root/radiance/ray/src/common/tonemap.h
Revision: 3.15
Committed: Mon Jul 14 04:56:54 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.14: +28 -1 lines
1 /* RCSid $Id: tonemap.h,v 3.14 2003/06/27 06:53:22 greg Exp $ */
2 /*
3 * Header file for tone mapping functions.
4 *
5 * Include after "color.h"
6 */
7 #ifndef _RAD_TONEMAP_H_
8 #define _RAD_TONEMAP_H_
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13 #include "tifftypes.h"
14
15 /**** Argument Macros ****/
16 /* Flags of what to do */
17 #define TM_F_HCONTR 01 /* human contrast sensitivity */
18 #define TM_F_MESOPIC 02 /* mesopic color sensitivity */
19 #define TM_F_LINEAR 04 /* linear brightness mapping */
20 #define TM_F_ACUITY 010 /* acuity adjustment */
21 #define TM_F_VEIL 020 /* veiling glare */
22 #define TM_F_CWEIGHT 040 /* center weighting */
23 #define TM_F_FOVEAL 0100 /* use foveal sample size */
24 #define TM_F_BW 0200 /* luminance only */
25 #define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
26 /* combined modes */
27 #define TM_F_CAMERA 0
28 #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
29 TM_F_ACUITY|TM_F_FOVEAL)
30 #define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
31
32 /* special pointer values */
33 #define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
34 #define TM_NOCHROM (BYTE *)NULL /* indicate no chrominance */
35 #define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */
36 #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
37
38
39 /**** Error Return Values ****/
40
41 #define TM_E_OK 0 /* normal return status */
42 #define TM_E_NOMEM 1 /* out of memory */
43 #define TM_E_ILLEGAL 2 /* illegal argument value */
44 #define TM_E_TMINVAL 3 /* no valid tone mapping */
45 #define TM_E_TMFAIL 4 /* cannot compute tone mapping */
46 #define TM_E_BADFILE 5 /* cannot open or understand file */
47 #define TM_E_CODERR1 6 /* code consistency error 1 */
48 #define TM_E_CODERR2 7 /* code consistency error 2 */
49
50
51 /**** Conversion Constants and Table Sizes ****/
52
53 #define TM_BRTSCALE 128 /* brightness scale factor (integer) */
54
55 #define TM_NOBRT (-1<<15) /* bogus brightness value */
56 #define TM_NOLUM (1e-17) /* ridiculously small luminance */
57
58 #define TM_MAXPKG 8 /* maximum number of color formats */
59
60
61 /**** Global Data Types and Structures ****/
62
63 #ifndef MEM_PTR
64 #define MEM_PTR void *
65 #endif
66
67 extern char *tmErrorMessage[]; /* error messages */
68 extern int tmLastError; /* last error incurred by library */
69 extern char *tmLastFunction; /* error-generating function name */
70
71 typedef short TMbright; /* encoded luminance type */
72
73 /* basic tone mapping data structure */
74 extern struct tmStruct {
75 int flags; /* flags of what to do */
76 RGBPRIMP monpri; /* monitor RGB primaries */
77 double mongam; /* monitor gamma value (approx.) */
78 COLOR clf; /* computed luminance coefficients */
79 int cdiv[3]; /* computed color divisors */
80 RGBPRIMP inppri; /* current input primaries */
81 double inpsf; /* current input scalefactor */
82 COLORMAT cmat; /* color conversion matrix */
83 TMbright hbrmin, hbrmax; /* histogram brightness limits */
84 int *histo; /* input histogram */
85 TMbright mbrmin, mbrmax; /* mapped brightness limits */
86 unsigned short *lumap; /* computed luminance map */
87 struct tmStruct *tmprev; /* previous tone mapping */
88 MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
89 } *tmTop; /* current tone mapping stack */
90
91 /* conversion package functions */
92 struct tmPackage {
93 MEM_PTR (*Init)(struct tmStruct *tms);
94 void (*NewSpace)(struct tmStruct *tms);
95 void (*Free)(MEM_PTR pp);
96 };
97 /* our list of conversion packages */
98 extern struct tmPackage *tmPkg[TM_MAXPKG];
99 extern int tmNumPkgs; /* number of registered packages */
100
101
102 /**** Useful Macros ****/
103
104 /* compute luminance from encoded value */
105 #define tmLuminance(li) exp((li)*(1./TM_BRTSCALE))
106
107 /* does tone mapping need color matrix? */
108 #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
109
110 /* register a conversion package */
111 #define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
112 (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
113
114 /* get the specific package's data */
115 #define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
116
117
118 /**** Library Function Calls ****/
119
120
121 extern struct tmStruct *
122 tmInit(int flags, RGBPRIMP monpri, double gamval);
123 /*
124 Initialize new tone mapping and push it onto stack.
125
126 flags - TM_F_* flags indicating what is to be done.
127 monpri - display monitor primaries (Note 1).
128 gamval - display gamma response (can be approximate).
129
130 returns - new tmTop, or NULL if insufficient memory.
131 */
132
133 extern int
134 tmSetSpace(RGBPRIMP pri, double sf);
135 /*
136 Set color primaries and scale factor for incoming scanlines.
137
138 pri - RGB color input primaries (Note 1).
139 sf - scale factor to get to luminance in cd/m^2.
140
141 returns - 0 on success, TM_E_* code on failure.
142 */
143
144 extern void
145 tmClearHisto(void);
146 /*
147 Clear histogram for current tone mapping.
148 */
149
150 extern int
151 tmAddHisto(TMbright *ls, int len, int wt);
152 /*
153 Add brightness values to current histogram.
154
155 ls - encoded luminance values.
156 len - number of luminance values.
157 wt - integer weight to use for each value (usually 1 or -1).
158
159 returns - 0 on success, TM_E_* on error.
160 */
161
162 extern int
163 tmFixedMapping(double expmult, double gamval);
164 /*
165 Assign a fixed, linear tone-mapping using the given multiplier,
166 which is the ratio of maximum output to uncalibrated input.
167 This mapping will be used in subsequent calls to tmMapPixels()
168 until a new tone mapping is computed.
169 Only the min. and max. values are used from the histogram.
170
171 expmult - the fixed exposure multiplier to use.
172 gamval - display gamma response (0. for default).
173 returns - 0 on success, TM_E_* on error.
174 */
175
176 extern int
177 tmComputeMapping(double gamval, double Lddyn, double Ldmax);
178 /*
179 Compute tone mapping function from the current histogram.
180 This mapping will be used in subsequent calls to tmMapPixels()
181 until a new tone mapping is computed.
182 I.e., calls to tmAddHisto() have no immediate effect.
183
184 gamval - display gamma response (0. for default).
185 Lddyn - the display's dynamic range (0. for default).
186 Ldmax - maximum display luminance in cd/m^2 (0. for default).
187
188 returns - 0 on success, TM_E_* on failure.
189 */
190
191 extern int
192 tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len);
193 /*
194 Apply tone mapping function to pixel values.
195
196 ps - returned pixel values (Note 2).
197 ls - encoded luminance values.
198 cs - encoded chrominance values (Note 2).
199 len - number of pixels.
200
201 returns - 0 on success, TM_E_* on failure.
202 */
203
204 extern struct tmStruct *
205 tmPop(void);
206 /*
207 Pops current tone mapping from stack.
208
209 returns - pointer to tone mapping structure, or NULL if none.
210 */
211
212 extern int
213 tmPull(struct tmStruct *tms);
214 /*
215 Pull tone mapping from anywhere in stack.
216
217 tms - tone mapping structure to find.
218
219 returns - 1 if found in stack, 0 otherwise.
220 */
221
222 extern int
223 tmPush(struct tmStruct *tms);
224 /*
225 Make tone mapping active by (pulling it and) pushing it to the top.
226
227 tms - initialized tone mapping structure.
228
229 returns - 0 on success, TM_E_* if tms is invalid.
230 */
231
232 extern struct tmStruct *
233 tmDup(void);
234 /*
235 Duplicate the current tone mapping into a new structure on the stack.
236
237 returns - pointer to new top, or NULL on error.
238 */
239
240 extern void
241 tmDone(struct tmStruct *tms);
242 /*
243 Free data associated with the given tone mapping structure.
244 Calls tmPull() first to remove it from the stack if present.
245 The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL)
246 all have the same effect, which is to remove and free
247 the current tone mapping.
248
249 tms - tone mapping structure to free.
250 */
251
252 extern int
253 tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len);
254 /*
255 Convert RGB/XYZ float scanline to encoded luminance and chrominance.
256
257 ls - returned encoded luminance values.
258 cs - returned encoded chrominance values (Note 2).
259 scan - input scanline.
260 len - scanline length.
261
262 returns - 0 on success, TM_E_* on error.
263 */
264
265 extern int
266 tmCvGrays(TMbright *ls, float *scan, int len);
267 /*
268 Convert gray float scanline to encoded luminance.
269
270 ls - returned encoded luminance values.
271 scan - input scanline.
272 len - scanline length.
273
274 returns - 0 on success, TM_E_* on error.
275 */
276
277 extern int
278 tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len);
279 /*
280 Convert RGBE/XYZE scanline to encoded luminance and chrominance.
281
282 ls - returned encoded luminance values.
283 cs - returned encoded chrominance values (Note 2).
284 scan - input scanline.
285 len - scanline length.
286
287 returns - 0 on success, TM_E_* on error.
288 */
289
290 extern int
291 tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp,
292 char *fname, FILE *fp);
293 /*
294 Load Radiance picture and convert to tone mapping representation.
295 Memory for the luminance and chroma arrays is allocated using
296 malloc(3), and should be freed with free(3) when no longer needed.
297 Calls tmSetSpace() to calibrate input color space.
298
299 lpp - returned array of encoded luminances, picture ordering.
300 cpp - returned array of encoded chrominances (Note 2).
301 xp, yp - returned picture dimensions.
302 fname - picture file name.
303 fp - pointer to open file (Note 3).
304
305 returns - 0 on success, TM_E_* on failure.
306 */
307
308 extern int
309 tmMapPicture(BYTE **psp, int *xp, int *yp, int flags,
310 RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
311 char *fname, FILE *fp);
312 /*
313 Load and apply tone mapping to Radiance picture.
314 Stack is restored to its original state upon return.
315 If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
316 calls pcond to perform the actual conversion, which takes
317 longer but gives access to all the TM_F_* features.
318 Memory for the final pixel array is allocated using malloc(3),
319 and should be freed with free(3) when it is no longer needed.
320
321 psp - returned array of tone mapped pixels, picture ordering.
322 xp, yp - returned picture dimensions.
323 flags - TM_F_* flags indicating what is to be done.
324 monpri - display monitor primaries (Note 1).
325 gamval - display gamma response.
326 Lddyn - the display's dynamic range (0. for default).
327 Ldmax - maximum display luminance in cd/m^2 (0. for default).
328 fname - picture file name.
329 fp - pointer to open file (Note 3).
330
331 returns - 0 on success, TM_E_* on failure.
332 */
333
334 extern int
335 tmCvRGB48(TMbright *ls, BYTE *cs, uint16 (*scan)[3], int len, double gv);
336 /*
337 Convert 48-bit RGB scanline to encoded luminance and chrominance.
338
339 ls - returned encoded luminance values.
340 cs - returned encoded chrominance values (Note 2).
341 scan - input scanline.
342 len - scanline length.
343 gv - input gamma value.
344
345 returns - 0 on success, TM_E_* on error.
346 */
347
348 extern int
349 tmCvGray16(TMbright *ls, uint16 *scan, int len, double gv);
350 /*
351 Convert 16-bit gray scanline to encoded luminance.
352
353 ls - returned encoded luminance values.
354 scan - input scanline.
355 len - scanline length.
356 gv - input gamma value.
357
358 returns - 0 on success, TM_E_* on error.
359 */
360
361 /**** Notes ****/
362 /*
363 General:
364
365 The usual sequence after calling tmInit() is to convert some
366 pixel values to chroma and luminance encodings, which can
367 be passed to tmAddHisto() to put into the tone mapping histogram.
368 This histogram is then used along with the display parameters
369 by tmComputeMapping() to compute the luminance mapping function.
370 (Colors are tone-mapped as they are converted if TM_F_MESOPIC
371 is set.) The encoded chroma and luminance values may then be
372 passed to tmMapPixels() to apply the computed tone mapping in
373 a second pass.
374
375 Especially for RGBE colors in the same color space as the
376 target display, the conversion to chroma and luminance values
377 is fast enough that it may be recomputed on the second pass
378 if memory is at a premium. (Since the chroma values are only
379 used during final mapping, setting the cs parameter to TM_NOCHROM
380 on the first pass will save time.) Another memory saving option
381 if third and subsequent passes are not needed is to use the
382 same array to store the mapped pixels as used to store
383 the encoded chroma values. This way, only two extra bytes
384 for storing encoded luminances are required per pixel. This
385 is the method employed by tmMapPicture(), for example.
386 */
387 /*
388 Note 1:
389
390 All RGBPRIMP values should be pointers to static structures.
391 I.e., the same pointer should be used for the same primaries,
392 and those primaries should not change from one call to the next.
393 This is because the routines use the pointer value to identify
394 computed conversion matrices, so the matrices do not have to be
395 rebuilt each time. If you are using the standard primaries,
396 use the standard primary pointer, stdprims.
397
398 To indicate a set of input primaries are actually CIE XYZ,
399 the TM_XYZPRIM macro may be passed. If the input primaries
400 are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
401 By default, the input primaries equal the monitor primaries
402 and the scalefactor is set to WHTEFFICACY in tmInit().
403 */
404 /*
405 Note 2:
406
407 Chrominance is optional in most of these routines, whether
408 TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
409 TM_NOCHROMP for picture reading) indicates that returned
410 color values are not desired.
411
412 If TM_NOCHROM is passed to a mapping routine expecting chroma
413 input, it will do without it and return luminance channel
414 rather than RGB pixel values. Otherwise, the array for
415 returned pixel values may be the same array used to pass
416 encoded chrominances if no other mappings are desired.
417 */
418 /*
419 Note 3:
420
421 Picture files may either be opened by the calling routine or by
422 the library function. If opened by the calling routine, the
423 pointer to the stream is passed, which may be a pipe or other
424 non-seekable input as it is only read once. It must be
425 positioned at the beginning when the function is called, and it
426 will be positioned at the end on return. It will not be closed.
427 If the passed stream pointer is TM_GETFILE, then the library
428 function will open the file, read its contents and close it
429 before returning, whether or not an error was encountered.
430 */
431
432 #ifdef __cplusplus
433 }
434 #endif
435 #endif /* _RAD_TONEMAP_H_ */
436
