--- ray/src/common/unix_process.c 2006/06/07 17:52:03 3.8 +++ ray/src/common/unix_process.c 2020/02/28 05:18:49 3.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: unix_process.c,v 3.8 2006/06/07 17:52:03 schorsch Exp $"; +static const char RCSid[] = "$Id: unix_process.c,v 3.16 2020/02/28 05:18:49 greg Exp $"; #endif /* * Routines to communicate with separate process via dual pipes @@ -10,80 +10,157 @@ static const char RCSid[] = "$Id: unix_process.c,v 3.8 #include "copyright.h" -#include #include -#include #include #include "rtprocess.h" #include "rtio.h" +SUBPROC sp_inactive = SP_INACTIVE; + + int open_process( /* open communication to separate process */ -SUBPROC *pd, -char *av[] + SUBPROC *pd, + char *av[] ) { char *compath; int p0[2], p1[2]; - pd->running = 0; /* not yet */ - /* find executable */ - compath = getpath(av[0], getenv("PATH"), 1); - if (compath == 0) + if (pd->pid > 0) + return(-1); /* need to close, first */ + + if ((pd->flags & (PF_FILT_INP|PF_FILT_OUT)) == (PF_FILT_INP|PF_FILT_OUT)) + return(-1); /* circular process not supported */ + + pd->flags &= ~PF_RUNNING; /* not running for sure */ + pd->pid = -1; + + if (av == NULL) /* cloning operation? */ + compath = NULL; + else if ((compath = getpath(av[0], getenv("PATH"), X_OK)) == NULL) return(0); - if (pipe(p0) < 0 || pipe(p1) < 0) + + if (pd->flags & PF_FILT_INP) { /* filterning input stream? */ + if ((pd->r < 0) | (pd->r == 1)) + return(-1); + p0[0] = pd->r; + p0[1] = -1; + } else if (pipe(p0) < 0) return(-1); - if ((pd->pid = fork()) == 0) { /* if child */ + + if (pd->flags & PF_FILT_OUT) { /* filtering output stream? */ + if (pd->w < 1) + return(-1); + p1[0] = -1; + p1[1] = pd->w; + } else if (pipe(p1) < 0) + return(-1); +#ifdef BSD + if (compath != NULL) + pd->pid = vfork(); /* more efficient with exec() */ + else +#endif + pd->pid = fork(); + if (pd->pid == 0) { /* if child... */ close(p0[1]); close(p1[0]); if (p0[0] != 0) { /* connect p0 to stdin */ - dup2(p0[0], 0); + if (dup2(p0[0], 0) < 0) + return(-1); close(p0[0]); } if (p1[1] != 1) { /* connect p1 to stdout */ - dup2(p1[1], 1); + if (dup2(p1[1], 1) < 0) + return(-1); close(p1[1]); } + if (compath == NULL) /* just cloning? */ + return(0); + /* else clear streams' FD_CLOEXEC */ + if (p0[0] == 0) + fcntl(0, F_SETFD, 0); + if (p1[1] == 1) + fcntl(1, F_SETFD, 0); execv(compath, av); /* exec command */ perror(compath); _exit(127); } if (pd->pid == -1) return(-1); - close(p0[0]); - close(p1[1]); - pd->r = p1[0]; - pd->w = p0[1]; + /* connect parent's streams */ + if (!(pd->flags & PF_FILT_INP)) { + close(p0[0]); + pd->r = p1[0]; + } else if (p1[0] != pd->r) { + if (dup2(p1[0], pd->r) < 0) + return(-1); + close(p1[0]); + } + if (!(pd->flags & PF_FILT_OUT)) { + close(p1[1]); + pd->w = p0[1]; + } else if (p0[1] != pd->w) { + if (dup2(p0[1], pd->w) < 0) + return(-1); + close(p0[1]); + } /* * Close write stream on exec to avoid multiprocessing deadlock. * No use in read stream without it, so set flag there as well. * GW: This bug took me two days to figure out!! */ - fcntl(pd->r, F_SETFD, FD_CLOEXEC); - fcntl(pd->w, F_SETFD, FD_CLOEXEC); - pd->running = 1; + if (pd->r >= 0) + fcntl(pd->r, F_SETFD, FD_CLOEXEC); + if (pd->w >= 0) + fcntl(pd->w, F_SETFD, FD_CLOEXEC); + pd->flags |= PF_RUNNING; return(PIPE_BUF); } - int -close_process( /* close pipes and wait for process */ -SUBPROC *pd +close_processes( /* close pipes and wait for processes to finish */ + SUBPROC pd[], + int nproc ) { - int status; + int togo = nproc; + int status, rtn_status = 0; + RT_PID pid; + int i; - if (!pd->running) - return(0); - close(pd->r); - close(pd->w); - pd->running = 0; - if (waitpid(pd->pid, &status, 0) == pd->pid) + for (i = 0; i < nproc; i++) /* close pipes, first */ + if (pd[i].flags & PF_RUNNING) { + close(pd[i].w); + close(pd[i].r); + pd[i].flags &= ~PF_RUNNING; + } else + togo -= (pd[i].pid < 0); + if (nproc == 1) { /* await specific process? */ + status = 0; + if (waitpid(pd->pid, &status, 0) != pd->pid) + return(-1); + *pd = sp_inactive; return(status>>8 & 0xff); - return(-1); /* ? unknown status */ + } + /* else unordered wait */ + while (togo > 0 && (pid = wait(&status)) >= 0) { + for (i = nproc; i-- > 0; ) + if (pd[i].pid == pid) { + pd[i] = sp_inactive; + --togo; + break; + } + if (i < 0) + continue; /* child we don't know? */ + status = status>>8 & 0xff; + if (status) /* record non-zero status */ + rtn_status = status; + } + if (togo) /* child went missing? */ + return(-1); + return(rtn_status); } - -
