root/Development/ray/src/common/tonemap.h
Revision: 3.6
Committed: Tue Jul 29 11:54:45 1997 UTC (28 years, 3 months ago) by gregl
Changes since 3.5: +2 -0 lines
added tmLastError and tmLastFunction globals (set by tmErrorReturn)
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for tone mapping functions.
7 */
8 /* required non-system header files */
9 #include "color.h"
10
11
12 /**** Argument Macros ****/
13 /* Flags of what to do */
14 #define TM_F_HCONTR 01 /* human contrast sensitivity */
15 #define TM_F_MESOPIC 02 /* mesopic color sensitivity */
16 #define TM_F_LINEAR 04 /* linear brightness mapping */
17 #define TM_F_ACUITY 010 /* acuity adjustment */
18 #define TM_F_VEIL 020 /* veiling glare */
19 #define TM_F_CWEIGHT 040 /* center weighting */
20 #define TM_F_FOVEAL 0100 /* use foveal sample size */
21 #define TM_F_BW 0200 /* luminance only */
22 #define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
23 /* combined modes */
24 #define TM_F_CAMERA 0
25 #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
26 TM_F_ACUITY|TM_F_FOVEAL)
27 #define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
28
29 /* special pointer values */
30 #define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
31 #define TM_NOCHROM (BYTE *)NULL /* indicate no chrominance */
32 #define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */
33 #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
34
35 /**** Error Return Values ****/
36
37 #define TM_E_OK 0 /* normal return status */
38 #define TM_E_NOMEM 1 /* out of memory */
39 #define TM_E_ILLEGAL 2 /* illegal argument value */
40 #define TM_E_TMINVAL 3 /* no valid tone mapping */
41 #define TM_E_TMFAIL 4 /* cannot compute tone mapping */
42 #define TM_E_BADFILE 5 /* cannot open or understand file */
43 #define TM_E_CODERR1 6 /* code consistency error 1 */
44 #define TM_E_CODERR2 7 /* code consistency error 2 */
45
46
47 /**** Conversion Constants and Table Sizes ****/
48
49 #define TM_BRTSCALE 128 /* brightness scale factor (integer) */
50
51 #define TM_MAXPKG 8 /* maximum number of color formats */
52
53
54 /**** Global Data Types and Structures ****/
55
56 #ifndef MEM_PTR
57 #define MEM_PTR void *
58 #endif
59
60 extern char *tmErrorMessage[]; /* error messages */
61 extern int tmLastError; /* last error incurred by library */
62 extern char *tmLastFunction; /* error-generating function name */
63
64 typedef short TMbright; /* encoded luminance type */
65
66 /* basic tone mapping data structure */
67 extern struct tmStruct {
68 int flags; /* flags of what to do */
69 RGBPRIMP monpri; /* monitor RGB primaries */
70 double mongam; /* monitor gamma value (approx.) */
71 COLOR clf; /* computed luminance coefficients */
72 int cdiv[3]; /* computed color divisors */
73 RGBPRIMP inppri; /* current input primaries */
74 double inpsf; /* current input scalefactor */
75 COLORMAT cmat; /* color conversion matrix */
76 TMbright brmin, brmax; /* input brightness limits */
77 int *histo; /* input histogram */
78 unsigned short *lumap; /* computed luminance map */
79 struct tmStruct *tmprev; /* previous tone mapping */
80 MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
81 } *tmTop; /* current tone mapping stack */
82
83 /* conversion package functions */
84 #ifdef NOPROTO
85 struct tmPackage {
86 MEM_PTR (*Init)(); /* initialize private data */
87 void (*NewSpace)(); /* new input color space (optional) */
88 void (*Free)(); /* free private data */
89 };
90 #else
91 struct tmPackage {
92 MEM_PTR (*Init)(struct tmStruct *tms);
93 int (*NewSpace)(struct tmStruct *tms);
94 void (*Free)(MEM_PTR pp);
95 };
96 #endif
97 /* our list of conversion packages */
98 extern struct tmPackage *tmPkg[TM_MAXPKG];
99 extern int tmNumPkgs; /* number of registered packages */
100
101
102 /**** Useful Macros ****/
103
104 /* compute luminance from encoded value */
105 #define tmLuminance(li) exp((li)/(double)TM_BRTSCALE)
106
107 /* does tone mapping need color matrix? */
108 #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
109
110 /* register a conversion package */
111 #define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
112 (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
113
114 /* get the specific package's data */
115 #define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
116
117
118 /**** Library Function Calls ****/
119
120 #ifdef NOPROTO
121
122 extern struct tmStruct *tmInit(), *tmPop(), *tmDup();
123 extern void tmClearHisto(), tmDone();
124 extern int tmSetSpace(), tmCvColors(), tmCvColrs();
125 extern int tmAddHisto(), tmComputeMapping(), tmMapPixels();
126 extern int tmLoadPicture(), tmMapPicture(), tmPull(), tmPush();
127
128 #else
129
130 extern struct tmStruct *
131 tmInit(int flags, RGBPRIMP monpri, double gamval);
132 /*
133 Initialize new tone mapping and push it onto stack.
134
135 flags - TM_F_* flags indicating what is to be done.
136 monpri - display monitor primaries (Note 1).
137 gamval - display gamma response (can be approximate).
138
139 returns - new tmTop, or NULL if insufficient memory.
140 */
141
142 extern int
143 tmSetSpace(RGBPRIMP pri, double sf);
144 /*
145 Set color primaries and scale factor for incoming scanlines.
146
147 pri - RGB color input primaries (Note 1).
148 sf - scale factor to get to luminance in cd/m^2.
149
150 returns - 0 on success, TM_E_* code on failure.
151 */
152
153 extern void
154 tmClearHisto(void);
155 /*
156 Clear histogram for current tone mapping.
157 */
158
159 extern int
160 tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len);
161 /*
162 Convert RGB/XYZ float scanline to encoded luminance and chrominance.
163
164 ls - returned encoded luminance values.
165 cs - returned encoded chrominance values (Note 2).
166 scan - input scanline.
167 len - scanline length.
168
169 returns - 0 on success, TM_E_* on error.
170 */
171
172 extern int
173 tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len);
174 /*
175 Convert RGBE/XYZE scanline to encoded luminance and chrominance.
176
177 ls - returned encoded luminance values.
178 cs - returned encoded chrominance values (Note 2).
179 scan - input scanline.
180 len - scanline length.
181
182 returns - 0 on success, TM_E_* on error.
183 */
184
185 extern int
186 tmAddHisto(TMbright *ls, int len, int wt);
187 /*
188 Add brightness values to current histogram.
189
190 ls - encoded luminance values.
191 len - number of luminance values.
192 wt - integer weight to use for each value (usually 1 or -1).
193
194 returns - 0 on success, TM_E_* on error.
195 */
196
197 extern int
198 tmComputeMapping(double gamval, double Lddyn, double Ldmax);
199 /*
200 Compute tone mapping function.
201
202 gamval - display gamma response (0. for default).
203 Lddyn - the display's dynamic range (0. for default).
204 Ldmax - maximum display luminance in cd/m^2 (0. for default).
205
206 returns - 0 on success, TM_E_* on failure.
207 */
208
209 extern int
210 tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len);
211 /*
212 Apply tone mapping function to pixel values.
213
214 ps - returned pixel values (Note 2).
215 ls - encoded luminance values.
216 cs - encoded chrominance values (Note 2).
217 len - number of pixels.
218
219 returns - 0 on success, TM_E_* on failure.
220 */
221
222 extern int
223 tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp,
224 char *fname, FILE *fp);
225 /*
226 Load Radiance picture and convert to tone mapping representation.
227 Memory for the luminance and chroma arrays is allocated using
228 malloc(3), and should be freed with free(3) when no longer needed.
229 Calls tmSetSpace() to calibrate input color space.
230
231 lpp - returned array of encoded luminances, English ordering.
232 cpp - returned array of encoded chrominances (Note 2).
233 xp, yp - returned picture dimensions.
234 fname - picture file name.
235 fp - pointer to open file (Note 3).
236
237 returns - 0 on success, TM_E_* on failure.
238 */
239
240 extern int
241 tmMapPicture(BYTE **psp, int *xp, int *yp, int flags,
242 RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
243 char *fname, FILE *fp);
244 /*
245 Load and apply tone mapping to Radiance picture.
246 Stack is restored to its original state upon return.
247 If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
248 calls pcond to perform the actual conversion, which takes
249 longer but gives access to all the TM_F_* features.
250 Memory for the final pixel array is allocated using malloc(3),
251 and should be freed with free(3) when it is no longer needed.
252
253 psp - returned array of tone mapped pixels, English ordering.
254 xp, yp - returned picture dimensions.
255 flags - TM_F_* flags indicating what is to be done.
256 monpri - display monitor primaries (Note 1).
257 gamval - display gamma response.
258 Lddyn - the display's dynamic range (0. for default).
259 Ldmax - maximum display luminance in cd/m^2 (0. for default).
260 fname - picture file name.
261 fp - pointer to open file (Note 3).
262
263 returns - 0 on success, TM_E_* on failure.
264 */
265
266 extern struct tmStruct *
267 tmPop(void);
268 /*
269 Pops current tone mapping from stack.
270
271 returns - pointer to tone mapping structure, or NULL if none.
272 */
273
274 extern int
275 tmPull(struct tmStruct *tms);
276 /*
277 Pull tone mapping from anywhere in stack.
278
279 tms - tone mapping structure to find.
280
281 returns - 1 if found in stack, 0 otherwise.
282 */
283
284 extern int
285 tmPush(struct tmStruct *tms);
286 /*
287 Make tone mapping active by (pulling it and) pushing it to the top.
288
289 tms - initialized tone mapping structure.
290
291 returns - 0 on success, TM_E_* if tms is invalid.
292 */
293
294 extern struct tmStruct *
295 tmDup(void);
296 /*
297 Duplicate the current tone mapping into a new structure on the stack.
298
299 returns - pointer to new top, or NULL on error.
300 */
301
302 extern void
303 tmDone(struct tmStruct *tms);
304 /*
305 Free data associated with the given tone mapping structure.
306 Calls tmPull() first to remove it from the stack if present.
307 The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL)
308 all have the same effect, which is to remove and free
309 the current tone mapping.
310
311 tms - tone mapping structure to free.
312 */
313
314 #endif
315
316
317 /**** Notes ****/
318 /*
319 General:
320
321 The usual sequence after calling tmInit() is to convert some
322 pixel values to chroma and luminance encodings, which can
323 be passed to tmAddHisto() to put into the tone mapping histogram.
324 This histogram is then used along with the display parameters
325 by tmComputeMapping() to compute the luminance mapping function.
326 (Colors are tone-mapped as they are converted if TM_F_MESOPIC
327 is set.) The encoded chroma and luminance values may then be
328 passed to tmMapPixels() to apply the computed tone mapping in
329 a second pass.
330
331 Especially for RGBE colors in the same color space as the
332 target display, the conversion to chroma and luminance values
333 is fast enough that it may be recomputed on the second pass
334 if memory is at a premium. (Since the chroma values are only
335 used during final mapping, setting the cs parameter to TM_NOCHROM
336 on the first pass will save time.) Another memory saving option
337 if third and subsequent passes are not needed is to use the
338 same array to store the mapped pixels as used to store
339 the encoded chroma values. This way, only two extra bytes
340 for storing encoded luminances are required per pixel. This
341 is the method employed by tmMapPicture(), for example.
342 */
343 /*
344 Note 1:
345
346 All RGBPRIMP values should be pointers to static structures.
347 I.e., the same pointer should be used for the same primaries,
348 and those primaries should not change from one call to the next.
349 This is because the routines use the pointer value to identify
350 computed conversion matrices, so the matrices do not have to be
351 rebuilt each time. If you are using the standard primaries,
352 use the standard primary pointer, stdprims.
353
354 To indicate a set of input primaries are actually CIE XYZ,
355 the TM_XYZPRIM macro may be passed. If the input primaries
356 are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
357 By default, the input primaries equal the monitor primaries
358 and the scalefactor is set to WHTEFFICACY in tmInit().
359 */
360 /*
361 Note 2:
362
363 Chrominance is optional in most of these routines, whether
364 TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
365 TM_NOCHROMP for picture reading) indicates that returned
366 color values are not desired.
367
368 If TM_NOCHROM is passed to a mapping routine expecting chroma
369 input, it will do without it and return luminance channel
370 rather than RGB pixel values. Otherwise, the array for
371 returned pixel values may be the same array used to pass
372 encoded chrominances if no other mappings are desired.
373 */
374 /*
375 Note 3:
376
377 Picture files may either be opened by the calling routine or by
378 the library function. If opened by the calling routine, the
379 pointer to the stream is passed, which may be a pipe or other
380 non-seekable input as it is only read once. It must be
381 positioned at the beginning when the function is called, and it
382 will be positioned at the end on return. It will not be closed.
383 If the passed stream pointer is TM_GETFILE, then the library
384 function will open the file, read its contents and close it
385 before returning, whether or not an error was encountered.
386 */
