root/radiance/ray/src/common/tonemap.h
Revision: 3.13
Committed: Fri Jun 6 16:38:47 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.12: +8 -24 lines
*** empty log message ***
1 /* RCSid $Id: tonemap.h,v 3.12 2003/02/25 02:47:22 greg Exp $ */
2 /*
3 * Header file for tone mapping functions.
4 *
5 * Include after "color.h"
6 */
7 #ifndef _RAD_TONEMAP_H_
8 #define _RAD_TONEMAP_H_
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13
14 #include "copyright.h"
15
16 /**** Argument Macros ****/
17 /* Flags of what to do */
18 #define TM_F_HCONTR 01 /* human contrast sensitivity */
19 #define TM_F_MESOPIC 02 /* mesopic color sensitivity */
20 #define TM_F_LINEAR 04 /* linear brightness mapping */
21 #define TM_F_ACUITY 010 /* acuity adjustment */
22 #define TM_F_VEIL 020 /* veiling glare */
23 #define TM_F_CWEIGHT 040 /* center weighting */
24 #define TM_F_FOVEAL 0100 /* use foveal sample size */
25 #define TM_F_BW 0200 /* luminance only */
26 #define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
27 /* combined modes */
28 #define TM_F_CAMERA 0
29 #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
30 TM_F_ACUITY|TM_F_FOVEAL)
31 #define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
32
33 /* special pointer values */
34 #define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
35 #define TM_NOCHROM (BYTE *)NULL /* indicate no chrominance */
36 #define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */
37 #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
38
39
40 /**** Error Return Values ****/
41
42 #define TM_E_OK 0 /* normal return status */
43 #define TM_E_NOMEM 1 /* out of memory */
44 #define TM_E_ILLEGAL 2 /* illegal argument value */
45 #define TM_E_TMINVAL 3 /* no valid tone mapping */
46 #define TM_E_TMFAIL 4 /* cannot compute tone mapping */
47 #define TM_E_BADFILE 5 /* cannot open or understand file */
48 #define TM_E_CODERR1 6 /* code consistency error 1 */
49 #define TM_E_CODERR2 7 /* code consistency error 2 */
50
51
52 /**** Conversion Constants and Table Sizes ****/
53
54 #define TM_BRTSCALE 128 /* brightness scale factor (integer) */
55
56 #define TM_NOBRT (-1<<15) /* bogus brightness value */
57 #define TM_NOLUM (1e-17) /* ridiculously small luminance */
58
59 #define TM_MAXPKG 8 /* maximum number of color formats */
60
61
62 /**** Global Data Types and Structures ****/
63
64 #ifndef MEM_PTR
65 #define MEM_PTR void *
66 #endif
67
68 extern char *tmErrorMessage[]; /* error messages */
69 extern int tmLastError; /* last error incurred by library */
70 extern char *tmLastFunction; /* error-generating function name */
71
72 typedef short TMbright; /* encoded luminance type */
73
74 /* basic tone mapping data structure */
75 extern struct tmStruct {
76 int flags; /* flags of what to do */
77 RGBPRIMP monpri; /* monitor RGB primaries */
78 double mongam; /* monitor gamma value (approx.) */
79 COLOR clf; /* computed luminance coefficients */
80 int cdiv[3]; /* computed color divisors */
81 RGBPRIMP inppri; /* current input primaries */
82 double inpsf; /* current input scalefactor */
83 COLORMAT cmat; /* color conversion matrix */
84 TMbright hbrmin, hbrmax; /* histogram brightness limits */
85 int *histo; /* input histogram */
86 TMbright mbrmin, mbrmax; /* mapped brightness limits */
87 unsigned short *lumap; /* computed luminance map */
88 struct tmStruct *tmprev; /* previous tone mapping */
89 MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
90 } *tmTop; /* current tone mapping stack */
91
92 /* conversion package functions */
93 struct tmPackage {
94 MEM_PTR (*Init)(struct tmStruct *tms);
95 void (*NewSpace)(struct tmStruct *tms);
96 void (*Free)(MEM_PTR pp);
97 };
98 /* our list of conversion packages */
99 extern struct tmPackage *tmPkg[TM_MAXPKG];
100 extern int tmNumPkgs; /* number of registered packages */
101
102
103 /**** Useful Macros ****/
104
105 /* compute luminance from encoded value */
106 #define tmLuminance(li) exp((li)*(1./TM_BRTSCALE))
107
108 /* does tone mapping need color matrix? */
109 #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
110
111 /* register a conversion package */
112 #define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
113 (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
114
115 /* get the specific package's data */
116 #define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
117
118
119 /**** Library Function Calls ****/
120
121
122 extern struct tmStruct *
123 tmInit(int flags, RGBPRIMP monpri, double gamval);
124 /*
125 Initialize new tone mapping and push it onto stack.
126
127 flags - TM_F_* flags indicating what is to be done.
128 monpri - display monitor primaries (Note 1).
129 gamval - display gamma response (can be approximate).
130
131 returns - new tmTop, or NULL if insufficient memory.
132 */
133
134 extern int
135 tmSetSpace(RGBPRIMP pri, double sf);
136 /*
137 Set color primaries and scale factor for incoming scanlines.
138
139 pri - RGB color input primaries (Note 1).
140 sf - scale factor to get to luminance in cd/m^2.
141
142 returns - 0 on success, TM_E_* code on failure.
143 */
144
145 extern void
146 tmClearHisto(void);
147 /*
148 Clear histogram for current tone mapping.
149 */
150
151 extern int
152 tmAddHisto(TMbright *ls, int len, int wt);
153 /*
154 Add brightness values to current histogram.
155
156 ls - encoded luminance values.
157 len - number of luminance values.
158 wt - integer weight to use for each value (usually 1 or -1).
159
160 returns - 0 on success, TM_E_* on error.
161 */
162
163 extern int
164 tmFixedMapping(double expmult, double gamval);
165 /*
166 Assign a fixed, linear tone-mapping using the given multiplier,
167 which is the ratio of maximum output to uncalibrated input.
168 This mapping will be used in subsequent calls to tmMapPixels()
169 until a new tone mapping is computed.
170 Only the min. and max. values are used from the histogram.
171
172 expmult - the fixed exposure multiplier to use.
173 gamval - display gamma response (0. for default).
174 returns - 0 on success, TM_E_* on error.
175 */
176
177 extern int
178 tmComputeMapping(double gamval, double Lddyn, double Ldmax);
179 /*
180 Compute tone mapping function from the current histogram.
181 This mapping will be used in subsequent calls to tmMapPixels()
182 until a new tone mapping is computed.
183 I.e., calls to tmAddHisto() have no immediate effect.
184
185 gamval - display gamma response (0. for default).
186 Lddyn - the display's dynamic range (0. for default).
187 Ldmax - maximum display luminance in cd/m^2 (0. for default).
188
189 returns - 0 on success, TM_E_* on failure.
190 */
191
192 extern int
193 tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len);
194 /*
195 Apply tone mapping function to pixel values.
196
197 ps - returned pixel values (Note 2).
198 ls - encoded luminance values.
199 cs - encoded chrominance values (Note 2).
200 len - number of pixels.
201
202 returns - 0 on success, TM_E_* on failure.
203 */
204
205 extern struct tmStruct *
206 tmPop(void);
207 /*
208 Pops current tone mapping from stack.
209
210 returns - pointer to tone mapping structure, or NULL if none.
211 */
212
213 extern int
214 tmPull(struct tmStruct *tms);
215 /*
216 Pull tone mapping from anywhere in stack.
217
218 tms - tone mapping structure to find.
219
220 returns - 1 if found in stack, 0 otherwise.
221 */
222
223 extern int
224 tmPush(struct tmStruct *tms);
225 /*
226 Make tone mapping active by (pulling it and) pushing it to the top.
227
228 tms - initialized tone mapping structure.
229
230 returns - 0 on success, TM_E_* if tms is invalid.
231 */
232
233 extern struct tmStruct *
234 tmDup(void);
235 /*
236 Duplicate the current tone mapping into a new structure on the stack.
237
238 returns - pointer to new top, or NULL on error.
239 */
240
241 extern void
242 tmDone(struct tmStruct *tms);
243 /*
244 Free data associated with the given tone mapping structure.
245 Calls tmPull() first to remove it from the stack if present.
246 The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL)
247 all have the same effect, which is to remove and free
248 the current tone mapping.
249
250 tms - tone mapping structure to free.
251 */
252
253 extern int
254 tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len);
255 /*
256 Convert RGB/XYZ float scanline to encoded luminance and chrominance.
257
258 ls - returned encoded luminance values.
259 cs - returned encoded chrominance values (Note 2).
260 scan - input scanline.
261 len - scanline length.
262
263 returns - 0 on success, TM_E_* on error.
264 */
265
266 extern int
267 tmCvGrays(TMbright *ls, float *scan, int len);
268 /*
269 Convert gray float scanline to encoded luminance.
270
271 ls - returned encoded luminance values.
272 scan - input scanline.
273 len - scanline length.
274
275 returns - 0 on success, TM_E_* on error.
276 */
277
278 extern int
279 tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len);
280 /*
281 Convert RGBE/XYZE scanline to encoded luminance and chrominance.
282
283 ls - returned encoded luminance values.
284 cs - returned encoded chrominance values (Note 2).
285 scan - input scanline.
286 len - scanline length.
287
288 returns - 0 on success, TM_E_* on error.
289 */
290
291 extern int
292 tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp,
293 char *fname, FILE *fp);
294 /*
295 Load Radiance picture and convert to tone mapping representation.
296 Memory for the luminance and chroma arrays is allocated using
297 malloc(3), and should be freed with free(3) when no longer needed.
298 Calls tmSetSpace() to calibrate input color space.
299
300 lpp - returned array of encoded luminances, picture ordering.
301 cpp - returned array of encoded chrominances (Note 2).
302 xp, yp - returned picture dimensions.
303 fname - picture file name.
304 fp - pointer to open file (Note 3).
305
306 returns - 0 on success, TM_E_* on failure.
307 */
308
309 extern int
310 tmMapPicture(BYTE **psp, int *xp, int *yp, int flags,
311 RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
312 char *fname, FILE *fp);
313 /*
314 Load and apply tone mapping to Radiance picture.
315 Stack is restored to its original state upon return.
316 If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
317 calls pcond to perform the actual conversion, which takes
318 longer but gives access to all the TM_F_* features.
319 Memory for the final pixel array is allocated using malloc(3),
320 and should be freed with free(3) when it is no longer needed.
321
322 psp - returned array of tone mapped pixels, picture ordering.
323 xp, yp - returned picture dimensions.
324 flags - TM_F_* flags indicating what is to be done.
325 monpri - display monitor primaries (Note 1).
326 gamval - display gamma response.
327 Lddyn - the display's dynamic range (0. for default).
328 Ldmax - maximum display luminance in cd/m^2 (0. for default).
329 fname - picture file name.
330 fp - pointer to open file (Note 3).
331
332 returns - 0 on success, TM_E_* on failure.
333 */
334
335
336
337 /**** Notes ****/
338 /*
339 General:
340
341 The usual sequence after calling tmInit() is to convert some
342 pixel values to chroma and luminance encodings, which can
343 be passed to tmAddHisto() to put into the tone mapping histogram.
344 This histogram is then used along with the display parameters
345 by tmComputeMapping() to compute the luminance mapping function.
346 (Colors are tone-mapped as they are converted if TM_F_MESOPIC
347 is set.) The encoded chroma and luminance values may then be
348 passed to tmMapPixels() to apply the computed tone mapping in
349 a second pass.
350
351 Especially for RGBE colors in the same color space as the
352 target display, the conversion to chroma and luminance values
353 is fast enough that it may be recomputed on the second pass
354 if memory is at a premium. (Since the chroma values are only
355 used during final mapping, setting the cs parameter to TM_NOCHROM
356 on the first pass will save time.) Another memory saving option
357 if third and subsequent passes are not needed is to use the
358 same array to store the mapped pixels as used to store
359 the encoded chroma values. This way, only two extra bytes
360 for storing encoded luminances are required per pixel. This
361 is the method employed by tmMapPicture(), for example.
362 */
363 /*
364 Note 1:
365
366 All RGBPRIMP values should be pointers to static structures.
367 I.e., the same pointer should be used for the same primaries,
368 and those primaries should not change from one call to the next.
369 This is because the routines use the pointer value to identify
370 computed conversion matrices, so the matrices do not have to be
371 rebuilt each time. If you are using the standard primaries,
372 use the standard primary pointer, stdprims.
373
374 To indicate a set of input primaries are actually CIE XYZ,
375 the TM_XYZPRIM macro may be passed. If the input primaries
376 are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
377 By default, the input primaries equal the monitor primaries
378 and the scalefactor is set to WHTEFFICACY in tmInit().
379 */
380 /*
381 Note 2:
382
383 Chrominance is optional in most of these routines, whether
384 TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
385 TM_NOCHROMP for picture reading) indicates that returned
386 color values are not desired.
387
388 If TM_NOCHROM is passed to a mapping routine expecting chroma
389 input, it will do without it and return luminance channel
390 rather than RGB pixel values. Otherwise, the array for
391 returned pixel values may be the same array used to pass
392 encoded chrominances if no other mappings are desired.
393 */
394 /*
395 Note 3:
396
397 Picture files may either be opened by the calling routine or by
398 the library function. If opened by the calling routine, the
399 pointer to the stream is passed, which may be a pipe or other
400 non-seekable input as it is only read once. It must be
401 positioned at the beginning when the function is called, and it
402 will be positioned at the end on return. It will not be closed.
403 If the passed stream pointer is TM_GETFILE, then the library
404 function will open the file, read its contents and close it
405 before returning, whether or not an error was encountered.
406 */
407
408 #ifdef __cplusplus
409 }
410 #endif
411 #endif /* _RAD_TONEMAP_H_ */
412
