1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: triangulate.c,v 2.5 2016/12/22 18:50:48 greg Exp $"; |
3 |
#endif |
4 |
5 |
* triangulate.c |
6 |
7 |
* Adapted by Greg Ward on 1/23/14. |
8 |
* Fixes for polygons with seams/holes and co-linear vertices added |
9 |
* by Nathaniel Jones on 12/21/16. |
10 |
* Copyright 2016 Anyhere Software. All rights reserved. |
11 |
12 |
13 |
14 |
/* COTD Entry submitted by John W. Ratcliff [[email protected]] |
15 |
16 |
// ** THIS IS A CODE SNIPPET WHICH WILL EFFICIEINTLY TRIANGULATE ANY |
17 |
// ** POLYGON/CONTOUR (without holes) AS A STATIC CLASS. THIS SNIPPET |
18 |
// ** IS COMPRISED OF 3 FILES, TRIANGULATE.H, THE HEADER FILE FOR THE |
19 |
// ** TRIANGULATE BASE CLASS, TRIANGULATE.CPP, THE IMPLEMENTATION OF |
20 |
// ** THE TRIANGULATE BASE CLASS, AND TEST.CPP, A SMALL TEST PROGRAM |
21 |
// ** DEMONSTRATING THE USAGE OF THE TRIANGULATOR. THE TRIANGULATE |
22 |
// ** BASE CLASS ALSO PROVIDES TWO USEFUL HELPER METHODS, ONE WHICH |
23 |
// ** COMPUTES THE AREA OF A POLYGON, AND ANOTHER WHICH DOES AN EFFICENT |
24 |
// ** POINT IN A TRIANGLE TEST. |
25 |
// ** SUBMITTED BY JOHN W. RATCLIFF ([email protected]) July 22, 2000 |
26 |
27 |
28 |
#include <stdio.h> |
29 |
#include <stdlib.h> |
30 |
#include "triangulate.h" |
31 |
32 |
#ifndef true |
33 |
#define true 1 |
34 |
#define false 0 |
35 |
#endif |
36 |
37 |
#define EPSILON 0.0000000001 |
38 |
39 |
static int |
40 |
polySnip(const Vert2_list *contour, int u, int v, int w, int n, int *V) |
41 |
42 |
int p; |
43 |
double Ax, Ay, Bx, By, Cx, Cy, Px, Py, cross; |
44 |
45 |
Ax = contour->v[V[u]].mX; |
46 |
Ay = contour->v[V[u]].mY; |
47 |
48 |
Bx = contour->v[V[v]].mX; |
49 |
By = contour->v[V[v]].mY; |
50 |
51 |
Cx = contour->v[V[w]].mX; |
52 |
Cy = contour->v[V[w]].mY; |
53 |
54 |
cross = ((Bx - Ax)*(Cy - Ay)) - ((By - Ay)*(Cx - Ax)); |
55 |
if (cross < EPSILON) |
56 |
return cross < -EPSILON ? -1 : false; /* Negative if colinear points */ |
57 |
58 |
for (p=0;p<n;p++) |
59 |
60 |
if( (p == u) | (p == v) | (p == w) ) continue; |
61 |
Px = contour->v[V[p]].mX; |
62 |
Py = contour->v[V[p]].mY; |
63 |
if ((Px == Ax) & (Py == Ay) || (Px == Bx) & (Py == By) || |
64 |
(Px == Cx) & (Py == Cy)) continue; /* Handle donuts */ |
65 |
if (insideTriangle(Ax,Ay,Bx,By,Cx,Cy,Px,Py)) return false; |
66 |
67 |
68 |
return true; |
69 |
70 |
71 |
Vert2_list * |
72 |
polyAlloc(int nv) |
73 |
74 |
Vert2_list *pnew; |
75 |
76 |
if (nv < 3) return NULL; |
77 |
78 |
pnew = (Vert2_list *)malloc(sizeof(Vert2_list) + sizeof(Vert2)*(nv-3)); |
79 |
if (pnew == NULL) return NULL; |
80 |
pnew->nv = nv; |
81 |
pnew->p = NULL; |
82 |
83 |
return pnew; |
84 |
85 |
86 |
87 |
Area is positive if vertices listed counter-clockwise, negative if clockwise |
88 |
89 |
double |
90 |
polyArea(const Vert2_list *contour) |
91 |
92 |
double A=0.0; |
93 |
int p, q; |
94 |
95 |
for(p = contour->nv-1, q = 0; q < contour->nv; p=q++) |
96 |
97 |
A += contour->v[p].mX*contour->v[q].mY - contour->v[q].mX*contour->v[p].mY; |
98 |
99 |
return A*0.5; |
100 |
101 |
102 |
103 |
InsideTriangle decides if a point P is Inside of the triangle |
104 |
defined by A, B, C. |
105 |
106 |
int |
107 |
insideTriangle(double Ax, double Ay, |
108 |
double Bx, double By, |
109 |
double Cx, double Cy, |
110 |
double Px, double Py) |
111 |
112 |
double ax, ay, bx, by, cx, cy, apx, apy, bpx, bpy, cpx, cpy; |
113 |
double cCROSSap, bCROSScp, aCROSSbp; |
114 |
115 |
ax = Cx - Bx; ay = Cy - By; |
116 |
bx = Ax - Cx; by = Ay - Cy; |
117 |
cx = Bx - Ax; cy = By - Ay; |
118 |
apx= Px - Ax; apy= Py - Ay; |
119 |
bpx= Px - Bx; bpy= Py - By; |
120 |
cpx= Px - Cx; cpy= Py - Cy; |
121 |
122 |
aCROSSbp = ax*bpy - ay*bpx; |
123 |
cCROSSap = cx*apy - cy*apx; |
124 |
bCROSScp = bx*cpy - by*cpx; |
125 |
126 |
return ((aCROSSbp >= 0.0) & (bCROSScp >= 0.0) & (cCROSSap >= 0.0)); |
127 |
128 |
129 |
int |
130 |
polyTriangulate(const Vert2_list *contour, tri_out_t *cb) |
131 |
132 |
/* allocate and initialize list of Vertices in polygon */ |
133 |
134 |
int nv, u, v, w, count, result; |
135 |
int *V; |
136 |
137 |
if ( contour->nv < 3 ) return false; |
138 |
139 |
V = (int *)malloc(sizeof(int)*contour->nv); |
140 |
if (V == NULL) return false; |
141 |
142 |
/* we want a counter-clockwise polygon in V */ |
143 |
144 |
if ( polyArea(contour) > 0.0 ) |
145 |
for (v=0; v<contour->nv; v++) V[v] = v; |
146 |
else |
147 |
for (v=0; v<contour->nv; v++) V[v] = (contour->nv-1)-v; |
148 |
149 |
nv = contour->nv; |
150 |
151 |
/* remove nv-2 Vertices, creating 1 triangle every time */ |
152 |
count = 2*nv; /* error detection */ |
153 |
154 |
v = nv-1; |
155 |
while (nv > 2) |
156 |
157 |
/* if we loop, it is probably a non-simple polygon */ |
158 |
if (count-- <= 0) |
159 |
160 |
/* Triangulate: ERROR - probable bad polygon */ |
161 |
free(V); |
162 |
return false; |
163 |
164 |
165 |
/* three consecutive vertices in current polygon, <u,v,w> */ |
166 |
u = v ; u *= (nv > u); /* previous */ |
167 |
v = u+1; v *= (nv > v); /* new v */ |
168 |
w = v+1; w *= (nv > w); /* next */ |
169 |
170 |
result = polySnip(contour, u, v, w, nv, V); |
171 |
if (result > 0) /* successfully found a triangle */ |
172 |
173 |
/* output Triangle */ |
174 |
if (!(*cb)(contour, V[u], V[v], V[w])) { |
175 |
free(V); |
176 |
return false; |
177 |
178 |
179 |
if (result) /* successfully found a triangle or three consecutive colinear points */ |
180 |
181 |
int s,t; |
182 |
183 |
/* remove v from remaining polygon */ |
184 |
for(s=v,t=v+1;t<nv;s++,t++) V[s] = V[t]; nv--; |
185 |
186 |
/* reset error detection counter */ |
187 |
count = 2*nv; |
188 |
189 |
190 |
191 |
free(V); |
192 |
193 |
return true; |
194 |
