| 1 |
/* Copyright (c) 1997 Regents of the University of California */
| 2 |
| 3 |
/* SCCSid "$SunId$ LBL" */
| 4 |
| 5 |
| 6 |
* Header file for tone mapping functions.
| 7 |
| 8 |
/* required non-system header files */
| 9 |
#include "color.h"
| 10 |
| 11 |
| 12 |
/**** Argument Macros ****/
| 13 |
/* Flags of what to do */
| 14 |
#define TM_F_HCONTR 01 /* human contrast sensitivity */
| 15 |
#define TM_F_MESOPIC 02 /* mesopic color sensitivity */
| 16 |
#define TM_F_LINEAR 04 /* linear brightness mapping */
| 17 |
#define TM_F_ACUITY 010 /* acuity adjustment */
| 18 |
#define TM_F_VEIL 020 /* veiling glare */
| 19 |
#define TM_F_CWEIGHT 040 /* center weighting */
| 20 |
#define TM_F_FOVEAL 0100 /* use foveal sample size */
| 21 |
#define TM_F_BW 0200 /* luminance only */
| 22 |
#define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
| 23 |
/* combined modes */
| 24 |
#define TM_F_CAMERA 0
| 25 |
#define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
| 26 |
TM_F_ACUITY|TM_F_FOVEAL)
| 27 |
#define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
| 28 |
| 29 |
/* special pointer values */
| 30 |
#define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
| 31 |
#define TM_NOCHROM (BYTE *)NULL /* indicate no chrominance */
| 32 |
#define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */
| 33 |
#define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
| 34 |
| 35 |
/**** Error Return Values ****/
| 36 |
| 37 |
#define TM_E_OK 0 /* normal return status */
| 38 |
#define TM_E_NOMEM 1 /* out of memory */
| 39 |
#define TM_E_ILLEGAL 2 /* illegal argument value */
| 40 |
#define TM_E_TMINVAL 3 /* no valid tone mapping */
| 41 |
#define TM_E_TMFAIL 4 /* cannot compute tone mapping */
| 42 |
#define TM_E_BADFILE 5 /* cannot open or understand file */
| 43 |
#define TM_E_CODERR1 6 /* code consistency error 1 */
| 44 |
#define TM_E_CODERR2 7 /* code consistency error 2 */
| 45 |
| 46 |
| 47 |
/**** Conversion Constants and Table Sizes ****/
| 48 |
| 49 |
#define TM_BRTSCALE 128 /* brightness scale factor (integer) */
| 50 |
| 51 |
#define TM_MAXPKG 8 /* maximum number of color formats */
| 52 |
| 53 |
| 54 |
/**** Global Data Types and Structures ****/
| 55 |
| 56 |
#ifndef MEM_PTR
| 57 |
#define MEM_PTR void *
| 58 |
#endif
| 59 |
| 60 |
extern char *tmErrorMessage[]; /* error messages */
| 61 |
extern int tmLastError; /* last error incurred by library */
| 62 |
extern char *tmLastFunction; /* error-generating function name */
| 63 |
| 64 |
typedef short TMbright; /* encoded luminance type */
| 65 |
| 66 |
/* basic tone mapping data structure */
| 67 |
extern struct tmStruct {
| 68 |
int flags; /* flags of what to do */
| 69 |
RGBPRIMP monpri; /* monitor RGB primaries */
| 70 |
double mongam; /* monitor gamma value (approx.) */
| 71 |
COLOR clf; /* computed luminance coefficients */
| 72 |
int cdiv[3]; /* computed color divisors */
| 73 |
RGBPRIMP inppri; /* current input primaries */
| 74 |
double inpsf; /* current input scalefactor */
| 75 |
COLORMAT cmat; /* color conversion matrix */
| 76 |
TMbright hbrmin, hbrmax; /* histogram brightness limits */
| 77 |
int *histo; /* input histogram */
| 78 |
TMbright mbrmin, mbrmax; /* mapped brightness limits */
| 79 |
unsigned short *lumap; /* computed luminance map */
| 80 |
struct tmStruct *tmprev; /* previous tone mapping */
| 81 |
MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
| 82 |
} *tmTop; /* current tone mapping stack */
| 83 |
| 84 |
/* conversion package functions */
| 85 |
#ifdef NOPROTO
| 86 |
struct tmPackage {
| 87 |
MEM_PTR (*Init)(); /* initialize private data */
| 88 |
void (*NewSpace)(); /* new input color space (optional) */
| 89 |
void (*Free)(); /* free private data */
| 90 |
| 91 |
#else
| 92 |
struct tmPackage {
| 93 |
MEM_PTR (*Init)(struct tmStruct *tms);
| 94 |
int (*NewSpace)(struct tmStruct *tms);
| 95 |
void (*Free)(MEM_PTR pp);
| 96 |
| 97 |
#endif
| 98 |
/* our list of conversion packages */
| 99 |
extern struct tmPackage *tmPkg[TM_MAXPKG];
| 100 |
extern int tmNumPkgs; /* number of registered packages */
| 101 |
| 102 |
| 103 |
/**** Useful Macros ****/
| 104 |
| 105 |
/* compute luminance from encoded value */
| 106 |
#define tmLuminance(li) exp((li)/(double)TM_BRTSCALE)
| 107 |
| 108 |
/* does tone mapping need color matrix? */
| 109 |
#define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
| 110 |
| 111 |
/* register a conversion package */
| 112 |
#define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
| 113 |
(tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
| 114 |
| 115 |
/* get the specific package's data */
| 116 |
#define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
| 117 |
| 118 |
| 119 |
/**** Library Function Calls ****/
| 120 |
| 121 |
#ifdef NOPROTO
| 122 |
| 123 |
extern struct tmStruct *tmInit(), *tmPop(), *tmDup();
| 124 |
extern void tmClearHisto(), tmDone();
| 125 |
extern int tmSetSpace(), tmCvColors(), tmCvColrs();
| 126 |
extern int tmAddHisto(), tmComputeMapping(), tmMapPixels();
| 127 |
extern int tmLoadPicture(), tmMapPicture(), tmPull(), tmPush();
| 128 |
| 129 |
#else
| 130 |
| 131 |
| 132 |
tmInit(int flags, RGBPRIMP monpri, double gamval);
| 133 |
| 134 |
Initialize new tone mapping and push it onto stack.
| 135 |
| 136 |
flags - TM_F_* flags indicating what is to be done.
| 137 |
monpri - display monitor primaries (Note 1).
| 138 |
gamval - display gamma response (can be approximate).
| 139 |
| 140 |
returns - new tmTop, or NULL if insufficient memory.
| 141 |
| 142 |
| 143 |
extern int
| 144 |
tmSetSpace(RGBPRIMP pri, double sf);
| 145 |
| 146 |
Set color primaries and scale factor for incoming scanlines.
| 147 |
| 148 |
pri - RGB color input primaries (Note 1).
| 149 |
sf - scale factor to get to luminance in cd/m^2.
| 150 |
| 151 |
returns - 0 on success, TM_E_* code on failure.
| 152 |
| 153 |
| 154 |
extern void
| 155 |
tmClearHisto(void);
| 156 |
| 157 |
Clear histogram for current tone mapping.
| 158 |
| 159 |
| 160 |
extern int
| 161 |
tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len);
| 162 |
| 163 |
Convert RGB/XYZ float scanline to encoded luminance and chrominance.
| 164 |
| 165 |
ls - returned encoded luminance values.
| 166 |
cs - returned encoded chrominance values (Note 2).
| 167 |
scan - input scanline.
| 168 |
len - scanline length.
| 169 |
| 170 |
returns - 0 on success, TM_E_* on error.
| 171 |
| 172 |
| 173 |
extern int
| 174 |
tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len);
| 175 |
| 176 |
Convert RGBE/XYZE scanline to encoded luminance and chrominance.
| 177 |
| 178 |
| 179 |
| 180 |
| 181 |
| 182 |
| 183 |
| 184 |
| 185 |
| 186 |
extern int
| 187 |
tmAddHisto(TMbright *ls, int len, int wt);
| 188 |
| 189 |
Add brightness values to current histogram.
| 190 |
| 191 |
ls - encoded luminance values.
| 192 |
len - number of luminance values.
| 193 |
wt - integer weight to use for each value (usually 1 or -1).
| 194 |
| 195 |
| 196 |
| 197 |
| 198 |
extern int
| 199 |
tmComputeMapping(double gamval, double Lddyn, double Ldmax);
| 200 |
| 201 |
Compute tone mapping function. This mapping will be used
| 202 |
in subsequent calls to tmMapPixels() until a new tone mapping
| 203 |
is computed. I.e., calls to tmAddHisto() have no immediate effect.
| 204 |
| 205 |
gamval - display gamma response (0. for default).
| 206 |
Lddyn - the display's dynamic range (0. for default).
| 207 |
Ldmax - maximum display luminance in cd/m^2 (0. for default).
| 208 |
| 209 |
returns - 0 on success, TM_E_* on failure.
| 210 |
| 211 |
| 212 |
extern int
| 213 |
tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len);
| 214 |
| 215 |
Apply tone mapping function to pixel values.
| 216 |
| 217 |
ps - returned pixel values (Note 2).
| 218 |
| 219 |
cs - encoded chrominance values (Note 2).
| 220 |
len - number of pixels.
| 221 |
| 222 |
| 223 |
| 224 |
| 225 |
extern int
| 226 |
tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp,
| 227 |
char *fname, FILE *fp);
| 228 |
| 229 |
Load Radiance picture and convert to tone mapping representation.
| 230 |
Memory for the luminance and chroma arrays is allocated using
| 231 |
malloc(3), and should be freed with free(3) when no longer needed.
| 232 |
Calls tmSetSpace() to calibrate input color space.
| 233 |
| 234 |
lpp - returned array of encoded luminances, English ordering.
| 235 |
cpp - returned array of encoded chrominances (Note 2).
| 236 |
xp, yp - returned picture dimensions.
| 237 |
fname - picture file name.
| 238 |
fp - pointer to open file (Note 3).
| 239 |
| 240 |
| 241 |
| 242 |
| 243 |
extern int
| 244 |
tmMapPicture(BYTE **psp, int *xp, int *yp, int flags,
| 245 |
RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
| 246 |
| 247 |
| 248 |
Load and apply tone mapping to Radiance picture.
| 249 |
Stack is restored to its original state upon return.
| 250 |
If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
| 251 |
calls pcond to perform the actual conversion, which takes
| 252 |
longer but gives access to all the TM_F_* features.
| 253 |
Memory for the final pixel array is allocated using malloc(3),
| 254 |
and should be freed with free(3) when it is no longer needed.
| 255 |
| 256 |
psp - returned array of tone mapped pixels, English ordering.
| 257 |
| 258 |
| 259 |
| 260 |
gamval - display gamma response.
| 261 |
| 262 |
| 263 |
| 264 |
| 265 |
| 266 |
| 267 |
| 268 |
| 269 |
| 270 |
tmPop(void);
| 271 |
| 272 |
Pops current tone mapping from stack.
| 273 |
| 274 |
returns - pointer to tone mapping structure, or NULL if none.
| 275 |
| 276 |
| 277 |
extern int
| 278 |
tmPull(struct tmStruct *tms);
| 279 |
| 280 |
Pull tone mapping from anywhere in stack.
| 281 |
| 282 |
tms - tone mapping structure to find.
| 283 |
| 284 |
returns - 1 if found in stack, 0 otherwise.
| 285 |
| 286 |
| 287 |
extern int
| 288 |
tmPush(struct tmStruct *tms);
| 289 |
| 290 |
Make tone mapping active by (pulling it and) pushing it to the top.
| 291 |
| 292 |
tms - initialized tone mapping structure.
| 293 |
| 294 |
returns - 0 on success, TM_E_* if tms is invalid.
| 295 |
| 296 |
| 297 |
| 298 |
tmDup(void);
| 299 |
| 300 |
Duplicate the current tone mapping into a new structure on the stack.
| 301 |
| 302 |
returns - pointer to new top, or NULL on error.
| 303 |
| 304 |
| 305 |
extern void
| 306 |
tmDone(struct tmStruct *tms);
| 307 |
| 308 |
Free data associated with the given tone mapping structure.
| 309 |
Calls tmPull() first to remove it from the stack if present.
| 310 |
The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL)
| 311 |
all have the same effect, which is to remove and free
| 312 |
the current tone mapping.
| 313 |
| 314 |
tms - tone mapping structure to free.
| 315 |
| 316 |
| 317 |
#endif
| 318 |
| 319 |
| 320 |
/**** Notes ****/
| 321 |
| 322 |
General:
| 323 |
| 324 |
The usual sequence after calling tmInit() is to convert some
| 325 |
pixel values to chroma and luminance encodings, which can
| 326 |
be passed to tmAddHisto() to put into the tone mapping histogram.
| 327 |
This histogram is then used along with the display parameters
| 328 |
by tmComputeMapping() to compute the luminance mapping function.
| 329 |
(Colors are tone-mapped as they are converted if TM_F_MESOPIC
| 330 |
is set.) The encoded chroma and luminance values may then be
| 331 |
passed to tmMapPixels() to apply the computed tone mapping in
| 332 |
a second pass.
| 333 |
| 334 |
Especially for RGBE colors in the same color space as the
| 335 |
target display, the conversion to chroma and luminance values
| 336 |
is fast enough that it may be recomputed on the second pass
| 337 |
if memory is at a premium. (Since the chroma values are only
| 338 |
used during final mapping, setting the cs parameter to TM_NOCHROM
| 339 |
on the first pass will save time.) Another memory saving option
| 340 |
if third and subsequent passes are not needed is to use the
| 341 |
same array to store the mapped pixels as used to store
| 342 |
the encoded chroma values. This way, only two extra bytes
| 343 |
for storing encoded luminances are required per pixel. This
| 344 |
is the method employed by tmMapPicture(), for example.
| 345 |
| 346 |
| 347 |
Note 1:
| 348 |
| 349 |
All RGBPRIMP values should be pointers to static structures.
| 350 |
I.e., the same pointer should be used for the same primaries,
| 351 |
and those primaries should not change from one call to the next.
| 352 |
This is because the routines use the pointer value to identify
| 353 |
computed conversion matrices, so the matrices do not have to be
| 354 |
rebuilt each time. If you are using the standard primaries,
| 355 |
use the standard primary pointer, stdprims.
| 356 |
| 357 |
To indicate a set of input primaries are actually CIE XYZ,
| 358 |
the TM_XYZPRIM macro may be passed. If the input primaries
| 359 |
are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
| 360 |
By default, the input primaries equal the monitor primaries
| 361 |
and the scalefactor is set to WHTEFFICACY in tmInit().
| 362 |
| 363 |
| 364 |
Note 2:
| 365 |
| 366 |
Chrominance is optional in most of these routines, whether
| 367 |
TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
| 368 |
TM_NOCHROMP for picture reading) indicates that returned
| 369 |
color values are not desired.
| 370 |
| 371 |
If TM_NOCHROM is passed to a mapping routine expecting chroma
| 372 |
input, it will do without it and return luminance channel
| 373 |
rather than RGB pixel values. Otherwise, the array for
| 374 |
returned pixel values may be the same array used to pass
| 375 |
encoded chrominances if no other mappings are desired.
| 376 |
| 377 |
| 378 |
Note 3:
| 379 |
| 380 |
Picture files may either be opened by the calling routine or by
| 381 |
the library function. If opened by the calling routine, the
| 382 |
pointer to the stream is passed, which may be a pipe or other
| 383 |
non-seekable input as it is only read once. It must be
| 384 |
positioned at the beginning when the function is called, and it
| 385 |
will be positioned at the end on return. It will not be closed.
| 386 |
If the passed stream pointer is TM_GETFILE, then the library
| 387 |
function will open the file, read its contents and close it
| 388 |
before returning, whether or not an error was encountered.
| 389 |
