root/radiance/ray/src/common/tonemap.h
Revision: 3.7
Committed: Mon Nov 17 13:54:35 1997 UTC (27 years, 8 months ago) by gregl
Changes since 3.6: +5 -2 lines
changed behavior so that tmClearHisto() and tmAddHisto() do not
void computed tone mapping, even if brightness limits are exceeded
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for tone mapping functions.
7 */
8 /* required non-system header files */
9 #include "color.h"
10
11
12 /**** Argument Macros ****/
13 /* Flags of what to do */
14 #define TM_F_HCONTR 01 /* human contrast sensitivity */
15 #define TM_F_MESOPIC 02 /* mesopic color sensitivity */
16 #define TM_F_LINEAR 04 /* linear brightness mapping */
17 #define TM_F_ACUITY 010 /* acuity adjustment */
18 #define TM_F_VEIL 020 /* veiling glare */
19 #define TM_F_CWEIGHT 040 /* center weighting */
20 #define TM_F_FOVEAL 0100 /* use foveal sample size */
21 #define TM_F_BW 0200 /* luminance only */
22 #define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
23 /* combined modes */
24 #define TM_F_CAMERA 0
25 #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
26 TM_F_ACUITY|TM_F_FOVEAL)
27 #define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
28
29 /* special pointer values */
30 #define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
31 #define TM_NOCHROM (BYTE *)NULL /* indicate no chrominance */
32 #define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */
33 #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
34
35 /**** Error Return Values ****/
36
37 #define TM_E_OK 0 /* normal return status */
38 #define TM_E_NOMEM 1 /* out of memory */
39 #define TM_E_ILLEGAL 2 /* illegal argument value */
40 #define TM_E_TMINVAL 3 /* no valid tone mapping */
41 #define TM_E_TMFAIL 4 /* cannot compute tone mapping */
42 #define TM_E_BADFILE 5 /* cannot open or understand file */
43 #define TM_E_CODERR1 6 /* code consistency error 1 */
44 #define TM_E_CODERR2 7 /* code consistency error 2 */
45
46
47 /**** Conversion Constants and Table Sizes ****/
48
49 #define TM_BRTSCALE 128 /* brightness scale factor (integer) */
50
51 #define TM_MAXPKG 8 /* maximum number of color formats */
52
53
54 /**** Global Data Types and Structures ****/
55
56 #ifndef MEM_PTR
57 #define MEM_PTR void *
58 #endif
59
60 extern char *tmErrorMessage[]; /* error messages */
61 extern int tmLastError; /* last error incurred by library */
62 extern char *tmLastFunction; /* error-generating function name */
63
64 typedef short TMbright; /* encoded luminance type */
65
66 /* basic tone mapping data structure */
67 extern struct tmStruct {
68 int flags; /* flags of what to do */
69 RGBPRIMP monpri; /* monitor RGB primaries */
70 double mongam; /* monitor gamma value (approx.) */
71 COLOR clf; /* computed luminance coefficients */
72 int cdiv[3]; /* computed color divisors */
73 RGBPRIMP inppri; /* current input primaries */
74 double inpsf; /* current input scalefactor */
75 COLORMAT cmat; /* color conversion matrix */
76 TMbright hbrmin, hbrmax; /* histogram brightness limits */
77 int *histo; /* input histogram */
78 TMbright mbrmin, mbrmax; /* mapped brightness limits */
79 unsigned short *lumap; /* computed luminance map */
80 struct tmStruct *tmprev; /* previous tone mapping */
81 MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
82 } *tmTop; /* current tone mapping stack */
83
84 /* conversion package functions */
85 #ifdef NOPROTO
86 struct tmPackage {
87 MEM_PTR (*Init)(); /* initialize private data */
88 void (*NewSpace)(); /* new input color space (optional) */
89 void (*Free)(); /* free private data */
90 };
91 #else
92 struct tmPackage {
93 MEM_PTR (*Init)(struct tmStruct *tms);
94 int (*NewSpace)(struct tmStruct *tms);
95 void (*Free)(MEM_PTR pp);
96 };
97 #endif
98 /* our list of conversion packages */
99 extern struct tmPackage *tmPkg[TM_MAXPKG];
100 extern int tmNumPkgs; /* number of registered packages */
101
102
103 /**** Useful Macros ****/
104
105 /* compute luminance from encoded value */
106 #define tmLuminance(li) exp((li)/(double)TM_BRTSCALE)
107
108 /* does tone mapping need color matrix? */
109 #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
110
111 /* register a conversion package */
112 #define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
113 (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
114
115 /* get the specific package's data */
116 #define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
117
118
119 /**** Library Function Calls ****/
120
121 #ifdef NOPROTO
122
123 extern struct tmStruct *tmInit(), *tmPop(), *tmDup();
124 extern void tmClearHisto(), tmDone();
125 extern int tmSetSpace(), tmCvColors(), tmCvColrs();
126 extern int tmAddHisto(), tmComputeMapping(), tmMapPixels();
127 extern int tmLoadPicture(), tmMapPicture(), tmPull(), tmPush();
128
129 #else
130
131 extern struct tmStruct *
132 tmInit(int flags, RGBPRIMP monpri, double gamval);
133 /*
134 Initialize new tone mapping and push it onto stack.
135
136 flags - TM_F_* flags indicating what is to be done.
137 monpri - display monitor primaries (Note 1).
138 gamval - display gamma response (can be approximate).
139
140 returns - new tmTop, or NULL if insufficient memory.
141 */
142
143 extern int
144 tmSetSpace(RGBPRIMP pri, double sf);
145 /*
146 Set color primaries and scale factor for incoming scanlines.
147
148 pri - RGB color input primaries (Note 1).
149 sf - scale factor to get to luminance in cd/m^2.
150
151 returns - 0 on success, TM_E_* code on failure.
152 */
153
154 extern void
155 tmClearHisto(void);
156 /*
157 Clear histogram for current tone mapping.
158 */
159
160 extern int
161 tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len);
162 /*
163 Convert RGB/XYZ float scanline to encoded luminance and chrominance.
164
165 ls - returned encoded luminance values.
166 cs - returned encoded chrominance values (Note 2).
167 scan - input scanline.
168 len - scanline length.
169
170 returns - 0 on success, TM_E_* on error.
171 */
172
173 extern int
174 tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len);
175 /*
176 Convert RGBE/XYZE scanline to encoded luminance and chrominance.
177
178 ls - returned encoded luminance values.
179 cs - returned encoded chrominance values (Note 2).
180 scan - input scanline.
181 len - scanline length.
182
183 returns - 0 on success, TM_E_* on error.
184 */
185
186 extern int
187 tmAddHisto(TMbright *ls, int len, int wt);
188 /*
189 Add brightness values to current histogram.
190
191 ls - encoded luminance values.
192 len - number of luminance values.
193 wt - integer weight to use for each value (usually 1 or -1).
194
195 returns - 0 on success, TM_E_* on error.
196 */
197
198 extern int
199 tmComputeMapping(double gamval, double Lddyn, double Ldmax);
200 /*
201 Compute tone mapping function. This mapping will be used
202 in subsequent calls to tmMapPixels() until a new tone mapping
203 is computed. I.e., calls to tmAddHisto() have no immediate effect.
204
205 gamval - display gamma response (0. for default).
206 Lddyn - the display's dynamic range (0. for default).
207 Ldmax - maximum display luminance in cd/m^2 (0. for default).
208
209 returns - 0 on success, TM_E_* on failure.
210 */
211
212 extern int
213 tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len);
214 /*
215 Apply tone mapping function to pixel values.
216
217 ps - returned pixel values (Note 2).
218 ls - encoded luminance values.
219 cs - encoded chrominance values (Note 2).
220 len - number of pixels.
221
222 returns - 0 on success, TM_E_* on failure.
223 */
224
225 extern int
226 tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp,
227 char *fname, FILE *fp);
228 /*
229 Load Radiance picture and convert to tone mapping representation.
230 Memory for the luminance and chroma arrays is allocated using
231 malloc(3), and should be freed with free(3) when no longer needed.
232 Calls tmSetSpace() to calibrate input color space.
233
234 lpp - returned array of encoded luminances, English ordering.
235 cpp - returned array of encoded chrominances (Note 2).
236 xp, yp - returned picture dimensions.
237 fname - picture file name.
238 fp - pointer to open file (Note 3).
239
240 returns - 0 on success, TM_E_* on failure.
241 */
242
243 extern int
244 tmMapPicture(BYTE **psp, int *xp, int *yp, int flags,
245 RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
246 char *fname, FILE *fp);
247 /*
248 Load and apply tone mapping to Radiance picture.
249 Stack is restored to its original state upon return.
250 If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
251 calls pcond to perform the actual conversion, which takes
252 longer but gives access to all the TM_F_* features.
253 Memory for the final pixel array is allocated using malloc(3),
254 and should be freed with free(3) when it is no longer needed.
255
256 psp - returned array of tone mapped pixels, English ordering.
257 xp, yp - returned picture dimensions.
258 flags - TM_F_* flags indicating what is to be done.
259 monpri - display monitor primaries (Note 1).
260 gamval - display gamma response.
261 Lddyn - the display's dynamic range (0. for default).
262 Ldmax - maximum display luminance in cd/m^2 (0. for default).
263 fname - picture file name.
264 fp - pointer to open file (Note 3).
265
266 returns - 0 on success, TM_E_* on failure.
267 */
268
269 extern struct tmStruct *
270 tmPop(void);
271 /*
272 Pops current tone mapping from stack.
273
274 returns - pointer to tone mapping structure, or NULL if none.
275 */
276
277 extern int
278 tmPull(struct tmStruct *tms);
279 /*
280 Pull tone mapping from anywhere in stack.
281
282 tms - tone mapping structure to find.
283
284 returns - 1 if found in stack, 0 otherwise.
285 */
286
287 extern int
288 tmPush(struct tmStruct *tms);
289 /*
290 Make tone mapping active by (pulling it and) pushing it to the top.
291
292 tms - initialized tone mapping structure.
293
294 returns - 0 on success, TM_E_* if tms is invalid.
295 */
296
297 extern struct tmStruct *
298 tmDup(void);
299 /*
300 Duplicate the current tone mapping into a new structure on the stack.
301
302 returns - pointer to new top, or NULL on error.
303 */
304
305 extern void
306 tmDone(struct tmStruct *tms);
307 /*
308 Free data associated with the given tone mapping structure.
309 Calls tmPull() first to remove it from the stack if present.
310 The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL)
311 all have the same effect, which is to remove and free
312 the current tone mapping.
313
314 tms - tone mapping structure to free.
315 */
316
317 #endif
318
319
320 /**** Notes ****/
321 /*
322 General:
323
324 The usual sequence after calling tmInit() is to convert some
325 pixel values to chroma and luminance encodings, which can
326 be passed to tmAddHisto() to put into the tone mapping histogram.
327 This histogram is then used along with the display parameters
328 by tmComputeMapping() to compute the luminance mapping function.
329 (Colors are tone-mapped as they are converted if TM_F_MESOPIC
330 is set.) The encoded chroma and luminance values may then be
331 passed to tmMapPixels() to apply the computed tone mapping in
332 a second pass.
333
334 Especially for RGBE colors in the same color space as the
335 target display, the conversion to chroma and luminance values
336 is fast enough that it may be recomputed on the second pass
337 if memory is at a premium. (Since the chroma values are only
338 used during final mapping, setting the cs parameter to TM_NOCHROM
339 on the first pass will save time.) Another memory saving option
340 if third and subsequent passes are not needed is to use the
341 same array to store the mapped pixels as used to store
342 the encoded chroma values. This way, only two extra bytes
343 for storing encoded luminances are required per pixel. This
344 is the method employed by tmMapPicture(), for example.
345 */
346 /*
347 Note 1:
348
349 All RGBPRIMP values should be pointers to static structures.
350 I.e., the same pointer should be used for the same primaries,
351 and those primaries should not change from one call to the next.
352 This is because the routines use the pointer value to identify
353 computed conversion matrices, so the matrices do not have to be
354 rebuilt each time. If you are using the standard primaries,
355 use the standard primary pointer, stdprims.
356
357 To indicate a set of input primaries are actually CIE XYZ,
358 the TM_XYZPRIM macro may be passed. If the input primaries
359 are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
360 By default, the input primaries equal the monitor primaries
361 and the scalefactor is set to WHTEFFICACY in tmInit().
362 */
363 /*
364 Note 2:
365
366 Chrominance is optional in most of these routines, whether
367 TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
368 TM_NOCHROMP for picture reading) indicates that returned
369 color values are not desired.
370
371 If TM_NOCHROM is passed to a mapping routine expecting chroma
372 input, it will do without it and return luminance channel
373 rather than RGB pixel values. Otherwise, the array for
374 returned pixel values may be the same array used to pass
375 encoded chrominances if no other mappings are desired.
376 */
377 /*
378 Note 3:
379
380 Picture files may either be opened by the calling routine or by
381 the library function. If opened by the calling routine, the
382 pointer to the stream is passed, which may be a pipe or other
383 non-seekable input as it is only read once. It must be
384 positioned at the beginning when the function is called, and it
385 will be positioned at the end on return. It will not be closed.
386 If the passed stream pointer is TM_GETFILE, then the library
387 function will open the file, read its contents and close it
388 before returning, whether or not an error was encountered.
389 */
