root/radiance/ray/src/common/triangulate.c
Revision: 2.3
Committed: Fri Jan 24 02:22:49 2014 UTC (10 years, 3 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R2P1
Fixed bug in triangulation code
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.3 static const char RCSid[] = "$Id: triangulate.c,v 2.2 2014/01/24 01:26:44 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * triangulate.c
6     *
7     * Adapted by Greg Ward on 1/23/14.
8     * Copyright 2014 Anyhere Software. All rights reserved.
9     *
10     */
11
12     /* COTD Entry submitted by John W. Ratcliff [[email protected]]
13
14     // ** THIS IS A CODE SNIPPET WHICH WILL EFFICIEINTLY TRIANGULATE ANY
15     // ** POLYGON/CONTOUR (without holes) AS A STATIC CLASS. THIS SNIPPET
16     // ** IS COMPRISED OF 3 FILES, TRIANGULATE.H, THE HEADER FILE FOR THE
17     // ** TRIANGULATE BASE CLASS, TRIANGULATE.CPP, THE IMPLEMENTATION OF
18     // ** THE TRIANGULATE BASE CLASS, AND TEST.CPP, A SMALL TEST PROGRAM
19     // ** DEMONSTRATING THE USAGE OF THE TRIANGULATOR. THE TRIANGULATE
20     // ** BASE CLASS ALSO PROVIDES TWO USEFUL HELPER METHODS, ONE WHICH
21     // ** COMPUTES THE AREA OF A POLYGON, AND ANOTHER WHICH DOES AN EFFICENT
22     // ** POINT IN A TRIANGLE TEST.
23     // ** SUBMITTED BY JOHN W. RATCLIFF ([email protected]) July 22, 2000
24     */
25
26     #include <stdio.h>
27     #include <stdlib.h>
28     #include "triangulate.h"
29
30     #ifndef true
31     #define true 1
32     #define false 0
33     #endif
34
35     static const double EPSILON = 0.0000000001;
36
37     static int
38     polySnip(const Vert2_list *contour, int u, int v, int w, int n, int *V)
39     {
40     int p;
41     double Ax, Ay, Bx, By, Cx, Cy, Px, Py;
42
43     Ax = contour->v[V[u]].mX;
44     Ay = contour->v[V[u]].mY;
45
46     Bx = contour->v[V[v]].mX;
47     By = contour->v[V[v]].mY;
48
49     Cx = contour->v[V[w]].mX;
50     Cy = contour->v[V[w]].mY;
51
52     if ( EPSILON > (((Bx-Ax)*(Cy-Ay)) - ((By-Ay)*(Cx-Ax))) ) return false;
53
54     for (p=0;p<n;p++)
55     {
56 greg 2.3 if( (p == u) | (p == v) | (p == w) ) continue;
57 greg 2.1 Px = contour->v[V[p]].mX;
58     Py = contour->v[V[p]].mY;
59     if (insideTriangle(Ax,Ay,Bx,By,Cx,Cy,Px,Py)) return false;
60     }
61
62     return true;
63     }
64
65     Vert2_list *
66     polyAlloc(int nv)
67     {
68     Vert2_list *pnew;
69
70     if (nv < 3) return NULL;
71
72     pnew = (Vert2_list *)malloc(sizeof(Vert2_list) + sizeof(Vert2)*(nv-3));
73     if (pnew == NULL) return NULL;
74     pnew->nv = nv;
75     pnew->p = NULL;
76
77     return pnew;
78     }
79
80     double
81     polyArea(const Vert2_list *contour)
82     {
83     double A=0.0;
84     int p, q;
85
86     for(p = contour->nv-1, q = 0; q < contour->nv; p=q++)
87     {
88     A += contour->v[p].mX*contour->v[q].mY - contour->v[q].mX*contour->v[p].mY;
89     }
90     return A*0.5;
91     }
92
93     /*
94     InsideTriangle decides if a point P is Inside of the triangle
95     defined by A, B, C.
96     */
97     int
98     insideTriangle(double Ax, double Ay,
99     double Bx, double By,
100     double Cx, double Cy,
101     double Px, double Py)
102
103     {
104     double ax, ay, bx, by, cx, cy, apx, apy, bpx, bpy, cpx, cpy;
105     double cCROSSap, bCROSScp, aCROSSbp;
106
107     ax = Cx - Bx; ay = Cy - By;
108     bx = Ax - Cx; by = Ay - Cy;
109     cx = Bx - Ax; cy = By - Ay;
110     apx= Px - Ax; apy= Py - Ay;
111     bpx= Px - Bx; bpy= Py - By;
112     cpx= Px - Cx; cpy= Py - Cy;
113
114     aCROSSbp = ax*bpy - ay*bpx;
115     cCROSSap = cx*apy - cy*apx;
116     bCROSScp = bx*cpy - by*cpx;
117
118     return ((aCROSSbp >= 0.0) && (bCROSScp >= 0.0) && (cCROSSap >= 0.0));
119     };
120
121     int
122     polyTriangulate(const Vert2_list *contour, tri_out_t *cb)
123     {
124     /* allocate and initialize list of Vertices in polygon */
125
126     int nv, m, u, v, w, count;
127     int *V;
128
129     if ( contour->nv < 3 ) return false;
130
131     V = (int *)malloc(sizeof(int)*contour->nv);
132     if (V == NULL) return false;
133
134     /* we want a counter-clockwise polygon in V */
135
136 greg 2.2 if ( 0.0 < polyArea(contour) )
137 greg 2.1 for (v=0; v<contour->nv; v++) V[v] = v;
138     else
139     for(v=0; v<contour->nv; v++) V[v] = (contour->nv-1)-v;
140
141     nv = contour->nv;
142
143     /* remove nv-2 Vertices, creating 1 triangle every time */
144     count = 2*nv; /* error detection */
145
146     for(m=0, v=nv-1; nv>2; )
147     {
148     /* if we loop, it is probably a non-simple polygon */
149 greg 2.3 if (0 >= count--)
150 greg 2.1 {
151 greg 2.3 /* Triangulate: ERROR - probable bad polygon */
152 greg 2.1 return false;
153     }
154
155     /* three consecutive vertices in current polygon, <u,v,w> */
156     u = v ; if (nv <= u) u = 0; /* previous */
157     v = u+1; if (nv <= v) v = 0; /* new v */
158     w = v+1; if (nv <= w) w = 0; /* next */
159
160     if ( polySnip(contour,u,v,w,nv,V) )
161     {
162     int a,b,c,s,t;
163
164     /* true names of the vertices */
165     a = V[u]; b = V[v]; c = V[w];
166
167     /* output Triangle */
168 greg 2.2 if (!(*cb)(contour, a, b, c)) return false;
169 greg 2.1
170     m++;
171
172     /* remove v from remaining polygon */
173     for(s=v,t=v+1;t<nv;s++,t++) V[s] = V[t]; nv--;
174
175 greg 2.3 /* reset error detection counter */
176 greg 2.1 count = 2*nv;
177     }
178     }
179
180     free(V);
181
182     return true;
183     }
