--- ray/src/common/view.h 1989/12/10 13:41:08 1.2 +++ ray/src/common/view.h 2004/06/08 19:48:29 2.16 @@ -1,16 +1,25 @@ -/* Copyright (c) 1988 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: view.h,v 2.16 2004/06/08 19:48:29 greg Exp $ */ /* * view.h - header file for image generation. * - * 9/19/88 + * Include after stdio.h and rtmath.h + * Includes resolu.h */ +#ifndef _RAD_VIEW_H_ +#define _RAD_VIEW_H_ +#include "resolu.h" + +#ifdef __cplusplus +extern "C" { +#endif + /* view types */ #define VT_PER 'v' /* perspective */ #define VT_PAR 'l' /* parallel */ +#define VT_ANG 'a' /* angular fisheye */ +#define VT_HEM 'h' /* hemispherical fisheye */ +#define VT_CYL 'c' /* cylindrical panorama */ typedef struct { int type; /* view type */ @@ -19,18 +28,44 @@ typedef struct { FVECT vup; /* view up */ double horiz; /* horizontal view size */ double vert; /* vertical view size */ - int hresolu; /* horizontal resolution */ - int vresolu; /* vertical resolution */ - FVECT vhinc; /* computed horizontal increment */ - FVECT vvinc; /* computed vertical increment */ - double vhs2; /* 1.0/DOT(vhinc,vhinc) */ - double vvs2; /* 1.0/DOT(vvinc,vvinc) */ + double hoff; /* horizontal image offset */ + double voff; /* vertical image offset */ + double vfore; /* fore clipping plane */ + double vaft; /* aft clipping plane (<=0 for inf) */ + FVECT hvec; /* computed horizontal image vector */ + FVECT vvec; /* computed vertical image vector */ + double hn2; /* DOT(hvec,hvec) */ + double vn2; /* DOT(vvec,vvec) */ } VIEW; /* view parameters */ extern VIEW stdview; -extern char *setview(); +#define viewaspect(v) sqrt((v)->vn2/(v)->hn2) -#define STDVIEW(h) {VT_PER,0.,0.,0.,0.,1.,0.,0.,0.,1.,45.,45.,h,h} +#define STDVIEW {VT_PER,{0.,0.,0.},{0.,1.,0.},{0.,0.,1.}, \ + 45.,45.,0.,0.,0.,0., \ + {0.,0.,0.},{0.,0.,0.},0.,0.} #define VIEWSTR "VIEW=" +#define VIEWSTRL 5 + + +extern char *setview(VIEW *v); +extern void normaspect(double va, double *ap, int *xp, int *yp); +extern double viewray(FVECT orig, FVECT direc, VIEW *v, double x, double y); +extern void viewloc(FVECT ip, VIEW *v, FVECT p); +extern void pix2loc(RREAL loc[2], RESOLU *rp, int px, int py); +extern void loc2pix(int pp[2], RESOLU *rp, double lx, double ly); +extern int getviewopt(VIEW *v, int ac, char *av[]); +extern int sscanview(VIEW *vp, char *s); +extern void fprintview(VIEW *vp, FILE *fp); +extern char *viewopt(VIEW *vp); +extern int isview(char *s); +extern int viewfile(char *fname, VIEW *vp, RESOLU *rp); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_VIEW_H_ */ +
