72 #endif /* _RAD_VIEW_H_ */
73
