1 |
/* RCSid $Id: triangulate.h,v 2.1 2014/01/23 23:51:41 greg Exp $ */ |
2 |
3 |
* triangulate.h |
4 |
5 |
* Adapted by Greg Ward on 1/23/14. |
6 |
* Copyright 2014 Anyhere Software. All rights reserved. |
7 |
8 |
9 |
10 |
/* COTD Entry submitted by John W. Ratcliff [[email protected]] */ |
11 |
12 |
/**** THIS IS A CODE SNIPPET WHICH WILL EFFICIEINTLY TRIANGULATE ANY |
13 |
// ** POLYGON/CONTOUR (without holes) AS A STATIC CLASS. THIS SNIPPET |
14 |
// ** IS COMPRISED OF 3 FILES, TRIANGULATE.H, THE HEADER FILE FOR THE |
15 |
// ** TRIANGULATE BASE CLASS, TRIANGULATE.CPP, THE IMPLEMENTATION OF |
16 |
// ** THE TRIANGULATE BASE CLASS, AND TEST.CPP, A SMALL TEST PROGRAM |
17 |
// ** DEMONSTRATING THE USAGE OF THE TRIANGULATOR. THE TRIANGULATE |
18 |
// ** BASE CLASS ALSO PROVIDES TWO USEFUL HELPER METHODS, ONE WHICH |
19 |
// ** COMPUTES THE AREA OF A POLYGON, AND ANOTHER WHICH DOES AN EFFICENT |
20 |
// ** POINT IN A TRIANGLE TEST. |
21 |
// ** SUBMITTED BY JOHN W. RATCLIFF ([email protected]) July 22, 2000 |
22 |
23 |
24 |
25 |
/************ HEADER FILE FOR TRIANGULATE.C ***************************/ |
26 |
27 |
28 |
#ifndef TRIANGULATE_H |
29 |
#define TRIANGULATE_H |
30 |
31 |
#ifdef __cplusplus |
32 |
extern "C" { |
33 |
#endif |
34 |
35 |
typedef struct { |
36 |
double mX, mY; |
37 |
} Vert2; |
38 |
39 |
typedef struct { |
40 |
int nv; /* number of vertices */ |
41 |
void *p; /* client data pointer */ |
42 |
Vert2 v[3]; /* extends struct */ |
43 |
} Vert2_list; |
44 |
45 |
/* allocate a polygon list */ |
46 |
extern Vert2_list *polyAlloc(int nv); |
47 |
48 |
#define polyFree free |
49 |
50 |
/* callback for output triangle */ |
51 |
typedef int tri_out_t(const Vert2_list *tp, int a, int b, int c); |
52 |
53 |
/* triangulate a contour/polygon, places results in STL vector |
54 |
* as series of triangles. */ |
55 |
extern int polyTriangulate(const Vert2_list *contour, tri_out_t *cb); |
56 |
57 |
/* compute area of a contour/polygon */ |
58 |
extern double polyArea(const Vert2_list *contour); |
59 |
60 |
/* decide if point Px/Py is inside triangle defined by |
61 |
* (Ax,Ay) (Bx,By) (Cx,Cy) */ |
62 |
extern int insideTriangle(double Ax, double Ay, |
63 |
double Bx, double By, |
64 |
double Cx, double Cy, |
65 |
double Px, double Py); |
66 |
67 |
68 |
69 |
#endif |
70 |
71 |
#endif |
