root/radiance/ray/src/common/vars.h
Revision: 2.11
Committed: Thu Feb 6 21:45:00 2025 UTC (3 months, 1 week ago) by greg
perf: Made printing of variables a little neater; added CAPDATE to holo header
# User Rev Content
1 greg 2.11 /* RCSid $Id: vars.h,v 2.10 2023/06/10 15:49:55 greg Exp $ */
2 greg 2.1 /*
3     * Header for programs that load variable files.
4     */
5 schorsch 2.5 #ifndef _RAD_VARS_H_
6     #define _RAD_VARS_H_
7     #ifdef __cplusplus
8     extern "C" {
9     #endif
10 greg 2.3
11 schorsch 2.7 typedef struct variable_s {
12 greg 2.8 const char *name; /* variable name */
13 greg 2.1 short nick; /* # characters required for nickname */
14     short nass; /* # assignments made */
15     char *value; /* assigned value(s) */
16 schorsch 2.7 void (*fixval)(struct variable_s *); /* assignment checking function */
17 greg 2.1 } VARIABLE; /* a variable-value pair */
18
19     /**** The following variables should be declared by calling program ****/
20
21     extern int NVARS; /* total number of variables */
22
23     extern VARIABLE vv[]; /* variable-value pairs */
24
25     extern char *progname; /* global argv[0] from main */
26
27     extern int nowarn; /* global boolean to turn warnings off */
28
29     /**** The rest is declared in loadvars.c ****/
30
31     #define UPPER(c) ((c)&~0x20) /* ASCII trick */
32
33     #define vnam(vc) (vv[vc].name)
34     #define vdef(vc) (vv[vc].nass)
35     #define vval(vc) (vv[vc].value)
36     #define vint(vc) atoi(vval(vc))
37 greg 2.2 #define vflt(vc) atof(vval(vc))
38 greg 2.1 #define vlet(vc) UPPER(vval(vc)[0])
39     #define vscale vlet
40     #define vbool(vc) (vlet(vc)=='T')
41
42     #define HIGH 'H'
43     #define MEDIUM 'M'
44     #define LOW 'L'
45 greg 2.3
46
47 greg 2.8 extern void loadvars(const char *rfname);
48     extern int setvariable(const char *ass, VARIABLE *(*mv)(const char*));
49     extern VARIABLE *matchvar(const char *nam);
50 greg 2.3 extern char *nvalue(int vn, int n);
51     extern void checkvalues(void);
52     extern void onevalue(VARIABLE *vp);
53     extern void catvalues(VARIABLE *vp);
54     extern int badmatch(char *tv, char *cv);
55     extern void boolvalue(VARIABLE *vp);
56     extern void qualvalue(VARIABLE *vp);
57 greg 2.10 extern void strvalue(VARIABLE *vp);
58 greg 2.3 extern void intvalue(VARIABLE *vp);
59     extern void fltvalue(VARIABLE *vp);
60 greg 2.11 extern int singlevar(VARIABLE *vp);
61 greg 2.3 extern void printvars(FILE *fp);
62
63 schorsch 2.5 #ifdef __cplusplus
64     }
65 greg 2.3 #endif
66 schorsch 2.5 #endif /* _RAD_VARS_H_ */
