root/radiance/ray/src/common/vars.h
Revision: 2.5
Committed: Fri Jun 6 16:38:47 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.4: +11 -18 lines
*** empty log message ***
1 /* RCSid $Id: vars.h,v 2.4 2003/02/25 02:47:22 greg Exp $ */
2 /*
3 * Header for programs that load variable files.
4 */
5 #ifndef _RAD_VARS_H_
6 #define _RAD_VARS_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 #include "copyright.h"
12
13 typedef struct {
14 char *name; /* variable name */
15 short nick; /* # characters required for nickname */
16 short nass; /* # assignments made */
17 char *value; /* assigned value(s) */
18 void (*fixval)(); /* assignment checking function */
19 } VARIABLE; /* a variable-value pair */
20
21 /**** The following variables should be declared by calling program ****/
22
23 extern int NVARS; /* total number of variables */
24
25 extern VARIABLE vv[]; /* variable-value pairs */
26
27 extern char *progname; /* global argv[0] from main */
28
29 extern int nowarn; /* global boolean to turn warnings off */
30
31 /**** The rest is declared in loadvars.c ****/
32
33 extern VARIABLE *matchvar();
34 extern char *nvalue();
35
36 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
37
38 #define vnam(vc) (vv[vc].name)
39 #define vdef(vc) (vv[vc].nass)
40 #define vval(vc) (vv[vc].value)
41 #define vint(vc) atoi(vval(vc))
42 #define vflt(vc) atof(vval(vc))
43 #define vlet(vc) UPPER(vval(vc)[0])
44 #define vscale vlet
45 #define vbool(vc) (vlet(vc)=='T')
46
47 #define HIGH 'H'
48 #define MEDIUM 'M'
49 #define LOW 'L'
50
51
52 extern void loadvars(char *rfname);
53 extern int setvariable(char *ass, VARIABLE *(*mv)());
54 extern VARIABLE *matchvar(char *nam);
55 extern char *nvalue(int vn, int n);
56 extern void checkvalues(void);
57 extern void onevalue(VARIABLE *vp);
58 extern void catvalues(VARIABLE *vp);
59 extern int badmatch(char *tv, char *cv);
60 extern void boolvalue(VARIABLE *vp);
61 extern void qualvalue(VARIABLE *vp);
62 extern void intvalue(VARIABLE *vp);
63 extern void fltvalue(VARIABLE *vp);
64 extern void printvars(FILE *fp);
65
66
67 #ifdef __cplusplus
68 }
69 #endif
70 #endif /* _RAD_VARS_H_ */
71
