root/radiance/ray/src/common/unix_process.c
Tue Jun 4 21:47:55 2024 UTC (13 months, 1 week ago) by greg
Changes since 3.18: +3 -3 lines
Diff to previous 3.18 , to selected 3.16
perf: minor optimization to avoid unnecessary system calls
Tue May 16 20:58:07 2023 UTC (2 years, 1 month ago) by greg
Changes since 3.17: +1 -6 lines
Diff to previous 3.17 , to selected 3.16
fix: removed deprecated call to vfork()
Mon Mar 2 19:06:48 2020 UTC (5 years, 4 months ago) by greg
Changes since 3.16: +4 -4 lines
Diff to previous 3.16
Don't close standard input or output descriptors on exec
Revision 3.16 - (view) (download) (annotate) - [selected]
Fri Feb 28 05:18:49 2020 UTC (5 years, 4 months ago) by greg
Changes since 3.15: +68 -22 lines
Diff to previous 3.15
Sat Dec 28 18:05:14 2019 UTC (5 years, 6 months ago) by greg
Changes since 3.14: +1 -3 lines
Diff to previous 3.14 , to selected 3.16
Tue May 14 18:37:36 2019 UTC (6 years, 2 months ago) by greg
Changes since 3.13: +8 -2 lines
Diff to previous 3.13 , to selected 3.16
Call vfork() if supported with exec()
Fri Mar 24 12:56:12 2017 UTC (8 years, 3 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 3.12: +3 -2 lines
Diff to previous 3.12 , to selected 3.16
Added case for already closed process in list
Fri Mar 4 19:16:49 2016 UTC (9 years, 4 months ago) by greg
Changes since 3.11: +4 -4 lines
Diff to previous 3.11 , to selected 3.16
Minor change should not affect anything
Fri Mar 4 02:48:14 2016 UTC (9 years, 4 months ago) by greg
Changes since 3.10: +38 -16 lines
Diff to previous 3.10 , to selected 3.16
Made quitting rvu, rholo and rcontrib quicker with multiple processes on Unix
Thu Jun 14 05:13:25 2012 UTC (13 years, 1 month ago) by greg
Changes since 3.9: +13 -10 lines
Diff to previous 3.9 , to selected 3.16
Simplified creation of child process
Sat Dec 12 23:08:13 2009 UTC (15 years, 7 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 3.8: +4 -3 lines
Diff to previous 3.8 , to selected 3.16
Bug fixes and performance improvements to rtrace -n option
Wed Jun 7 17:52:03 2006 UTC (19 years, 1 month ago) by schorsch
CVS Tags: rad3R8, rad3R9
Changes since 3.7: +2 -2 lines
Diff to previous 3.7 , to selected 3.16
Thu Jan 20 04:08:00 2005 UTC (20 years, 5 months ago) by greg
Changes since 3.6: +3 -2 lines
Diff to previous 3.6 , to selected 3.16
Minor dependency cleanup
Sun Sep 19 08:42:22 2004 UTC (20 years, 9 months ago) by greg
Changes since 3.5: +9 -1 lines
Diff to previous 3.5 , to selected 3.16
Fri Sep 17 21:43:49 2004 UTC (20 years, 9 months ago) by greg
Changes since 3.4: +5 -4 lines
Diff to previous 3.4 , to selected 3.16
Tue Nov 11 16:24:06 2003 UTC (21 years, 8 months ago) by greg
Changes since 3.3: +2 -2 lines
Diff to previous 3.3 , to selected 3.16
Mon Nov 10 16:41:52 2003 UTC (21 years, 8 months ago) by greg
Changes since 3.2: +1 -2 lines
Diff to previous 3.2 , to selected 3.16
Thu Jul 17 09:21:29 2003 UTC (22 years ago) by schorsch
Changes since 3.1: +4 -1 lines
Diff to previous 3.1 , to selected 3.16
Thu Jun 26 00:58:09 2003 UTC (22 years ago) by schorsch
Diff to selected 3.16
