--- ray/src/common/tonemap.h 2005/11/15 06:53:00 3.21 +++ ray/src/common/tonemap.h 2006/05/10 15:21:58 3.22 @@ -1,4 +1,4 @@ -/* RCSid $Id: tonemap.h,v 3.21 2005/11/15 06:53:00 greg Exp $ */ +/* RCSid $Id: tonemap.h,v 3.22 2006/05/10 15:21:58 greg Exp $ */ /* * Header file for tone mapping functions. * @@ -124,6 +124,18 @@ tmCvLuminance(double lum); Convert a single luminance value to an encoded brightness value. */ +extern int +tmCvLums(TMbright *ls, float *scan, int len); +/* + Convert luminance values to encoded brightness values using lookup. + + ls - returned encoded luminance values. + scan - input scanline. + len - scanline length. + + returns - 0 on success, TM_E_* on error. + */ + extern TMstruct * tmInit(int flags, RGBPRIMP monpri, double gamval); /* @@ -235,13 +247,12 @@ tmDone(TMstruct *tms); */ extern int -tmCvColors(TMstruct *tms, TMbright *ls, BYTE *cs, COLOR *scan, int len); +tmCvGrays(TMstruct *tms, TMbright *ls, float *scan, int len); /* - Convert RGB/XYZ float scanline to encoded luminance and chrominance. + Convert gray float scanline to encoded luminance. tms - tone mapping structure pointer. ls - returned encoded luminance values. - cs - returned encoded chrominance values (Note 2). scan - input scanline. len - scanline length. @@ -249,12 +260,13 @@ tmCvColors(TMstruct *tms, TMbright *ls, BYTE *cs, COLO */ extern int -tmCvGrays(TMstruct *tms, TMbright *ls, float *scan, int len); +tmCvColors(TMstruct *tms, TMbright *ls, BYTE *cs, COLOR *scan, int len); /* - Convert gray float scanline to encoded luminance. + Convert RGB/XYZ float scanline to encoded luminance and chrominance. tms - tone mapping structure pointer. ls - returned encoded luminance values. + cs - returned encoded chrominance values (Note 2). scan - input scanline. len - scanline length.
