root/radiance/ray/src/common/unix_process.c
Revision: 3.16
Committed: Fri Feb 28 05:18:49 2020 UTC (5 years, 5 months ago) by greg
Changes since 3.15: +68 -22 lines
2 static const char RCSid[] = "$Id: unix_process.c,v 3.15 2019/12/28 18:05:14 greg Exp $";
5 * Routines to communicate with separate process via dual pipes
6 * Unix version
7 *
8 * External symbols declared in standard.h
9 */
10
11 #include "copyright.h"
12
13 #include <sys/wait.h>
14 #include <stdlib.h>
15
16 #include "rtprocess.h"
17 #include "rtio.h"
18
19
20 SUBPROC sp_inactive = SP_INACTIVE;
21
22
23 int
24 open_process( /* open communication to separate process */
25 SUBPROC *pd,
26 char *av[]
27 )
28 {
29 char *compath;
30 int p0[2], p1[2];
31
32 if (pd->pid > 0)
33 return(-1); /* need to close, first */
34
35 if ((pd->flags & (PF_FILT_INP|PF_FILT_OUT)) == (PF_FILT_INP|PF_FILT_OUT))
36 return(-1); /* circular process not supported */
37
38 pd->flags &= ~PF_RUNNING; /* not running for sure */
39 pd->pid = -1;
40
41 if (av == NULL) /* cloning operation? */
42 compath = NULL;
43 else if ((compath = getpath(av[0], getenv("PATH"), X_OK)) == NULL)
44 return(0);
45
46 if (pd->flags & PF_FILT_INP) { /* filterning input stream? */
47 if ((pd->r < 0) | (pd->r == 1))
48 return(-1);
49 p0[0] = pd->r;
50 p0[1] = -1;
51 } else if (pipe(p0) < 0)
52 return(-1);
53
54 if (pd->flags & PF_FILT_OUT) { /* filtering output stream? */
55 if (pd->w < 1)
56 return(-1);
57 p1[0] = -1;
58 p1[1] = pd->w;
59 } else if (pipe(p1) < 0)
60 return(-1);
61 #ifdef BSD
62 if (compath != NULL)
63 pd->pid = vfork(); /* more efficient with exec() */
64 else
65 #endif
66 pd->pid = fork();
67 if (pd->pid == 0) { /* if child... */
68 close(p0[1]);
69 close(p1[0]);
70 if (p0[0] != 0) { /* connect p0 to stdin */
71 if (dup2(p0[0], 0) < 0)
72 return(-1);
73 close(p0[0]);
74 }
75 if (p1[1] != 1) { /* connect p1 to stdout */
76 if (dup2(p1[1], 1) < 0)
77 return(-1);
78 close(p1[1]);
79 }
80 if (compath == NULL) /* just cloning? */
81 return(0);
82 /* else clear streams' FD_CLOEXEC */
83 if (p0[0] == 0)
84 fcntl(0, F_SETFD, 0);
85 if (p1[1] == 1)
86 fcntl(1, F_SETFD, 0);
87 execv(compath, av); /* exec command */
88 perror(compath);
89 _exit(127);
90 }
91 if (pd->pid == -1)
92 return(-1);
93 /* connect parent's streams */
94 if (!(pd->flags & PF_FILT_INP)) {
95 close(p0[0]);
96 pd->r = p1[0];
97 } else if (p1[0] != pd->r) {
98 if (dup2(p1[0], pd->r) < 0)
99 return(-1);
100 close(p1[0]);
101 }
102 if (!(pd->flags & PF_FILT_OUT)) {
103 close(p1[1]);
104 pd->w = p0[1];
105 } else if (p0[1] != pd->w) {
106 if (dup2(p0[1], pd->w) < 0)
107 return(-1);
108 close(p0[1]);
109 }
110 /*
111 * Close write stream on exec to avoid multiprocessing deadlock.
112 * No use in read stream without it, so set flag there as well.
113 * GW: This bug took me two days to figure out!!
114 */
115 if (pd->r >= 0)
116 fcntl(pd->r, F_SETFD, FD_CLOEXEC);
117 if (pd->w >= 0)
118 fcntl(pd->w, F_SETFD, FD_CLOEXEC);
119 pd->flags |= PF_RUNNING;
120 return(PIPE_BUF);
121 }
122
123
124 int
125 close_processes( /* close pipes and wait for processes to finish */
126 SUBPROC pd[],
127 int nproc
128 )
129 {
130 int togo = nproc;
131 int status, rtn_status = 0;
132 RT_PID pid;
133 int i;
134
135 for (i = 0; i < nproc; i++) /* close pipes, first */
136 if (pd[i].flags & PF_RUNNING) {
137 close(pd[i].w);
138 close(pd[i].r);
139 pd[i].flags &= ~PF_RUNNING;
140 } else
141 togo -= (pd[i].pid < 0);
142 if (nproc == 1) { /* await specific process? */
143 status = 0;
144 if (waitpid(pd->pid, &status, 0) != pd->pid)
145 return(-1);
146 *pd = sp_inactive;
147 return(status>>8 & 0xff);
148 }
149 /* else unordered wait */
150 while (togo > 0 && (pid = wait(&status)) >= 0) {
151 for (i = nproc; i-- > 0; )
152 if (pd[i].pid == pid) {
153 pd[i] = sp_inactive;
154 --togo;
155 break;
156 }
157 if (i < 0)
158 continue; /* child we don't know? */
159 status = status>>8 & 0xff;
160 if (status) /* record non-zero status */
161 rtn_status = status;
162 }
163 if (togo) /* child went missing? */
164 return(-1);
165 return(rtn_status);
166 }
