root/radiance/ray/src/common/tonemap.h
Revision: 3.26
Committed: Fri May 20 02:06:38 2011 UTC (14 years, 1 month ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R2P1, rad5R3
Changes since 3.25: +9 -9 lines
# User Rev Content
1 greg 3.26 /* RCSid $Id: tonemap.h,v 3.25 2010/08/18 15:25:03 greg Exp $ */
2 greg 3.1 /*
3     * Header file for tone mapping functions.
4 gwlarson 3.8 *
5     * Include after "color.h"
6 greg 3.1 */
7 schorsch 3.13 #ifndef _RAD_TONEMAP_H_
8     #define _RAD_TONEMAP_H_
9 schorsch 3.16
10 greg 3.23 #include "tiff.h" /* needed for int32, etc. */
11 schorsch 3.16
12 greg 3.11 #ifdef __cplusplus
13     extern "C" {
14     #endif
15 greg 3.15
16 greg 3.1 /**** Argument Macros ****/
17 greg 3.20 /* flags of what to do */
18 greg 3.1 #define TM_F_HCONTR 01 /* human contrast sensitivity */
19     #define TM_F_MESOPIC 02 /* mesopic color sensitivity */
20     #define TM_F_LINEAR 04 /* linear brightness mapping */
21     #define TM_F_ACUITY 010 /* acuity adjustment */
22     #define TM_F_VEIL 020 /* veiling glare */
23     #define TM_F_CWEIGHT 040 /* center weighting */
24     #define TM_F_FOVEAL 0100 /* use foveal sample size */
25     #define TM_F_BW 0200 /* luminance only */
26 greg 3.2 #define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
27 greg 3.1 /* combined modes */
28     #define TM_F_CAMERA 0
29     #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
30     TM_F_ACUITY|TM_F_FOVEAL)
31     #define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
32
33     /* special pointer values */
34     #define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
35 greg 3.26 #define TM_NOCHROM (uby8 *)NULL /* indicate no chrominance */
36     #define TM_NOCHROMP (uby8 **)NULL /* indicate no chrominances */
37 greg 3.1 #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
38 gwlarson 3.8
39 greg 3.1
40     /**** Error Return Values ****/
41
42     #define TM_E_OK 0 /* normal return status */
43     #define TM_E_NOMEM 1 /* out of memory */
44     #define TM_E_ILLEGAL 2 /* illegal argument value */
45     #define TM_E_TMINVAL 3 /* no valid tone mapping */
46     #define TM_E_TMFAIL 4 /* cannot compute tone mapping */
47     #define TM_E_BADFILE 5 /* cannot open or understand file */
48 greg 3.4 #define TM_E_CODERR1 6 /* code consistency error 1 */
49     #define TM_E_CODERR2 7 /* code consistency error 2 */
50 greg 3.1
51 greg 3.4
52 greg 3.1 /**** Conversion Constants and Table Sizes ****/
53
54 greg 3.25 #define TM_BRTSCALE 256 /* brightness scale factor (integer) */
55 greg 3.1
56 gwlarson 3.10 #define TM_NOBRT (-1<<15) /* bogus brightness value */
57 greg 3.11 #define TM_NOLUM (1e-17) /* ridiculously small luminance */
58 gwlarson 3.10
59 greg 3.4 #define TM_MAXPKG 8 /* maximum number of color formats */
60 greg 3.1
61
62 greg 3.4 /**** Global Data Types and Structures ****/
63
64     #ifndef MEM_PTR
65     #define MEM_PTR void *
66     #endif
67
68 greg 3.1 extern char *tmErrorMessage[]; /* error messages */
69
70     typedef short TMbright; /* encoded luminance type */
71
72     /* basic tone mapping data structure */
73 greg 3.20 typedef struct {
74 greg 3.1 int flags; /* flags of what to do */
75     RGBPRIMP monpri; /* monitor RGB primaries */
76     double mongam; /* monitor gamma value (approx.) */
77     COLOR clf; /* computed luminance coefficients */
78 greg 3.4 int cdiv[3]; /* computed color divisors */
79 greg 3.1 RGBPRIMP inppri; /* current input primaries */
80     double inpsf; /* current input scalefactor */
81 greg 3.19 MEM_PTR inpdat; /* current input client data */
82 greg 3.1 COLORMAT cmat; /* color conversion matrix */
83 gregl 3.7 TMbright hbrmin, hbrmax; /* histogram brightness limits */
84 greg 3.1 int *histo; /* input histogram */
85 gregl 3.7 TMbright mbrmin, mbrmax; /* mapped brightness limits */
86 greg 3.1 unsigned short *lumap; /* computed luminance map */
87 greg 3.4 MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
88 greg 3.18 int lastError; /* last error incurred */
89     const char *lastFunc; /* error-generating function name */
90 greg 3.17 } TMstruct;
91 greg 3.4
92     /* conversion package functions */
93     struct tmPackage {
94 greg 3.17 MEM_PTR (*Init)(TMstruct *tms);
95     void (*NewSpace)(TMstruct *tms);
96 greg 3.4 void (*Free)(MEM_PTR pp);
97     };
98     /* our list of conversion packages */
99     extern struct tmPackage *tmPkg[TM_MAXPKG];
100     extern int tmNumPkgs; /* number of registered packages */
101
102
103 greg 3.1 /**** Useful Macros ****/
104
105 greg 3.4 /* compute luminance from encoded value */
106 greg 3.11 #define tmLuminance(li) exp((li)*(1./TM_BRTSCALE))
107 greg 3.1
108 greg 3.4 /* does tone mapping need color matrix? */
109     #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
110
111     /* register a conversion package */
112     #define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
113     (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
114
115     /* get the specific package's data */
116     #define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
117
118
119 greg 3.1 /**** Library Function Calls ****/
120
121 greg 3.21 extern TMbright
122     tmCvLuminance(double lum);
123     /*
124     Convert a single luminance value to an encoded brightness value.
125     */
126 greg 3.1
127 greg 3.22 extern int
128     tmCvLums(TMbright *ls, float *scan, int len);
129     /*
130     Convert luminance values to encoded brightness values using lookup.
131
132     ls - returned encoded luminance values.
133     scan - input scanline.
134     len - scanline length.
135
136     returns - 0 on success, TM_E_* on error.
137     */
138
139 greg 3.17 extern TMstruct *
140 greg 3.1 tmInit(int flags, RGBPRIMP monpri, double gamval);
141     /*
142 greg 3.17 Allocate and initialize new tone mapping.
143 greg 3.1
144     flags - TM_F_* flags indicating what is to be done.
145     monpri - display monitor primaries (Note 1).
146     gamval - display gamma response (can be approximate).
147
148 greg 3.17 returns - new tone-mapping pointer, or NULL if no memory.
149 greg 3.1 */
150
151     extern int
152 greg 3.19 tmSetSpace(TMstruct *tms, RGBPRIMP pri, double sf, MEM_PTR dat);
153 greg 3.1 /*
154     Set color primaries and scale factor for incoming scanlines.
155
156 greg 3.17 tms - tone mapping structure pointer.
157 greg 3.1 pri - RGB color input primaries (Note 1).
158     sf - scale factor to get to luminance in cd/m^2.
159 greg 3.19 dat - application-specific data (NULL if not needed)
160 greg 3.1
161     returns - 0 on success, TM_E_* code on failure.
162     */
163
164     extern void
165 greg 3.17 tmClearHisto(TMstruct *tms);
166 greg 3.1 /*
167     Clear histogram for current tone mapping.
168 greg 3.17
169     tms - tone mapping structure pointer.
170 greg 3.1 */
171
172     extern int
173 greg 3.17 tmAddHisto(TMstruct *tms, TMbright *ls, int len, int wt);
174 greg 3.1 /*
175     Add brightness values to current histogram.
176
177 greg 3.17 tms - tone mapping structure pointer.
178 greg 3.1 ls - encoded luminance values.
179     len - number of luminance values.
180     wt - integer weight to use for each value (usually 1 or -1).
181
182     returns - 0 on success, TM_E_* on error.
183     */
184
185     extern int
186 greg 3.17 tmFixedMapping(TMstruct *tms, double expmult, double gamval);
187 greg 3.11 /*
188     Assign a fixed, linear tone-mapping using the given multiplier,
189     which is the ratio of maximum output to uncalibrated input.
190     This mapping will be used in subsequent calls to tmMapPixels()
191     until a new tone mapping is computed.
192     Only the min. and max. values are used from the histogram.
193
194 greg 3.17 tms - tone mapping structure pointer.
195 greg 3.11 expmult - the fixed exposure multiplier to use.
196     gamval - display gamma response (0. for default).
197 greg 3.18
198 greg 3.11 returns - 0 on success, TM_E_* on error.
199     */
200
201     extern int
202 greg 3.17 tmComputeMapping(TMstruct *tms, double gamval, double Lddyn, double Ldmax);
203 greg 3.1 /*
204 greg 3.11 Compute tone mapping function from the current histogram.
205     This mapping will be used in subsequent calls to tmMapPixels()
206     until a new tone mapping is computed.
207     I.e., calls to tmAddHisto() have no immediate effect.
208 greg 3.1
209 greg 3.17 tms - tone mapping structure pointer.
210 greg 3.1 gamval - display gamma response (0. for default).
211     Lddyn - the display's dynamic range (0. for default).
212     Ldmax - maximum display luminance in cd/m^2 (0. for default).
213
214     returns - 0 on success, TM_E_* on failure.
215     */
216
217     extern int
218 greg 3.26 tmMapPixels(TMstruct *tms, uby8 *ps, TMbright *ls, uby8 *cs, int len);
219 greg 3.1 /*
220     Apply tone mapping function to pixel values.
221
222 greg 3.17 tms - tone mapping structure pointer.
223 greg 3.1 ps - returned pixel values (Note 2).
224     ls - encoded luminance values.
225     cs - encoded chrominance values (Note 2).
226     len - number of pixels.
227
228     returns - 0 on success, TM_E_* on failure.
229     */
230
231 greg 3.17 extern TMstruct *
232     tmDup(TMstruct *orig);
233 greg 3.3 /*
234 greg 3.17 Duplicate the given tone mapping into a new struct.
235 greg 3.3
236 greg 3.17 orig - tone mapping structure to duplicate.
237 greg 3.18
238 greg 3.17 returns - pointer to new struct, or NULL on error.
239 greg 3.3 */
240
241 greg 3.1 extern void
242 greg 3.17 tmDone(TMstruct *tms);
243 greg 3.1 /*
244     Free data associated with the given tone mapping structure.
245
246     tms - tone mapping structure to free.
247     */
248
249 greg 3.11 extern int
250 greg 3.22 tmCvGrays(TMstruct *tms, TMbright *ls, float *scan, int len);
251 greg 3.11 /*
252 greg 3.22 Convert gray float scanline to encoded luminance.
253 greg 3.11
254 greg 3.17 tms - tone mapping structure pointer.
255 greg 3.11 ls - returned encoded luminance values.
256     scan - input scanline.
257     len - scanline length.
258
259     returns - 0 on success, TM_E_* on error.
260     */
261
262     extern int
263 greg 3.26 tmCvColors(TMstruct *tms, TMbright *ls, uby8 *cs, COLOR *scan, int len);
264 greg 3.11 /*
265 greg 3.22 Convert RGB/XYZ float scanline to encoded luminance and chrominance.
266 greg 3.11
267 greg 3.17 tms - tone mapping structure pointer.
268 greg 3.11 ls - returned encoded luminance values.
269 greg 3.22 cs - returned encoded chrominance values (Note 2).
270 greg 3.11 scan - input scanline.
271     len - scanline length.
272
273     returns - 0 on success, TM_E_* on error.
274     */
275
276     extern int
277 greg 3.26 tmCvColrs(TMstruct *tms, TMbright *ls, uby8 *cs, COLR *scan, int len);
278 greg 3.11 /*
279     Convert RGBE/XYZE scanline to encoded luminance and chrominance.
280
281 greg 3.17 tms - tone mapping structure pointer.
282 greg 3.11 ls - returned encoded luminance values.
283     cs - returned encoded chrominance values (Note 2).
284     scan - input scanline.
285     len - scanline length.
286
287     returns - 0 on success, TM_E_* on error.
288     */
289
290     extern int
291 greg 3.26 tmLoadPicture(TMstruct *tms, TMbright **lpp, uby8 **cpp, int *xp, int *yp,
292 greg 3.11 char *fname, FILE *fp);
293     /*
294     Load Radiance picture and convert to tone mapping representation.
295     Memory for the luminance and chroma arrays is allocated using
296     malloc(3), and should be freed with free(3) when no longer needed.
297     Calls tmSetSpace() to calibrate input color space.
298
299 greg 3.17 tms - tone mapping structure pointer.
300 greg 3.11 lpp - returned array of encoded luminances, picture ordering.
301     cpp - returned array of encoded chrominances (Note 2).
302     xp, yp - returned picture dimensions.
303     fname - picture file name.
304     fp - pointer to open file (Note 3).
305
306     returns - 0 on success, TM_E_* on failure.
307     */
308
309     extern int
310 greg 3.26 tmMapPicture(uby8 **psp, int *xp, int *yp, int flags,
311 greg 3.11 RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
312     char *fname, FILE *fp);
313     /*
314     Load and apply tone mapping to Radiance picture.
315     If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
316     calls pcond to perform the actual conversion, which takes
317     longer but gives access to all the TM_F_* features.
318     Memory for the final pixel array is allocated using malloc(3),
319     and should be freed with free(3) when it is no longer needed.
320
321     psp - returned array of tone mapped pixels, picture ordering.
322     xp, yp - returned picture dimensions.
323     flags - TM_F_* flags indicating what is to be done.
324     monpri - display monitor primaries (Note 1).
325     gamval - display gamma response.
326     Lddyn - the display's dynamic range (0. for default).
327     Ldmax - maximum display luminance in cd/m^2 (0. for default).
328     fname - picture file name.
329     fp - pointer to open file (Note 3).
330
331     returns - 0 on success, TM_E_* on failure.
332     */
333
334 greg 3.15 extern int
335 greg 3.26 tmCvRGB48(TMstruct *tms, TMbright *ls, uby8 *cs, uint16 (*scan)[3],
336 greg 3.17 int len, double gv);
337 greg 3.15 /*
338     Convert 48-bit RGB scanline to encoded luminance and chrominance.
339
340 greg 3.17 tms - tone mapping structure pointer.
341 greg 3.15 ls - returned encoded luminance values.
342     cs - returned encoded chrominance values (Note 2).
343     scan - input scanline.
344     len - scanline length.
345     gv - input gamma value.
346
347     returns - 0 on success, TM_E_* on error.
348     */
349
350     extern int
351 greg 3.17 tmCvGray16(TMstruct *tms, TMbright *ls, uint16 *scan, int len, double gv);
352 greg 3.15 /*
353     Convert 16-bit gray scanline to encoded luminance.
354
355 greg 3.17 tms - tone mapping structure pointer.
356 greg 3.15 ls - returned encoded luminance values.
357     scan - input scanline.
358     len - scanline length.
359     gv - input gamma value.
360 greg 3.4
361 greg 3.15 returns - 0 on success, TM_E_* on error.
362     */
363 greg 3.4
364 greg 3.1 /**** Notes ****/
365     /*
366     General:
367
368     The usual sequence after calling tmInit() is to convert some
369     pixel values to chroma and luminance encodings, which can
370     be passed to tmAddHisto() to put into the tone mapping histogram.
371     This histogram is then used along with the display parameters
372 greg 3.5 by tmComputeMapping() to compute the luminance mapping function.
373 greg 3.1 (Colors are tone-mapped as they are converted if TM_F_MESOPIC
374     is set.) The encoded chroma and luminance values may then be
375     passed to tmMapPixels() to apply the computed tone mapping in
376     a second pass.
377
378     Especially for RGBE colors in the same color space as the
379     target display, the conversion to chroma and luminance values
380     is fast enough that it may be recomputed on the second pass
381     if memory is at a premium. (Since the chroma values are only
382     used during final mapping, setting the cs parameter to TM_NOCHROM
383     on the first pass will save time.) Another memory saving option
384     if third and subsequent passes are not needed is to use the
385 greg 3.3 same array to store the mapped pixels as used to store
386 greg 3.1 the encoded chroma values. This way, only two extra bytes
387     for storing encoded luminances are required per pixel. This
388     is the method employed by tmMapPicture(), for example.
389     */
390     /*
391     Note 1:
392
393     All RGBPRIMP values should be pointers to static structures.
394     I.e., the same pointer should be used for the same primaries,
395     and those primaries should not change from one call to the next.
396     This is because the routines use the pointer value to identify
397     computed conversion matrices, so the matrices do not have to be
398     rebuilt each time. If you are using the standard primaries,
399     use the standard primary pointer, stdprims.
400
401     To indicate a set of input primaries are actually CIE XYZ,
402     the TM_XYZPRIM macro may be passed. If the input primaries
403     are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
404     By default, the input primaries equal the monitor primaries
405     and the scalefactor is set to WHTEFFICACY in tmInit().
406     */
407     /*
408     Note 2:
409
410     Chrominance is optional in most of these routines, whether
411     TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
412     TM_NOCHROMP for picture reading) indicates that returned
413     color values are not desired.
414
415     If TM_NOCHROM is passed to a mapping routine expecting chroma
416     input, it will do without it and return luminance channel
417     rather than RGB pixel values. Otherwise, the array for
418     returned pixel values may be the same array used to pass
419     encoded chrominances if no other mappings are desired.
420     */
421     /*
422     Note 3:
423
424     Picture files may either be opened by the calling routine or by
425     the library function. If opened by the calling routine, the
426     pointer to the stream is passed, which may be a pipe or other
427     non-seekable input as it is only read once. It must be
428     positioned at the beginning when the function is called, and it
429     will be positioned at the end on return. It will not be closed.
430     If the passed stream pointer is TM_GETFILE, then the library
431     function will open the file, read its contents and close it
432     before returning, whether or not an error was encountered.
433     */
434 greg 3.11
435     #ifdef __cplusplus
436     }
437     #endif
438 schorsch 3.13 #endif /* _RAD_TONEMAP_H_ */
439
