root/radiance/ray/src/common/view.h
Revision: 2.7
Committed: Sat Feb 22 02:07:23 2003 UTC (21 years, 4 months ago) by greg
Changes since 2.6: +94 -11 lines
1 /* RCSid: $Id$ */
2 /*
3 * view.h - header file for image generation.
4 *
5 * Include after fvect.h
6 * Includes resolu.h
7 */
8
9 /* ====================================================================
10 * The Radiance Software License, Version 1.0
11 *
12 * Copyright (c) 1990 - 2002 The Regents of the University of California,
13 * through Lawrence Berkeley National Laboratory. All rights reserved.
14 *
15 * Redistribution and use in source and binary forms, with or without
16 * modification, are permitted provided that the following conditions
17 * are met:
18 *
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 *
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in
24 * the documentation and/or other materials provided with the
25 * distribution.
26 *
27 * 3. The end-user documentation included with the redistribution,
28 * if any, must include the following acknowledgment:
29 * "This product includes Radiance software
30 * (http://radsite.lbl.gov/)
31 * developed by the Lawrence Berkeley National Laboratory
32 * (http://www.lbl.gov/)."
33 * Alternately, this acknowledgment may appear in the software itself,
34 * if and wherever such third-party acknowledgments normally appear.
35 *
36 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
37 * and "The Regents of the University of California" must
38 * not be used to endorse or promote products derived from this
39 * software without prior written permission. For written
40 * permission, please contact [email protected].
41 *
42 * 5. Products derived from this software may not be called "Radiance",
43 * nor may "Radiance" appear in their name, without prior written
44 * permission of Lawrence Berkeley National Laboratory.
45 *
46 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
47 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
48 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
49 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
50 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
51 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
52 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
53 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
54 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
55 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
56 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
57 * SUCH DAMAGE.
58 * ====================================================================
59 *
60 * This software consists of voluntary contributions made by many
61 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
62 * information on Lawrence Berkeley National Laboratory, please see
63 * <http://www.lbl.gov/>.
64 */
65
66 #include "resolu.h"
67
68 /* view types */
69 #define VT_PER 'v' /* perspective */
70 #define VT_PAR 'l' /* parallel */
71 #define VT_ANG 'a' /* angular fisheye */
72 #define VT_HEM 'h' /* hemispherical fisheye */
73 #define VT_CYL 'c' /* cylindrical panorama */
74
75 typedef struct {
76 int type; /* view type */
77 FVECT vp; /* view origin */
78 FVECT vdir; /* view direction */
79 FVECT vup; /* view up */
80 double horiz; /* horizontal view size */
81 double vert; /* vertical view size */
82 double hoff; /* horizontal image offset */
83 double voff; /* vertical image offset */
84 double vfore; /* fore clipping plane */
85 double vaft; /* aft clipping plane (<=0 for inf) */
86 FVECT hvec; /* computed horizontal image vector */
87 FVECT vvec; /* computed vertical image vector */
88 double hn2; /* DOT(hvec,hvec) */
89 double vn2; /* DOT(vvec,vvec) */
90 } VIEW; /* view parameters */
91
92 extern VIEW stdview;
93
94 #define viewaspect(v) sqrt((v)->vn2/(v)->hn2)
95
96 #define STDVIEW {VT_PER,{0.,0.,0.},{0.,1.,0.},{0.,0.,1.}, \
97 45.,45.,0.,0.,0.,0., \
98 {0.,0.,0.},{0.,0.,0.},0.,0.}
99
100 #define VIEWSTR "VIEW="
101 #define VIEWSTRL 5
102
103 #ifdef NOPROTO
104
105 extern char *setview();
106 extern void normaspect();
107 extern double viewray();
108 extern void viewloc();
109 extern void pix2loc();
110 extern void loc2pix();
111 extern int getviewopt();
112 extern int sscanview();
113 extern void fprintview();
114 extern char *viewopt();
115 extern int isview();
116 extern int viewfile();
117
118 #else
119
120 extern char *setview(VIEW *v);
121 extern void normaspect(double va, double *ap, int *xp, int *yp);
122 extern double viewray(FVECT orig, FVECT direc, VIEW *v, double x, double y);
123 extern void viewloc(FVECT ip, VIEW *v, FVECT p);
124 extern void pix2loc(FLOAT loc[2], RESOLU *rp, int px, int py);
125 extern void loc2pix(int pp[2], RESOLU *rp, double lx, double ly);
126 extern int getviewopt(VIEW *v, int ac, char *av[]);
127 extern int sscanview(VIEW *vp, char *s);
128 extern void fprintview(VIEW *vp, FILE *fp);
129 extern char *viewopt(VIEW *vp);
130 extern int isview(char *s);
131 extern int viewfile(char *fname, VIEW *vp, RESOLU *rp);
132
133 #endif
