root/radiance/ray/src/common/triangulate.h
Revision: 2.1
Committed: Thu Jan 23 23:51:41 2014 UTC (10 years, 4 months ago) by greg
Added routines to triangulate polygons
1 /* RCSid $Id$ */
2 /*
3 * triangulate.h
4 *
5 * Adapted by Greg Ward on 1/23/14.
6 * Copyright 2014 Anyhere Software. All rights reserved.
7 *
8 */
9
10 /* COTD Entry submitted by John W. Ratcliff [[email protected]] */
11
12 /**** THIS IS A CODE SNIPPET WHICH WILL EFFICIEINTLY TRIANGULATE ANY
13 // ** POLYGON/CONTOUR (without holes) AS A STATIC CLASS. THIS SNIPPET
14 // ** IS COMPRISED OF 3 FILES, TRIANGULATE.H, THE HEADER FILE FOR THE
15 // ** TRIANGULATE BASE CLASS, TRIANGULATE.CPP, THE IMPLEMENTATION OF
16 // ** THE TRIANGULATE BASE CLASS, AND TEST.CPP, A SMALL TEST PROGRAM
17 // ** DEMONSTRATING THE USAGE OF THE TRIANGULATOR. THE TRIANGULATE
18 // ** BASE CLASS ALSO PROVIDES TWO USEFUL HELPER METHODS, ONE WHICH
19 // ** COMPUTES THE AREA OF A POLYGON, AND ANOTHER WHICH DOES AN EFFICENT
20 // ** POINT IN A TRIANGLE TEST.
21 // ** SUBMITTED BY JOHN W. RATCLIFF ([email protected]) July 22, 2000
22 */
23
24 /**********************************************************************/
25 /************ HEADER FILE FOR TRIANGULATE.C ***************************/
26 /**********************************************************************/
27
28 #ifndef TRIANGULATE_H
29 #define TRIANGULATE_H
30
31 #ifdef __cplusplus
32 extern "C" {
33 #endif
34
35 typedef struct {
36 double mX, mY;
37 } Vert2;
38
39 typedef struct {
40 int nv; /* number of vertices */
41 void *p; /* client data pointer */
42 Vert2 v[3]; /* extends struct */
43 } Vert2_list;
44
45 /* allocate a polygon list */
46 extern Vert2_list *polyAlloc(int nv);
47
48 #define polyFree free
49
50 /* callback for output triangle */
51 typedef void tri_out_t(const Vert2_list *tp, int a, int b, int c);
52
53 /* triangulate a contour/polygon, places results in STL vector
54 * as series of triangles. */
55 extern int polyTriangulate(const Vert2_list *contour, tri_out_t *cb);
56
57 /* compute area of a contour/polygon */
58 extern double polyArea(const Vert2_list *contour);
59
60 /* decide if point Px/Py is inside triangle defined by
61 * (Ax,Ay) (Bx,By) (Cx,Cy) */
62 extern int insideTriangle(double Ax, double Ay,
63 double Bx, double By,
64 double Cx, double Cy,
65 double Px, double Py);
66
67 #ifdef __cplusplus
68 }
69 #endif
70
71 #endif
