root/radiance/ray/src/common/urand.c
Thu Apr 21 15:22:30 2022 UTC (3 years, 1 month ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 2.13
fix: Better implementation of irandom()
Thu Apr 21 02:55:19 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.12: +3 -7 lines
Diff to previous 2.12
style: Beautifying last addition
Thu Apr 21 02:52:40 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.11: +20 -2 lines
perf(cnt): improved randomness of cnt -s option with new irandom(modulus) call
Wed May 27 08:42:06 2015 UTC (10 years ago) by greg
CVS Tags: rad5R0, rad5R1, rad5R2, rad5R3
Changes since 2.10: +11 -10 lines
Fixed includes and prototypes
Wed Apr 5 06:22:56 2006 UTC (19 years, 2 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Changes since 2.9: +11 -8 lines
Made -u+ option truly random
Sun May 16 14:49:42 2004 UTC (21 years ago) by greg
Fixed bug introduced in last change (serious)
Fri May 14 20:49:13 2004 UTC (21 years ago) by greg
Changes since 2.7: +9 -9 lines
Fixed bug in initialization of long random sequences
Sat Jun 7 12:50:21 2003 UTC (22 years ago) by schorsch
Tue Feb 25 02:47:22 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.4: +66 -10 lines
Mon Jan 5 16:47:37 1998 UTC (27 years, 5 months ago) by gregl
Changes since 2.3: +6 -4 lines
added check for too many urand values
Mon Dec 1 09:55:00 1997 UTC (27 years, 6 months ago) by gregl
Changes since 2.2: +4 -2 lines
Sat Sep 5 13:40:55 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.1: +4 -2 lines
added free call for multiple calls to initurand()
Tue Nov 12 16:55:47 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.7
Mon Aug 12 13:07:02 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.6: +0 -52 lines
Diff to previous 1.6
moved urind(3) from urand.c to urind.c and added peano.c
Thu Jul 11 16:25:58 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.5: +52 -0 lines
Diff to previous 1.5
added urind function for multi-dimensional sampling
Fri Jun 7 10:50:14 1991 UTC (34 years ago) by greg
Diff to previous 1.4
minor mods
Fri Jun 7 10:47:17 1991 UTC (34 years ago) by greg
Diff to previous 1.3
changed definition of hval for consistency in ilhash()
Tue May 21 11:01:00 1991 UTC (34 years ago) by greg
Changes since 1.2: +2 -3 lines
Diff to previous 1.2
added hash function
Fri May 17 13:51:14 1991 UTC (34 years ago) by greg
Changes since 1.1: +16 -0 lines
Diff to previous 1.1
added urhash() function
Fri May 17 12:55:27 1991 UTC (34 years ago) by greg
