| 1 |
/* RCSid $Id$ */
| 2 |
| 3 |
* Header for programs that load variable files.
| 4 |
| 5 |
| 6 |
#include "copyright.h"
| 7 |
| 8 |
typedef struct {
| 9 |
char *name; /* variable name */
| 10 |
short nick; /* # characters required for nickname */
| 11 |
short nass; /* # assignments made */
| 12 |
char *value; /* assigned value(s) */
| 13 |
void (*fixval)(); /* assignment checking function */
| 14 |
} VARIABLE; /* a variable-value pair */
| 15 |
| 16 |
/**** The following variables should be declared by calling program ****/
| 17 |
| 18 |
extern int NVARS; /* total number of variables */
| 19 |
| 20 |
extern VARIABLE vv[]; /* variable-value pairs */
| 21 |
| 22 |
extern char *progname; /* global argv[0] from main */
| 23 |
| 24 |
extern int nowarn; /* global boolean to turn warnings off */
| 25 |
| 26 |
/**** The rest is declared in loadvars.c ****/
| 27 |
| 28 |
extern VARIABLE *matchvar();
| 29 |
extern char *nvalue();
| 30 |
| 31 |
#define UPPER(c) ((c)&~0x20) /* ASCII trick */
| 32 |
| 33 |
#define vnam(vc) (vv[vc].name)
| 34 |
#define vdef(vc) (vv[vc].nass)
| 35 |
#define vval(vc) (vv[vc].value)
| 36 |
#define vint(vc) atoi(vval(vc))
| 37 |
#define vflt(vc) atof(vval(vc))
| 38 |
#define vlet(vc) UPPER(vval(vc)[0])
| 39 |
#define vscale vlet
| 40 |
#define vbool(vc) (vlet(vc)=='T')
| 41 |
| 42 |
#define HIGH 'H'
| 43 |
#define MEDIUM 'M'
| 44 |
#define LOW 'L'
| 45 |
| 46 |
#ifdef NOPROTO
| 47 |
| 48 |
extern void loadvars();
| 49 |
extern int setvariable();
| 50 |
| 51 |
| 52 |
extern void checkvalues();
| 53 |
extern void onevalue();
| 54 |
extern void catvalues();
| 55 |
extern int badmatch();
| 56 |
extern void boolvalue();
| 57 |
extern void qualvalue();
| 58 |
extern void intvalue();
| 59 |
extern void fltvalue();
| 60 |
extern void printvars();
| 61 |
| 62 |
#else
| 63 |
| 64 |
extern void loadvars(char *rfname);
| 65 |
extern int setvariable(char *ass, VARIABLE *(*mv)());
| 66 |
extern VARIABLE *matchvar(char *nam);
| 67 |
extern char *nvalue(int vn, int n);
| 68 |
extern void checkvalues(void);
| 69 |
extern void onevalue(VARIABLE *vp);
| 70 |
extern void catvalues(VARIABLE *vp);
| 71 |
extern int badmatch(char *tv, char *cv);
| 72 |
extern void boolvalue(VARIABLE *vp);
| 73 |
extern void qualvalue(VARIABLE *vp);
| 74 |
extern void intvalue(VARIABLE *vp);
| 75 |
extern void fltvalue(VARIABLE *vp);
| 76 |
extern void printvars(FILE *fp);
| 77 |
| 78 |
#endif
