| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: triangulate.c,v 2.4 2016/12/22 18:48:36 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* triangulate.c
| 6 |
| 7 |
* Adapted by Greg Ward on 1/23/14.
| 8 |
* Fixes for polygons with seams/holes and co-linear vertices added
| 9 |
* by Nathaniel Jones on 12/21/16.
| 10 |
* Copyright 2016 Anyhere Software. All rights reserved.
| 11 |
| 12 |
| 13 |
| 14 |
/* COTD Entry submitted by John W. Ratcliff [[email protected]]
| 15 |
| 16 |
// ** THIS IS A CODE SNIPPET WHICH WILL EFFICIEINTLY TRIANGULATE ANY
| 17 |
// ** POLYGON/CONTOUR (without holes) AS A STATIC CLASS. THIS SNIPPET
| 18 |
// ** IS COMPRISED OF 3 FILES, TRIANGULATE.H, THE HEADER FILE FOR THE
| 19 |
// ** TRIANGULATE BASE CLASS, TRIANGULATE.CPP, THE IMPLEMENTATION OF
| 20 |
// ** THE TRIANGULATE BASE CLASS, AND TEST.CPP, A SMALL TEST PROGRAM
| 21 |
// ** DEMONSTRATING THE USAGE OF THE TRIANGULATOR. THE TRIANGULATE
| 22 |
// ** BASE CLASS ALSO PROVIDES TWO USEFUL HELPER METHODS, ONE WHICH
| 23 |
// ** COMPUTES THE AREA OF A POLYGON, AND ANOTHER WHICH DOES AN EFFICENT
| 24 |
// ** POINT IN A TRIANGLE TEST.
| 25 |
// ** SUBMITTED BY JOHN W. RATCLIFF ([email protected]) July 22, 2000
| 26 |
| 27 |
| 28 |
#include <stdio.h>
| 29 |
#include <stdlib.h>
| 30 |
#include "triangulate.h"
| 31 |
| 32 |
#ifndef true
| 33 |
#define true 1
| 34 |
#define false 0
| 35 |
#endif
| 36 |
| 37 |
static const double EPSILON = 0.0000000001;
| 38 |
| 39 |
static int
| 40 |
polySnip(const Vert2_list *contour, int u, int v, int w, int n, int *V)
| 41 |
| 42 |
int p;
| 43 |
double Ax, Ay, Bx, By, Cx, Cy, Px, Py, cross;
| 44 |
| 45 |
Ax = contour->v[V[u]].mX;
| 46 |
Ay = contour->v[V[u]].mY;
| 47 |
| 48 |
Bx = contour->v[V[v]].mX;
| 49 |
By = contour->v[V[v]].mY;
| 50 |
| 51 |
Cx = contour->v[V[w]].mX;
| 52 |
Cy = contour->v[V[w]].mY;
| 53 |
| 54 |
cross = ((Bx - Ax)*(Cy - Ay)) - ((By - Ay)*(Cx - Ax));
| 55 |
if (EPSILON > cross) return EPSILON > -cross ? -1 : false; /* Negative if colinear points */
| 56 |
| 57 |
for (p=0;p<n;p++)
| 58 |
| 59 |
if( (p == u) | (p == v) | (p == w) ) continue;
| 60 |
Px = contour->v[V[p]].mX;
| 61 |
Py = contour->v[V[p]].mY;
| 62 |
if ((Px == Ax && Py == Ay) || (Px == Bx && Py == By) ||
| 63 |
(Px == Cx && Py == Cy)) continue; /* Handle donuts */
| 64 |
if (insideTriangle(Ax,Ay,Bx,By,Cx,Cy,Px,Py)) return false;
| 65 |
| 66 |
| 67 |
return true;
| 68 |
| 69 |
| 70 |
Vert2_list *
| 71 |
polyAlloc(int nv)
| 72 |
| 73 |
Vert2_list *pnew;
| 74 |
| 75 |
if (nv < 3) return NULL;
| 76 |
| 77 |
pnew = (Vert2_list *)malloc(sizeof(Vert2_list) + sizeof(Vert2)*(nv-3));
| 78 |
if (pnew == NULL) return NULL;
| 79 |
pnew->nv = nv;
| 80 |
pnew->p = NULL;
| 81 |
| 82 |
return pnew;
| 83 |
| 84 |
| 85 |
double
| 86 |
polyArea(const Vert2_list *contour)
| 87 |
| 88 |
double A=0.0;
| 89 |
int p, q;
| 90 |
| 91 |
for(p = contour->nv-1, q = 0; q < contour->nv; p=q++)
| 92 |
| 93 |
A += contour->v[p].mX*contour->v[q].mY - contour->v[q].mX*contour->v[p].mY;
| 94 |
| 95 |
return A*0.5;
| 96 |
| 97 |
| 98 |
| 99 |
InsideTriangle decides if a point P is Inside of the triangle
| 100 |
defined by A, B, C.
| 101 |
| 102 |
int
| 103 |
insideTriangle(double Ax, double Ay,
| 104 |
double Bx, double By,
| 105 |
double Cx, double Cy,
| 106 |
double Px, double Py)
| 107 |
| 108 |
| 109 |
double ax, ay, bx, by, cx, cy, apx, apy, bpx, bpy, cpx, cpy;
| 110 |
double cCROSSap, bCROSScp, aCROSSbp;
| 111 |
| 112 |
ax = Cx - Bx; ay = Cy - By;
| 113 |
bx = Ax - Cx; by = Ay - Cy;
| 114 |
cx = Bx - Ax; cy = By - Ay;
| 115 |
apx= Px - Ax; apy= Py - Ay;
| 116 |
bpx= Px - Bx; bpy= Py - By;
| 117 |
cpx= Px - Cx; cpy= Py - Cy;
| 118 |
| 119 |
aCROSSbp = ax*bpy - ay*bpx;
| 120 |
cCROSSap = cx*apy - cy*apx;
| 121 |
bCROSScp = bx*cpy - by*cpx;
| 122 |
| 123 |
return ((aCROSSbp >= 0.0) && (bCROSScp >= 0.0) && (cCROSSap >= 0.0));
| 124 |
| 125 |
| 126 |
int
| 127 |
polyTriangulate(const Vert2_list *contour, tri_out_t *cb)
| 128 |
| 129 |
/* allocate and initialize list of Vertices in polygon */
| 130 |
| 131 |
int nv, m, u, v, w, count, result;
| 132 |
int *V;
| 133 |
| 134 |
if ( contour->nv < 3 ) return false;
| 135 |
| 136 |
V = (int *)malloc(sizeof(int)*contour->nv);
| 137 |
if (V == NULL) return false;
| 138 |
| 139 |
/* we want a counter-clockwise polygon in V */
| 140 |
| 141 |
if ( 0.0 < polyArea(contour) )
| 142 |
for (v=0; v<contour->nv; v++) V[v] = v;
| 143 |
else
| 144 |
for(v=0; v<contour->nv; v++) V[v] = (contour->nv-1)-v;
| 145 |
| 146 |
nv = contour->nv;
| 147 |
| 148 |
/* remove nv-2 Vertices, creating 1 triangle every time */
| 149 |
count = 2*nv; /* error detection */
| 150 |
| 151 |
for(m=0, v=nv-1; nv>2; )
| 152 |
| 153 |
/* if we loop, it is probably a non-simple polygon */
| 154 |
if (0 >= count--)
| 155 |
| 156 |
/* Triangulate: ERROR - probable bad polygon */
| 157 |
return false;
| 158 |
| 159 |
| 160 |
/* three consecutive vertices in current polygon, <u,v,w> */
| 161 |
u = v ; if (nv <= u) u = 0; /* previous */
| 162 |
v = u+1; if (nv <= v) v = 0; /* new v */
| 163 |
w = v+1; if (nv <= w) w = 0; /* next */
| 164 |
| 165 |
result = polySnip(contour, u, v, w, nv, V);
| 166 |
if (result > 0) /* successfully found a triangle */
| 167 |
| 168 |
int a,b,c;
| 169 |
| 170 |
/* true names of the vertices */
| 171 |
a = V[u]; b = V[v]; c = V[w];
| 172 |
| 173 |
/* output Triangle */
| 174 |
if (!(*cb)(contour, a, b, c)) return false;
| 175 |
| 176 |
m++;
| 177 |
| 178 |
if (result) /* successfully found a triangle or three consecutive colinear points */
| 179 |
| 180 |
int s,t;
| 181 |
| 182 |
/* remove v from remaining polygon */
| 183 |
for(s=v,t=v+1;t<nv;s++,t++) V[s] = V[t]; nv--;
| 184 |
| 185 |
/* reset error detection counter */
| 186 |
count = 2*nv;
| 187 |
| 188 |
| 189 |
| 190 |
free(V);
| 191 |
| 192 |
return true;
| 193 |
