root/Development/ray/src/common/triangulate.c
Revision: 2.3
Committed: Fri Jan 24 02:22:49 2014 UTC (11 years, 10 months ago) by greg
CVS Tags: rad5R0, rad4R2P2, rad4R2P1, rad4R2
Fixed bug in triangulation code
2 static const char RCSid[] = "$Id: triangulate.c,v 2.2 2014/01/24 01:26:44 greg Exp $";
5 * triangulate.c
6 *
7 * Adapted by Greg Ward on 1/23/14.
8 * Copyright 2014 Anyhere Software. All rights reserved.
9 *
10 */
11
12 /* COTD Entry submitted by John W. Ratcliff [[email protected]]
13
14 // ** THIS IS A CODE SNIPPET WHICH WILL EFFICIEINTLY TRIANGULATE ANY
15 // ** POLYGON/CONTOUR (without holes) AS A STATIC CLASS. THIS SNIPPET
16 // ** IS COMPRISED OF 3 FILES, TRIANGULATE.H, THE HEADER FILE FOR THE
17 // ** TRIANGULATE BASE CLASS, TRIANGULATE.CPP, THE IMPLEMENTATION OF
18 // ** THE TRIANGULATE BASE CLASS, AND TEST.CPP, A SMALL TEST PROGRAM
19 // ** DEMONSTRATING THE USAGE OF THE TRIANGULATOR. THE TRIANGULATE
20 // ** BASE CLASS ALSO PROVIDES TWO USEFUL HELPER METHODS, ONE WHICH
21 // ** COMPUTES THE AREA OF A POLYGON, AND ANOTHER WHICH DOES AN EFFICENT
22 // ** POINT IN A TRIANGLE TEST.
23 // ** SUBMITTED BY JOHN W. RATCLIFF ([email protected]) July 22, 2000
24 */
25
26 #include <stdio.h>
27 #include <stdlib.h>
28 #include "triangulate.h"
29
30 #ifndef true
31 #define true 1
32 #define false 0
33 #endif
34
35 static const double EPSILON = 0.0000000001;
36
37 static int
38 polySnip(const Vert2_list *contour, int u, int v, int w, int n, int *V)
39 {
40 int p;
41 double Ax, Ay, Bx, By, Cx, Cy, Px, Py;
42
43 Ax = contour->v[V[u]].mX;
44 Ay = contour->v[V[u]].mY;
45
46 Bx = contour->v[V[v]].mX;
47 By = contour->v[V[v]].mY;
48
49 Cx = contour->v[V[w]].mX;
50 Cy = contour->v[V[w]].mY;
51
52 if ( EPSILON > (((Bx-Ax)*(Cy-Ay)) - ((By-Ay)*(Cx-Ax))) ) return false;
53
54 for (p=0;p<n;p++)
55 {
56 if( (p == u) | (p == v) | (p == w) ) continue;
57 Px = contour->v[V[p]].mX;
58 Py = contour->v[V[p]].mY;
59 if (insideTriangle(Ax,Ay,Bx,By,Cx,Cy,Px,Py)) return false;
60 }
61
62 return true;
63 }
64
65 Vert2_list *
66 polyAlloc(int nv)
67 {
68 Vert2_list *pnew;
69
70 if (nv < 3) return NULL;
71
72 pnew = (Vert2_list *)malloc(sizeof(Vert2_list) + sizeof(Vert2)*(nv-3));
73 if (pnew == NULL) return NULL;
74 pnew->nv = nv;
75 pnew->p = NULL;
76
77 return pnew;
78 }
79
80 double
81 polyArea(const Vert2_list *contour)
82 {
83 double A=0.0;
84 int p, q;
85
86 for(p = contour->nv-1, q = 0; q < contour->nv; p=q++)
87 {
88 A += contour->v[p].mX*contour->v[q].mY - contour->v[q].mX*contour->v[p].mY;
89 }
90 return A*0.5;
91 }
92
93 /*
94 InsideTriangle decides if a point P is Inside of the triangle
95 defined by A, B, C.
96 */
97 int
98 insideTriangle(double Ax, double Ay,
99 double Bx, double By,
100 double Cx, double Cy,
101 double Px, double Py)
102
103 {
104 double ax, ay, bx, by, cx, cy, apx, apy, bpx, bpy, cpx, cpy;
105 double cCROSSap, bCROSScp, aCROSSbp;
106
107 ax = Cx - Bx; ay = Cy - By;
108 bx = Ax - Cx; by = Ay - Cy;
109 cx = Bx - Ax; cy = By - Ay;
110 apx= Px - Ax; apy= Py - Ay;
111 bpx= Px - Bx; bpy= Py - By;
112 cpx= Px - Cx; cpy= Py - Cy;
113
114 aCROSSbp = ax*bpy - ay*bpx;
115 cCROSSap = cx*apy - cy*apx;
116 bCROSScp = bx*cpy - by*cpx;
117
118 return ((aCROSSbp >= 0.0) && (bCROSScp >= 0.0) && (cCROSSap >= 0.0));
119 };
120
121 int
122 polyTriangulate(const Vert2_list *contour, tri_out_t *cb)
123 {
124 /* allocate and initialize list of Vertices in polygon */
125
126 int nv, m, u, v, w, count;
127 int *V;
128
129 if ( contour->nv < 3 ) return false;
130
131 V = (int *)malloc(sizeof(int)*contour->nv);
132 if (V == NULL) return false;
133
134 /* we want a counter-clockwise polygon in V */
135
136 if ( 0.0 < polyArea(contour) )
137 for (v=0; v<contour->nv; v++) V[v] = v;
138 else
139 for(v=0; v<contour->nv; v++) V[v] = (contour->nv-1)-v;
140
141 nv = contour->nv;
142
143 /* remove nv-2 Vertices, creating 1 triangle every time */
144 count = 2*nv; /* error detection */
145
146 for(m=0, v=nv-1; nv>2; )
147 {
148 /* if we loop, it is probably a non-simple polygon */
149 if (0 >= count--)
150 {
151 /* Triangulate: ERROR - probable bad polygon */
152 return false;
153 }
154
155 /* three consecutive vertices in current polygon, <u,v,w> */
156 u = v ; if (nv <= u) u = 0; /* previous */
157 v = u+1; if (nv <= v) v = 0; /* new v */
158 w = v+1; if (nv <= w) w = 0; /* next */
159
160 if ( polySnip(contour,u,v,w,nv,V) )
161 {
162 int a,b,c,s,t;
163
164 /* true names of the vertices */
165 a = V[u]; b = V[v]; c = V[w];
166
167 /* output Triangle */
168 if (!(*cb)(contour, a, b, c)) return false;
169
170 m++;
171
172 /* remove v from remaining polygon */
173 for(s=v,t=v+1;t<nv;s++,t++) V[s] = V[t]; nv--;
174
175 /* reset error detection counter */
176 count = 2*nv;
177 }
178 }
179
180 free(V);
181
182 return true;
183 }
