--- ray/src/common/triangulate.c 2014/01/24 02:22:49 2.3 +++ ray/src/common/triangulate.c 2021/04/19 20:37:04 2.7 @@ -1,11 +1,13 @@ #ifndef lint -static const char RCSid[] = "$Id: triangulate.c,v 2.3 2014/01/24 02:22:49 greg Exp $"; +static const char RCSid[] = "$Id: triangulate.c,v 2.7 2021/04/19 20:37:04 greg Exp $"; #endif /* * triangulate.c * * Adapted by Greg Ward on 1/23/14. - * Copyright 2014 Anyhere Software. All rights reserved. + * Fixes for polygons with seams/holes and co-linear vertices added + * by Nathaniel Jones on 12/21/16. + * Copyright 2016 Anyhere Software. All rights reserved. * */ @@ -32,13 +34,13 @@ static const char RCSid[] = "$Id: triangulate.c,v 2.3 #define false 0 #endif -static const double EPSILON = 0.0000000001; +#define EPSILON 0.0000000001 static int polySnip(const Vert2_list *contour, int u, int v, int w, int n, int *V) { int p; - double Ax, Ay, Bx, By, Cx, Cy, Px, Py; + double Ax, Ay, Bx, By, Cx, Cy, Px, Py, cross; Ax = contour->v[V[u]].mX; Ay = contour->v[V[u]].mY; @@ -49,13 +51,17 @@ polySnip(const Vert2_list *contour, int u, int v, int Cx = contour->v[V[w]].mX; Cy = contour->v[V[w]].mY; - if ( EPSILON > (((Bx-Ax)*(Cy-Ay)) - ((By-Ay)*(Cx-Ax))) ) return false; + cross = ((Bx - Ax)*(Cy - Ay)) - ((By - Ay)*(Cx - Ax)); + if (cross < EPSILON) + return cross > -EPSILON ? -1 : false; /* Negative if colinear points */ for (p=0;pv[V[p]].mX; Py = contour->v[V[p]].mY; + if ((Px == Ax) & (Py == Ay) || (Px == Bx) & (Py == By) || + (Px == Cx) & (Py == Cy)) continue; /* Handle donuts */ if (insideTriangle(Ax,Ay,Bx,By,Cx,Cy,Px,Py)) return false; } @@ -77,6 +83,9 @@ polyAlloc(int nv) return pnew; } +/* + Area is positive if vertices listed counter-clockwise, negative if clockwise + */ double polyArea(const Vert2_list *contour) { @@ -99,7 +108,6 @@ insideTriangle(double Ax, double Ay, double Bx, double By, double Cx, double Cy, double Px, double Py) - { double ax, ay, bx, by, cx, cy, apx, apy, bpx, bpy, cpx, cpy; double cCROSSap, bCROSScp, aCROSSbp; @@ -115,7 +123,7 @@ insideTriangle(double Ax, double Ay, cCROSSap = cx*apy - cy*apx; bCROSScp = bx*cpy - by*cpx; - return ((aCROSSbp >= 0.0) && (bCROSScp >= 0.0) && (cCROSSap >= 0.0)); + return ((aCROSSbp >= 0.0) & (bCROSScp >= 0.0) & (cCROSSap >= 0.0)); }; int @@ -123,7 +131,7 @@ polyTriangulate(const Vert2_list *contour, tri_out_t * { /* allocate and initialize list of Vertices in polygon */ - int nv, m, u, v, w, count; + int nv, u, v, w, count, result; int *V; if ( contour->nv < 3 ) return false; @@ -133,41 +141,44 @@ polyTriangulate(const Vert2_list *contour, tri_out_t * /* we want a counter-clockwise polygon in V */ - if ( 0.0 < polyArea(contour) ) + if ( polyArea(contour) > 0.0 ) for (v=0; vnv; v++) V[v] = v; else - for(v=0; vnv; v++) V[v] = (contour->nv-1)-v; + for (v=0; vnv; v++) V[v] = (contour->nv-1)-v; nv = contour->nv; /* remove nv-2 Vertices, creating 1 triangle every time */ count = 2*nv; /* error detection */ - for(m=0, v=nv-1; nv>2; ) + v = nv-1; + while (nv > 2) { /* if we loop, it is probably a non-simple polygon */ - if (0 >= count--) + if (count-- <= 0) { /* Triangulate: ERROR - probable bad polygon */ + free(V); return false; } /* three consecutive vertices in current polygon, */ - u = v ; if (nv <= u) u = 0; /* previous */ - v = u+1; if (nv <= v) v = 0; /* new v */ - w = v+1; if (nv <= w) w = 0; /* next */ + u = v ; u *= (nv > u); /* previous */ + v = u+1; v *= (nv > v); /* new v */ + w = v+1; w *= (nv > w); /* next */ - if ( polySnip(contour,u,v,w,nv,V) ) + result = polySnip(contour, u, v, w, nv, V); + if (result > 0) /* successfully found a triangle */ { - int a,b,c,s,t; - - /* true names of the vertices */ - a = V[u]; b = V[v]; c = V[w]; - /* output Triangle */ - if (!(*cb)(contour, a, b, c)) return false; - - m++; + if (!(*cb)(contour, V[u], V[v], V[w])) { + free(V); + return false; + } + } + if (result) /* successfully found a triangle or three consecutive colinear points */ + { + int s,t; /* remove v from remaining polygon */ for(s=v,t=v+1;t
