root/radiance/ray/src/common/triangulate.c
Mon Apr 19 20:37:04 2021 UTC (4 years, 3 months ago) by greg
fix: Repaired issue in last change with colinear vertices
Mon Apr 19 19:40:03 2021 UTC (4 years, 3 months ago) by greg
Changes since 2.5: +24 -23 lines
fix(genbox): Fixed issue with reversed triangles
Thu Dec 22 18:50:48 2016 UTC (8 years, 7 months ago) by greg
Added comment regarding last change.
Thu Dec 22 18:48:36 2016 UTC (8 years, 7 months ago) by greg
Changes since 2.3: +14 -6 lines
Fixes from Nathaniel Jones for co-linear vertices and seams/holes
Fri Jan 24 02:22:49 2014 UTC (11 years, 6 months ago) by greg
Fixed bug in triangulation code
Fri Jan 24 01:26:44 2014 UTC (11 years, 6 months ago) by greg
Thu Jan 23 23:51:41 2014 UTC (11 years, 6 months ago) by greg
Diff to selected 2.4
Added routines to triangulate polygons
