--- ray/src/common/tonemap.h 1997/04/15 16:53:03 3.1 +++ ray/src/common/tonemap.h 2010/08/18 15:25:03 3.25 @@ -1,15 +1,20 @@ -/* Copyright (c) 1997 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: tonemap.h,v 3.25 2010/08/18 15:25:03 greg Exp $ */ /* * Header file for tone mapping functions. + * + * Include after "color.h" */ - /* required non-system header files */ -#include "color.h" +#ifndef _RAD_TONEMAP_H_ +#define _RAD_TONEMAP_H_ +#include "tiff.h" /* needed for int32, etc. */ + +#ifdef __cplusplus +extern "C" { +#endif + /**** Argument Macros ****/ - /* Flags of what to do */ + /* flags of what to do */ #define TM_F_HCONTR 01 /* human contrast sensitivity */ #define TM_F_MESOPIC 02 /* mesopic color sensitivity */ #define TM_F_LINEAR 04 /* linear brightness mapping */ @@ -18,7 +23,7 @@ #define TM_F_CWEIGHT 040 /* center weighting */ #define TM_F_FOVEAL 0100 /* use foveal sample size */ #define TM_F_BW 0200 /* luminance only */ -#define TM_F_NOERRS 0400 /* don't report errors to stderr */ +#define TM_F_NOSTDERR 0400 /* don't report errors to stderr */ /* combined modes */ #define TM_F_CAMERA 0 #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\ @@ -31,6 +36,7 @@ #define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */ #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */ + /**** Error Return Values ****/ #define TM_E_OK 0 /* normal return status */ @@ -39,125 +45,168 @@ #define TM_E_TMINVAL 3 /* no valid tone mapping */ #define TM_E_TMFAIL 4 /* cannot compute tone mapping */ #define TM_E_BADFILE 5 /* cannot open or understand file */ +#define TM_E_CODERR1 6 /* code consistency error 1 */ +#define TM_E_CODERR2 7 /* code consistency error 2 */ + /**** Conversion Constants and Table Sizes ****/ -#define TM_BRTSCALE 128 /* brightness scale factor (integer) */ +#define TM_BRTSCALE 256 /* brightness scale factor (integer) */ -#define TM_GAMTSZ 1024 /* gamma lookup table size */ +#define TM_NOBRT (-1<<15) /* bogus brightness value */ +#define TM_NOLUM (1e-17) /* ridiculously small luminance */ -/**** Global Data Structures ****/ +#define TM_MAXPKG 8 /* maximum number of color formats */ + +/**** Global Data Types and Structures ****/ + +#ifndef MEM_PTR +#define MEM_PTR void * +#endif + extern char *tmErrorMessage[]; /* error messages */ typedef short TMbright; /* encoded luminance type */ /* basic tone mapping data structure */ -extern struct tmStruct { +typedef struct { int flags; /* flags of what to do */ RGBPRIMP monpri; /* monitor RGB primaries */ double mongam; /* monitor gamma value (approx.) */ - BYTE gamb[TM_GAMTSZ];/* gamma lookup table from mongam */ COLOR clf; /* computed luminance coefficients */ - COLR clfb; /* normalized version of clf */ + int cdiv[3]; /* computed color divisors */ RGBPRIMP inppri; /* current input primaries */ double inpsf; /* current input scalefactor */ - TMbright inpsfb; /* encoded version of inpsf */ + MEM_PTR inpdat; /* current input client data */ COLORMAT cmat; /* color conversion matrix */ - TMbright brmin, brmax; /* input brightness limits */ + TMbright hbrmin, hbrmax; /* histogram brightness limits */ int *histo; /* input histogram */ + TMbright mbrmin, mbrmax; /* mapped brightness limits */ unsigned short *lumap; /* computed luminance map */ - struct tmStruct *tmprev; /* previous tone mapping */ -} *tmTop; /* current tone mapping stack */ - + MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */ + int lastError; /* last error incurred */ + const char *lastFunc; /* error-generating function name */ +} TMstruct; + + /* conversion package functions */ +struct tmPackage { + MEM_PTR (*Init)(TMstruct *tms); + void (*NewSpace)(TMstruct *tms); + void (*Free)(MEM_PTR pp); +}; + /* our list of conversion packages */ +extern struct tmPackage *tmPkg[TM_MAXPKG]; +extern int tmNumPkgs; /* number of registered packages */ + + /**** Useful Macros ****/ -#define tmLuminance(li) exp((li)/(double)TM_BRTSCALE) + /* compute luminance from encoded value */ +#define tmLuminance(li) exp((li)*(1./TM_BRTSCALE)) + /* does tone mapping need color matrix? */ +#define tmNeedMatrix(t) ((t)->monpri != (t)->inppri) + + /* register a conversion package */ +#define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \ + (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) ) + + /* get the specific package's data */ +#define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t)) + + /**** Library Function Calls ****/ -#ifdef NOPROTO +extern TMbright +tmCvLuminance(double lum); +/* + Convert a single luminance value to an encoded brightness value. + */ -extern struct tmStruct *tmInit(), *tmPop(); -extern void tmClearHisto(), tmDone(); -extern int tmSetSpace(), tmCvColors(), tmCvColrs(); -extern int tmAddHisto(), tmComputeMapping(), tmMapPixels(); -extern int tmLoadPicture(), tmMapPicture(), tmPull(), tmPush(); +extern int +tmCvLums(TMbright *ls, float *scan, int len); +/* + Convert luminance values to encoded brightness values using lookup. -#else + ls - returned encoded luminance values. + scan - input scanline. + len - scanline length. -extern struct tmStruct * + returns - 0 on success, TM_E_* on error. + */ + +extern TMstruct * tmInit(int flags, RGBPRIMP monpri, double gamval); /* - Initialize new tone mapping and push it onto stack. + Allocate and initialize new tone mapping. flags - TM_F_* flags indicating what is to be done. monpri - display monitor primaries (Note 1). gamval - display gamma response (can be approximate). - returns - new tmTop, or NULL if insufficient memory. + returns - new tone-mapping pointer, or NULL if no memory. */ extern int -tmSetSpace(RGBPRIMP pri, double sf); +tmSetSpace(TMstruct *tms, RGBPRIMP pri, double sf, MEM_PTR dat); /* Set color primaries and scale factor for incoming scanlines. + tms - tone mapping structure pointer. pri - RGB color input primaries (Note 1). sf - scale factor to get to luminance in cd/m^2. + dat - application-specific data (NULL if not needed) returns - 0 on success, TM_E_* code on failure. */ extern void -tmClearHisto(void); +tmClearHisto(TMstruct *tms); /* Clear histogram for current tone mapping. -*/ -extern int -tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len); -/* - Convert RGB/XYZ float scanline to encoded luminance and chrominance. - - ls - returned encoded luminance values. - cs - returned encoded chrominance values (Note 2). - scan - input scanline. - len - scanline length. - - returns - 0 on success, TM_E_* on error. + tms - tone mapping structure pointer. */ extern int -tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len); +tmAddHisto(TMstruct *tms, TMbright *ls, int len, int wt); /* - Convert RGBE/XYZE scanline to encoded luminance and chrominance. + Add brightness values to current histogram. - ls - returned encoded luminance values. - cs - returned encoded chrominance values (Note 2). - scan - input scanline. - len - scanline length. + tms - tone mapping structure pointer. + ls - encoded luminance values. + len - number of luminance values. + wt - integer weight to use for each value (usually 1 or -1). returns - 0 on success, TM_E_* on error. */ extern int -tmAddHisto(TMbright *ls, int len, int wt); +tmFixedMapping(TMstruct *tms, double expmult, double gamval); /* - Add brightness values to current histogram. + Assign a fixed, linear tone-mapping using the given multiplier, + which is the ratio of maximum output to uncalibrated input. + This mapping will be used in subsequent calls to tmMapPixels() + until a new tone mapping is computed. + Only the min. and max. values are used from the histogram. + + tms - tone mapping structure pointer. + expmult - the fixed exposure multiplier to use. + gamval - display gamma response (0. for default). - ls - encoded luminance values. - len - number of luminance values. - wt - integer weight to use for each value (usually 1 or -1). - - returns - 0 on success, TM_E_* on error. + returns - 0 on success, TM_E_* on error. */ extern int -tmComputeMapping(double gamval, double Lddyn, double Ldmax); +tmComputeMapping(TMstruct *tms, double gamval, double Lddyn, double Ldmax); /* - Compute tone mapping function. + Compute tone mapping function from the current histogram. + This mapping will be used in subsequent calls to tmMapPixels() + until a new tone mapping is computed. + I.e., calls to tmAddHisto() have no immediate effect. + tms - tone mapping structure pointer. gamval - display gamma response (0. for default). Lddyn - the display's dynamic range (0. for default). Ldmax - maximum display luminance in cd/m^2 (0. for default). @@ -166,10 +215,11 @@ tmComputeMapping(double gamval, double Lddyn, double L */ extern int -tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len); +tmMapPixels(TMstruct *tms, BYTE *ps, TMbright *ls, BYTE *cs, int len); /* Apply tone mapping function to pixel values. + tms - tone mapping structure pointer. ps - returned pixel values (Note 2). ls - encoded luminance values. cs - encoded chrominance values (Note 2). @@ -178,13 +228,76 @@ tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len) returns - 0 on success, TM_E_* on failure. */ +extern TMstruct * +tmDup(TMstruct *orig); +/* + Duplicate the given tone mapping into a new struct. + + orig - tone mapping structure to duplicate. + + returns - pointer to new struct, or NULL on error. +*/ + +extern void +tmDone(TMstruct *tms); +/* + Free data associated with the given tone mapping structure. + + tms - tone mapping structure to free. +*/ + extern int -tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp, +tmCvGrays(TMstruct *tms, TMbright *ls, float *scan, int len); +/* + Convert gray float scanline to encoded luminance. + + tms - tone mapping structure pointer. + ls - returned encoded luminance values. + scan - input scanline. + len - scanline length. + + returns - 0 on success, TM_E_* on error. +*/ + +extern int +tmCvColors(TMstruct *tms, TMbright *ls, BYTE *cs, COLOR *scan, int len); +/* + Convert RGB/XYZ float scanline to encoded luminance and chrominance. + + tms - tone mapping structure pointer. + ls - returned encoded luminance values. + cs - returned encoded chrominance values (Note 2). + scan - input scanline. + len - scanline length. + + returns - 0 on success, TM_E_* on error. +*/ + +extern int +tmCvColrs(TMstruct *tms, TMbright *ls, BYTE *cs, COLR *scan, int len); +/* + Convert RGBE/XYZE scanline to encoded luminance and chrominance. + + tms - tone mapping structure pointer. + ls - returned encoded luminance values. + cs - returned encoded chrominance values (Note 2). + scan - input scanline. + len - scanline length. + + returns - 0 on success, TM_E_* on error. +*/ + +extern int +tmLoadPicture(TMstruct *tms, TMbright **lpp, BYTE **cpp, int *xp, int *yp, char *fname, FILE *fp); /* Load Radiance picture and convert to tone mapping representation. + Memory for the luminance and chroma arrays is allocated using + malloc(3), and should be freed with free(3) when no longer needed. + Calls tmSetSpace() to calibrate input color space. - lpp - returned array of encoded luminances, English ordering. + tms - tone mapping structure pointer. + lpp - returned array of encoded luminances, picture ordering. cpp - returned array of encoded chrominances (Note 2). xp, yp - returned picture dimensions. fname - picture file name. @@ -199,12 +312,13 @@ tmMapPicture(BYTE **psp, int *xp, int *yp, int flags, char *fname, FILE *fp); /* Load and apply tone mapping to Radiance picture. - Stack is restored to its original state upon return. If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture() calls pcond to perform the actual conversion, which takes longer but gives access to all the TM_F_* features. + Memory for the final pixel array is allocated using malloc(3), + and should be freed with free(3) when it is no longer needed. - psp - returned array of tone mapped pixels, English ordering. + psp - returned array of tone mapped pixels, picture ordering. xp, yp - returned picture dimensions. flags - TM_F_* flags indicating what is to be done. monpri - display monitor primaries (Note 1). @@ -217,48 +331,36 @@ tmMapPicture(BYTE **psp, int *xp, int *yp, int flags, returns - 0 on success, TM_E_* on failure. */ -extern struct tmStruct * -tmPop(void); -/* - Pops current tone mapping from stack. - - returns - pointer to tone mapping structure, or NULL if none. -*/ - extern int -tmPull(struct tmStruct *tms); +tmCvRGB48(TMstruct *tms, TMbright *ls, BYTE *cs, uint16 (*scan)[3], + int len, double gv); /* - Pull tone mapping from anywhere in stack. + Convert 48-bit RGB scanline to encoded luminance and chrominance. - tms - tone mapping structure to find. + tms - tone mapping structure pointer. + ls - returned encoded luminance values. + cs - returned encoded chrominance values (Note 2). + scan - input scanline. + len - scanline length. + gv - input gamma value. - returns - 1 if found in stack, 0 otherwise. + returns - 0 on success, TM_E_* on error. */ extern int -tmPush(struct tmStruct *tms); +tmCvGray16(TMstruct *tms, TMbright *ls, uint16 *scan, int len, double gv); /* - Make tone mapping active by (pulling it and) pushing it to the top. + Convert 16-bit gray scanline to encoded luminance. - tms - initialized tone mapping structure. + tms - tone mapping structure pointer. + ls - returned encoded luminance values. + scan - input scanline. + len - scanline length. + gv - input gamma value. - returns - 0 on success, TM_E_* if tms is invalid. + returns - 0 on success, TM_E_* on error. */ -extern void -tmDone(struct tmStruct *tms); -/* - Free data associated with the given tone mapping structure. - Calls tmPull() first to remove it from the stack if present. - The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL) - all have the same effect, which is to remove and free - the current tone mapping. - - tms - tone mapping structure to free. -*/ - -#endif - /**** Notes ****/ /* General: @@ -267,7 +369,7 @@ tmDone(struct tmStruct *tms); pixel values to chroma and luminance encodings, which can be passed to tmAddHisto() to put into the tone mapping histogram. This histogram is then used along with the display parameters - by tmComputMapping() to compute the luminance mapping function. + by tmComputeMapping() to compute the luminance mapping function. (Colors are tone-mapped as they are converted if TM_F_MESOPIC is set.) The encoded chroma and luminance values may then be passed to tmMapPixels() to apply the computed tone mapping in @@ -280,7 +382,7 @@ tmDone(struct tmStruct *tms); used during final mapping, setting the cs parameter to TM_NOCHROM on the first pass will save time.) Another memory saving option if third and subsequent passes are not needed is to use the - same array to store the mapped pixels as is used to store + same array to store the mapped pixels as used to store the encoded chroma values. This way, only two extra bytes for storing encoded luminances are required per pixel. This is the method employed by tmMapPicture(), for example. @@ -329,3 +431,9 @@ tmDone(struct tmStruct *tms); function will open the file, read its contents and close it before returning, whether or not an error was encountered. */ + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_TONEMAP_H_ */ +
