1 |
/* RCSid $Id: vars.h,v 2.9 2023/06/09 22:52:47 greg Exp $ */ |
2 |
3 |
* Header for programs that load variable files. |
4 |
5 |
#ifndef _RAD_VARS_H_ |
6 |
#define _RAD_VARS_H_ |
7 |
#ifdef __cplusplus |
8 |
extern "C" { |
9 |
#endif |
10 |
11 |
typedef struct variable_s { |
12 |
const char *name; /* variable name */ |
13 |
short nick; /* # characters required for nickname */ |
14 |
short nass; /* # assignments made */ |
15 |
char *value; /* assigned value(s) */ |
16 |
void (*fixval)(struct variable_s *); /* assignment checking function */ |
17 |
} VARIABLE; /* a variable-value pair */ |
18 |
19 |
/**** The following variables should be declared by calling program ****/ |
20 |
21 |
extern int NVARS; /* total number of variables */ |
22 |
23 |
extern VARIABLE vv[]; /* variable-value pairs */ |
24 |
25 |
extern char *progname; /* global argv[0] from main */ |
26 |
27 |
extern int nowarn; /* global boolean to turn warnings off */ |
28 |
29 |
/**** The rest is declared in loadvars.c ****/ |
30 |
31 |
#define UPPER(c) ((c)&~0x20) /* ASCII trick */ |
32 |
33 |
#define vnam(vc) (vv[vc].name) |
34 |
#define vdef(vc) (vv[vc].nass) |
35 |
#define vval(vc) (vv[vc].value) |
36 |
#define vint(vc) atoi(vval(vc)) |
37 |
#define vflt(vc) atof(vval(vc)) |
38 |
#define vlet(vc) UPPER(vval(vc)[0]) |
39 |
#define vscale vlet |
40 |
#define vbool(vc) (vlet(vc)=='T') |
41 |
42 |
#define HIGH 'H' |
43 |
#define MEDIUM 'M' |
44 |
#define LOW 'L' |
45 |
46 |
47 |
extern void loadvars(const char *rfname); |
48 |
extern int setvariable(const char *ass, VARIABLE *(*mv)(const char*)); |
49 |
extern VARIABLE *matchvar(const char *nam); |
50 |
extern char *nvalue(int vn, int n); |
51 |
extern void checkvalues(void); |
52 |
extern void onevalue(VARIABLE *vp); |
53 |
extern void catvalues(VARIABLE *vp); |
54 |
extern int badmatch(char *tv, char *cv); |
55 |
extern void boolvalue(VARIABLE *vp); |
56 |
extern void qualvalue(VARIABLE *vp); |
57 |
extern void strvalue(VARIABLE *vp); |
58 |
extern void intvalue(VARIABLE *vp); |
59 |
extern void fltvalue(VARIABLE *vp); |
60 |
extern void printvars(FILE *fp); |
61 |
62 |
63 |
64 |
#endif |
65 |
#endif /* _RAD_VARS_H_ */ |
