root/Development/ray/src/common/unix_process.c
Revision: 3.20
Committed: Fri Oct 17 18:14:53 2025 UTC (2 weeks, 4 days ago) by greg
Changes since 3.19: +7 -9 lines
refactor: Minor code simplification
2 static const char RCSid[] = "$Id: unix_process.c,v 3.19 2024/06/04 21:47:55 greg Exp $";
5 * Routines to communicate with separate process via dual pipes
6 * Unix version
7 *
8 * External symbols declared in standard.h
9 */
10
11 #include "copyright.h"
12
13 #include <sys/wait.h>
14 #include <stdlib.h>
15
16 #include "rtprocess.h"
17 #include "rtio.h"
18
19
20 SUBPROC sp_inactive = SP_INACTIVE;
21
22
23 int
24 open_process( /* open communication to separate process */
25 SUBPROC *pd,
26 char *av[]
27 )
28 {
29 char *compath;
30 int p0[2], p1[2];
31
32 if (pd->pid > 0)
33 return(-1); /* need to close, first */
34
35 if ((pd->flags&(PF_FILT_INP|PF_FILT_OUT)) == (PF_FILT_INP|PF_FILT_OUT))
36 return(-1); /* circular process not supported */
37
38 pd->flags &= ~PF_RUNNING; /* not running for sure */
39 pd->pid = -1;
40
41 if (av == NULL) /* cloning operation? */
42 compath = NULL;
43 else if ((compath = getpath(av[0], getenv("PATH"), X_OK)) == NULL)
44 return(0);
45
46 if (pd->flags & PF_FILT_INP) { /* filterning input stream? */
47 if ((pd->r < 0) | (pd->r == 1))
48 return(-1);
49 p0[0] = pd->r;
50 p0[1] = -1;
51 } else if (pipe(p0) < 0)
52 return(-1);
53
54 if (pd->flags & PF_FILT_OUT) { /* filtering output stream? */
55 if (pd->w < 1)
56 return(-1);
57 p1[0] = -1;
58 p1[1] = pd->w;
59 } else if (pipe(p1) < 0)
60 return(-1);
61 pd->pid = fork();
62 if (pd->pid == 0) { /* if child... */
63 close(p0[1]);
64 close(p1[0]);
65 if (p0[0] != 0) { /* connect p0 to stdin */
66 if (dup2(p0[0], 0) < 0)
67 return(-1);
68 close(p0[0]);
69 }
70 if (p1[1] != 1) { /* connect p1 to stdout */
71 if (dup2(p1[1], 1) < 0)
72 return(-1);
73 close(p1[1]);
74 }
75 if (compath == NULL) /* just cloning? */
76 return(0);
77 /* else clear streams' FD_CLOEXEC */
78 if (p0[0] == 0)
79 fcntl(0, F_SETFD, 0);
80 if (p1[1] == 1)
81 fcntl(1, F_SETFD, 0);
82 execv(compath, av); /* exec command */
83 perror(compath);
84 _exit(127);
85 }
86 if (pd->pid == -1)
87 return(-1);
88 /* connect parent's streams */
89 if (!(pd->flags & PF_FILT_INP)) {
90 close(p0[0]);
91 pd->r = p1[0];
92 } else if (p1[0] != pd->r) {
93 if (dup2(p1[0], pd->r) < 0)
94 return(-1);
95 close(p1[0]);
96 }
97 if (!(pd->flags & PF_FILT_OUT)) {
98 close(p1[1]);
99 pd->w = p0[1];
100 } else if (p0[1] != pd->w) {
101 if (dup2(p0[1], pd->w) < 0)
102 return(-1);
103 close(p0[1]);
104 }
105 /*
106 * Close write stream on exec to avoid multiprocessing deadlock.
107 * No use in read stream without it, so set flag there as well.
108 * GW: This bug took me two days to figure out!!
109 */
110 if (pd->r > 0)
111 fcntl(pd->r, F_SETFD, FD_CLOEXEC);
112 if (pd->w > 1)
113 fcntl(pd->w, F_SETFD, FD_CLOEXEC);
114 pd->flags |= PF_RUNNING;
115 return(PIPE_BUF);
116 }
117
118
119 int
120 close_processes( /* close pipes and wait for processes to finish */
121 SUBPROC pd[],
122 int nproc
123 )
124 {
125 int togo = nproc;
126 int status = 0, rtn_status = 0;
127 RT_PID pid;
128 int i;
129
130 for (i = 0; i < nproc; i++) /* close pipes, first */
131 if (pd[i].flags & PF_RUNNING) {
132 if (pd[i].w >= 0) close(pd[i].w);
133 if (pd[i].r >= 0) close(pd[i].r);
134 pd[i].flags &= ~PF_RUNNING;
135 } else
136 togo -= (pd[i].pid < 0);
137 if (nproc == 1) { /* await specific process? */
138 if (waitpid(pd->pid, &status, 0) != pd->pid)
139 return(-1);
140 *pd = sp_inactive;
141 return(status>>8 & 0xff);
142 }
143 /* else unordered wait */
144 while (togo > 0 && (pid = wait(&status)) >= 0) {
145 for (i = nproc; i-- > 0; )
146 if (pd[i].pid == pid)
147 break; /* found it! */
148 if (i < 0)
149 continue; /* or child not in our list */
150 pd[i] = sp_inactive;
151 --togo;
152 status = status>>8 & 0xff;
153 if (status) /* record non-zero status */
154 rtn_status = status;
155 }
156 if (togo) /* child went missing? */
157 return(-1);
158 return(rtn_status);
159 }
